[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #318
See <https://build.geoserver.org/job/geoserver-java11/318/display/redirect?page=changes&gt;
Changes:
[Steve.Ikeoka] [GEOS-9121] Added a fixed sort order to the module status table.
[...truncated 1.56 MB...]
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[211,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[219,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[227,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLike
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[238,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNull
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[244,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNil
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[250,25\] cannot find symbol
[ERROR] symbol: class BBOX
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[255,25\] cannot find symbol
[ERROR] symbol: class Beyond
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[260,25\] cannot find symbol
[ERROR] symbol: class Contains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[265,25\] cannot find symbol
[ERROR] symbol: class Crosses
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[270,25\] cannot find symbol
[ERROR] symbol: class Disjoint
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[275,25\] cannot find symbol
[ERROR] symbol: class DWithin
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[280,25\] cannot find symbol
[ERROR] symbol: class Equals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[285,25\] cannot find symbol
[ERROR] symbol: class Intersects
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[290,25\] cannot find symbol
[ERROR] symbol: class Overlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[295,25\] cannot find symbol
[ERROR] symbol: class Touches
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[300,25\] cannot find symbol
[ERROR] symbol: class Within
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[305,25\] cannot find symbol
[ERROR] symbol: class After
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[313,25\] cannot find symbol
[ERROR] symbol: class AnyInteracts
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[318,25\] cannot find symbol
[ERROR] symbol: class Before
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[326,25\] cannot find symbol
[ERROR] symbol: class Begins
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[331,25\] cannot find symbol
[ERROR] symbol: class BegunBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[336,25\] cannot find symbol
[ERROR] symbol: class During
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[341,25\] cannot find symbol
[ERROR] symbol: class EndedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[346,25\] cannot find symbol
[ERROR] symbol: class Ends
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[351,25\] cannot find symbol
[ERROR] symbol: class Meets
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[356,25\] cannot find symbol
[ERROR] symbol: class MetBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[361,25\] cannot find symbol
[ERROR] symbol: class OverlappedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[366,25\] cannot find symbol
[ERROR] symbol: class TContains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[371,25\] cannot find symbol
[ERROR] symbol: class TEquals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[377,25\] cannot find symbol
[ERROR] symbol: class TOverlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[78,35\] cannot find symbol
[ERROR] symbol: class BinaryComparisonOperator
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria.PropertyComparable
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[95,35\] cannot find symbol
[ERROR] symbol: class BinaryTemporalOperator
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-csw: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-app: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/TestHomePage.java&gt;:\[6,1\] cannot access org.geoserver.wicket.test
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/scale2/jt-scale2/1.1.7/jt-scale2-1.1.7.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/WebXmlTest.java&gt;:\[6,1\] cannot access org.geoserver.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/filters/GZIPResponseStreamTest.java&gt;:\[6,1\] cannot access org.geoserver.filters
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java&gt;:\[16,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java&gt;:\[16,44\] cannot find symbol
[ERROR] symbol: class Serializable
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java&gt;:\[22,31\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: interface org.geoserver.wicket.test.IComponentFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java&gt;:\[22,5\] cannot find symbol
[ERROR] symbol: class Component
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java&gt;:\[28,8\] cannot access org.geoserver.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java&gt;:\[28,44\] cannot find symbol
[ERROR] symbol: class WebApplication
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java&gt;:\[69,12\] cannot find symbol
[ERROR] symbol: class Class
[ERROR] location: class org.geoserver.wicket.test.WicketTestApplication
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java&gt;:\[69,28\] cannot find symbol
[ERROR] symbol: class Page
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;:\[49,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;:\[50,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.web.Start
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;:\[180,20\] cannot find symbol
[ERROR] symbol: class SslContextFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;:\[214,30\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;:\[269,56\] cannot find symbol
[ERROR] symbol: class KeyStore
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
Not sending mail to unregistered user Steve.Ikeoka@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/319/display/redirect?page=changes&gt;
Changes:
[github] Update Jetty deprecated properties
[github] Typo in ControlFlowCallback.java
[...truncated 1.85 MB...]
[ERROR] location: class org.geoserver.web.netcdf.DataPacking
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[145,26\] cannot find symbol
[ERROR] symbol: class Integer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[147,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[149,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[157,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[159,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[161,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[164,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[167,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[170,21\] cannot find symbol
[ERROR] symbol: class DataType
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[263,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;:\[265,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[8,8\] cannot access com
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/commons-pool/commons-pool/1.5.4/commons-pool-1.5.4.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[8,11\] cannot access com.thoughtworks
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[8,32\] import requires canonical name for <any>.xstream.XStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[9,21\] cannot access org.geoserver.config
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[9,28\] cannot access org.geoserver.config.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[9,33\] import requires canonical name for <any>.XStreamPersister
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[10,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[8,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[10,21\] cannot access org.geoserver.catalog
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[13,57\] cannot find symbol
[ERROR] symbol: class XStreamPersisterInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[16,22\] cannot find symbol
[ERROR] location: class org.geoserver.web.netcdf.ExtraVariableXStreamInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[63,13\] cannot find symbol
[ERROR] symbol: class MetadataMap
[ERROR] location: class org.geoserver.web.netcdf.NetCDFSettingsContainer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[142,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[7,24\] cannot access com.thoughtworks.xstream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[7,32\] package com.thoughtworks.xstream does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[8,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[9,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[12,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[15,22\] cannot find symbol
[ERROR] location: class org.geoserver.web.netcdf.NetCDFContainerXStreamInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[36,8\] cannot access org.geoserver.wcs
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[36,53\] cannot find symbol
[ERROR] symbol: class BaseCoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[37,20\] cannot find symbol
[ERROR] symbol: class CoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[37,46\] cannot find symbol
[ERROR] symbol: class ApplicationContextAware
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[39,25\] cannot find symbol
[ERROR] location: class org.geoserver.wcs.responses.NetCDFCoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[41,13\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[11,21\] cannot access org.geoserver.wcs2_0
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[11,28\] cannot access org.geoserver.wcs2_0.response
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[11,37\] import requires canonical name for <any>.GranuleStack
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[12,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[12,20\] cannot access org.geotools.coverage
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[12,34\] import requires canonical name for <any>.grid.GridCoverage2D
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[44,43\] cannot find symbol
[ERROR] symbol: class GeoServer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[74,13\] cannot find symbol
[ERROR] symbol: class GridCoverage2D
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[76,13\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[77,13\] cannot find symbol
[ERROR] symbol: class OutputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[78,20\] cannot find symbol
[ERROR] symbol: class ServiceException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[78,38\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[107,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[107,12\] cannot find symbol
[ERROR] symbol: class GranuleStack
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,80\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[147,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[147,85\] cannot find symbol
[ERROR] symbol: class BeansException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[152,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[30,13\] cannot find symbol
[ERROR] location: interface org.geoserver.wcs.responses.NetCDFEncoderFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[11,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[13,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[14,21\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[14,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[15,37\] package org.geoserver.wcs2_0.response does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[16,28\] cannot access org.geoserver.wcs2_0.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[16,33\] package org.geoserver.wcs2_0.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,8\] cannot access ucar
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,12\] cannot access ucar.ma2
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,16\] import requires canonical name for <any>.InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[43,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[33,38\] cannot find symbol
[ERROR] symbol: class InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,8\] cannot access javax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,13\] cannot access javax.measure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,21\] import requires canonical name for <any>.Unit
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[14,21\] cannot access javax.measure.format
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[14,28\] package javax.measure.format does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,25\] import requires canonical name for <any>.Component
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[16,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[16,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[17,30\] cannot access org.apache.wicket.ajax.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[17,35\] package org.apache.wicket.ajax.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,25\] cannot access org.apache.wicket.extensions
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,36\] cannot access org.apache.wicket.extensions.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,66\] import requires canonical name for <any>.markup.html.autocomplete.AutoCompleteTextField
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,43\] import requires canonical name for <any>.basic.Label
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[20,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[20,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[21,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;:\[6,1\] cannot access org.geoserver.wcs2_0.eo.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/com/google/errorprone/error_prone_annotations/2.2.0/error_prone_annotations-2.2.0.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;:\[17,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;:\[17,38\] cannot find symbol
[ERROR] symbol: class AdminPagePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;:\[20,28\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.wcs2_0.eo.web.WCSEOAdminPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;:\[20,39\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-sldservice
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/320/display/redirect?page=changes&gt;
