[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #324
See <https://build.geoserver.org/job/geoserver-java11/324/display/redirect&gt;
[...truncated 1.50 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.145 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.986 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.510 s]
[INFO] Main Module ........................................ SUCCESS [01:39 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.156 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:39 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:12 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.053 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.530 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 18.362 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.762 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:50 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:52 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:47 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 43.305 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.540 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:55 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 25.730 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 30.964 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 18.785 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.113 s]
[INFO] Core UI Module ..................................... SUCCESS [01:15 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 50.255 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:04 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.072 s]
[INFO] Demos Module ....................................... SUCCESS [ 35.421 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 24.602 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.090 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:18 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:37 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.791 s]
[INFO] REST UI Module ..................................... SUCCESS [ 16.972 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.070 s]
[INFO] Printing Module .................................... SUCCESS [ 10.022 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 9.166 s]
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.051 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.992 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.737 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.610 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.922 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.803 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.891 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.846 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 12.924 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.955 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.900 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.056 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.691 s]
[INFO] OGR WFS ............................................ SUCCESS [ 7.915 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.056 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:58 min]
[INFO] OGR WPS ............................................ SUCCESS [ 19.054 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.300 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.745 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.151 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.683 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 19.226 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 24.587 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 37.957 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.946 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.601 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.347 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 31.801 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.159 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 9.474 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.153 s]
[INFO] GeoServer CAS Security Web Module .................. FAILURE [ 0.609 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 29.557 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 52.527 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 23.070 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.089 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.325 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 15.522 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 59.661 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.138 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.048 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 12.023 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 15.618 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.044 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 24.129 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 24.652 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 14.361 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.277 s]
[INFO] Importer Core Module ............................... SUCCESS [01:26 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 56.057 s]
[INFO] Importer Berkley DB Persistence Module ............. FAILURE [ 2.999 s]
[INFO] Importer Web UI Module ............................. FAILURE [ 0.755 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.892 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 28.284 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 55.843 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 26.817 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 20.037 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.678 s]
[INFO] REST SLD service ................................... SUCCESS [ 33.254 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 31.419 s]
[INFO] GeoFence Server .................................... SUCCESS [ 53.030 s]
[INFO] BUILD FAILURE
[INFO] Total time: 27:52 min (Wall Clock)
[INFO] Finished at: 2019-02-09T10:27:43+00:00
[INFO] Final Memory: 604M/1474M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBindingTest.java&gt;:\[6,1\] cannot access org.geoserver.importer.bdb
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/crop/jt-crop/1.1.7/jt-crop-1.1.7.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java&gt;:\[29,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java&gt;:\[29,51\] cannot find symbol
[ERROR] symbol: class ImporterTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java&gt;:\[32,52\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] location: class org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java&gt;:\[71,18\] cannot find symbol
[ERROR] symbol: class DatabaseEntry
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java&gt;:\[71,5\] cannot find symbol
[ERROR] symbol: class Document
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java&gt;:\[71,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java&gt;:\[78,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[33,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[33,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[32,2\] cannot find symbol
[ERROR] symbol: class RunWith
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[36,19\] cannot find symbol
[ERROR] symbol: class Collection
[ERROR] location: class org.geoserver.importer.bdb.BDBImportStoreTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[44,5\] cannot find symbol
[ERROR] symbol: class BDBImportStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[45,5\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[47,13\] cannot find symbol
[ERROR] symbol: class BindingType
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[49,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[94,48\] cannot find symbol
[ERROR] symbol: class ImportContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[205,39\] cannot find symbol
[ERROR] symbol: class ImportVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java&gt;:\[213,27\] cannot find symbol
[ERROR] location: class org.geoserver.importer.bdb.BDBImportStoreTest.SearchingVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/CountingVisitor.java&gt;:\[11,1\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/CountingVisitor.java&gt;:\[11,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/CountingVisitor.java&gt;:\[15,23\] cannot find symbol
[ERROR] location: class org.geoserver.importer.bdb.CountingVisitor
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-bdb
See <https://build.geoserver.org/job/geoserver-java11/325/display/redirect&gt;
[...truncated 1.61 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLRawReader.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLRawReader.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLRawReader.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/Importer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/Importer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/Importer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/GdalTranslateTransform.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/GdalTranslateTransform.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/GdalTranslateTransform.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/mosaic/MosaicFormat.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/mosaic/MosaicFormat.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/mosaic/MosaicFormat.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AbstractTransform.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AbstractTransform.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AbstractTransform.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/GeoJSONFormat.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/GeoJSONFormat.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/GeoJSONFormat.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/KMLPlacemarkTransform.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/KMLPlacemarkTransform.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/KMLPlacemarkTransform.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AttributeRemapTransform.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AttributeRemapTransform.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AttributeRemapTransform.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/VectorFormat.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/VectorFormat.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/VectorFormat.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AbstractInlineVectorTransform.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AbstractInlineVectorTransform.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/AbstractInlineVectorTransform.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/InlineVectorTransform.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/InlineVectorTransform.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/InlineVectorTransform.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/ImportTransform.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/ImportTransform.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/ImportTransform.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/job/Task.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/job/Task.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/job/Task.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[5,1\] cannot access org.geoserver.geofence.rest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/jaitools/jt-vectorize/1.5.0/jt-vectorize-1.5.0.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[5,1\] cannot access org.geoserver.geofence.internal
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java&gt;:\[5,1\] cannot access org.geoserver.geofence.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[29,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[29,51\] cannot find symbol
[ERROR] symbol: class GeofenceBaseTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[31,15\] cannot find symbol
[ERROR] symbol: class AdminRulesRestController
[ERROR] location: class org.geoserver.geofence.rest.AdminRulesRestControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[33,15\] cannot find symbol
[ERROR] symbol: class AdminRuleAdminService
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[257,13\] cannot find symbol
[ERROR] symbol: class ResponseEntity
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[257,28\] cannot find symbol
[ERROR] symbol: class JaxbAdminRuleList
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[257,55\] cannot find symbol
[ERROR] symbol: class HttpStatus
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[271,42\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[271,57\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[280,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[280,57\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[280,72\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[301,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[21,8\] cannot access org.geoserver.geofence
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[23,13\] cannot find symbol
[ERROR] symbol: class MultiPolygonAdapter
[ERROR] location: class org.geoserver.geofence.rest.MultiPolygonAdapterTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[34,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[34,47\] cannot find symbol
[ERROR] symbol: class AbstractSecurityServiceTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[36,15\] cannot find symbol
[ERROR] symbol: class GeoServerRoleService
[ERROR] location: class org.geoserver.geofence.internal.InternalUserResolverTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[38,15\] cannot find symbol
[ERROR] symbol: class GeoServerRoleStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[41,28\] cannot find symbol
[ERROR] symbol: class SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[75,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[101,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[120,13\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[121,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[122,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[23,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[23,45\] cannot find symbol
[ERROR] symbol: class GeoServerWicketTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[26,31\] cannot find symbol
[ERROR] location: class org.geoserver.geofence.web.GeofenceRulesModelTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[93,36\] cannot find symbol
[ERROR] symbol: class GeofenceRulesModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[7,18\] cannot access org.junit
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[7,24\] import requires canonical name for <any>.Assert
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[9,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[9,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[9,25\] import requires canonical name for <any>.logging.Level
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[10,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[10,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[10,42\] import requires canonical name for <any>.ajax.markup.html.AjaxLink
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[11,25\] cannot access org.apache.wicket.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[11,30\] cannot access org.apache.wicket.util.tester
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[11,37\] import requires canonical name for <any>.FormTester
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[12,21\] cannot access org.geoserver.data
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[12,26\] cannot access org.geoserver.data.test
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[12,31\] import requires canonical name for <any>.SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[13,30\] cannot access org.geoserver.geofence.config
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[13,37\] package org.geoserver.geofence.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[14,30\] cannot access org.geoserver.geofence.services
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[14,39\] cannot access org.geoserver.geofence.services.dto
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[14,43\] import requires canonical name for <any>.ShortAdminRule
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[15,21\] cannot access org.geoserver.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[15,25\] package org.geoserver.web does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[16,25\] cannot access org.geoserver.web.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[16,32\] package org.geoserver.web.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[17,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[18,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[20,50\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[22,12\] cannot find symbol
[ERROR] symbol: class GeoFencePropertyPlaceholderConfigurer
[ERROR] location: class org.geoserver.geofence.web.GeofenceServerAdminPageTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[25,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[36,31\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-ogr-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-monitor-core
See <https://build.geoserver.org/job/geoserver-java11/326/display/redirect&gt;
[...truncated 712.40 KB...]
Running org.geoserver.wcs2_0.eo.GetCapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.416 sec
Running org.geoserver.wcs2_0.eo.GetCoverageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.438 sec
Running org.geoserver.wcs2_0.eo.GranuleCoverageExtensionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.302 sec
Results :
Tests run: 31, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-wcs2_0-eo-core ---
[debug] Using AOSP style
[INFO] Processed 19 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-wcs2_0-eo-core >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-wcs2_0-eo-core ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-wcs2_0-eo-core <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-wcs2_0-eo-core ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wcs2_0-eo-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wcs2_0-eo-core/2.16-SNAPSHOT/gs-wcs2_0-eo-core-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wcs2_0-eo-core/2.16-SNAPSHOT/gs-wcs2_0-eo-core-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wcs2_0-eo-core/2.16-SNAPSHOT/gs-wcs2_0-eo-core-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wcs2_0-eo-core/2.16-SNAPSHOT/gs-wcs2_0-eo-core-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wcs2_0-eo-core/2.16-SNAPSHOT/gs-wcs2_0-eo-core-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Building Web Coverage Service 2.0 Earth Observation GUI extension 2.16-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wcs2_0-eo ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-wcs2_0-eo ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs2_0-eo ---
[INFO] Copying 3 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-wcs2_0-eo ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs2_0-eo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/test/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfigTest.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/test/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfigTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs2_0-eo ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs2_0.eo.web.WCSEOAdminPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.488 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.238 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-wcs2_0-eo ---
[INFO] Processed 4 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.936 s]
[INFO] Core Platform Module ............................... SUCCESS [ 31.943 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 27.025 s]
[INFO] Main Module ........................................ SUCCESS [02:34 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.292 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:06 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:12 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.194 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.600 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 22.390 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.266 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:39 min]
[INFO] Web Feature Service Module ......................... FAILURE [02:24 min]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 23.404 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:48 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 20.418 s]
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.185 s]
[INFO] Core UI Module ..................................... SUCCESS [01:48 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.125 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SUCCESS [ 12.480 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.127 s]
[INFO] Printing Module .................................... SUCCESS [ 11.937 s]
[INFO] Community Space .................................... SUCCESS [ 0.137 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.120 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.043 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.624 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.442 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.133 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.083 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.586 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 7.029 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.172 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.102 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.991 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.138 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 1.955 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.028 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.834 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 19.934 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.819 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.189 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 13.369 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 14.934 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:03 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 19.556 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.126 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.091 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.361 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.969 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 13.064 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.979 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15:19 min (Wall Clock)
[INFO] Finished at: 2019-02-09T12:29:05+00:00
[INFO] Final Memory: 368M/1244M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <https://build.geoserver.org/job/geoserver-java11/327/display/redirect&gt;
[...truncated 714.69 KB...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.365 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.385 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.271 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.814 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.975 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.631 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.542 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.872 s]
[INFO] Main Module ........................................ SUCCESS [01:38 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.165 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:44 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 46.532 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.654 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.506 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 17.953 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.086 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [04:20 min]
[INFO] Web Feature Service Module ......................... FAILURE [01:39 min]
[INFO] gs-rest ............................................ SUCCESS [ 15.338 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 13.782 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.123 s]
[INFO] Core UI Module ..................................... SUCCESS [01:14 min]
[INFO] Security UI Modules ................................ SUCCESS [ 0.095 s]
[INFO] REST UI Module ..................................... SUCCESS [ 9.085 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.112 s]
[INFO] Printing Module .................................... SUCCESS [ 9.371 s]
[INFO] Community Space .................................... SUCCESS [ 0.099 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.082 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.393 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.948 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.976 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.119 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.796 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.757 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.901 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.705 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.038 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.621 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.042 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.622 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.125 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.720 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.994 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.620 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.129 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.644 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.822 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.067 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.826 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.045 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.033 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.319 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.228 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.450 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.643 s]
[INFO] Total time: 11:04 min (Wall Clock)
[INFO] Finished at: 2019-02-09T12:48:40+00:00
[INFO] Final Memory: 383M/1297M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/328/display/redirect&gt;
