Hudson
February 14, 2019, 10:43am
1
See <https://build.geoserver.org/job/geoserver-java11/340/display/redirect> ;
[...truncated 1.81 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[28,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[29,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[30,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,11\] cannot access org.springframework
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/affine/jt-affine/1.1.7/jt-affine-1.1.7.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,27\] cannot access org.springframework.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,40\] import requires canonical name for <any>.cas.ServiceProperties
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[32,36\] cannot access org.springframework.security.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[32,40\] cannot access org.springframework.security.cas.web
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-ogr-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java>:\[5,1\] cannot access org.geoserver.wps.hz
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geotools/xsd/gt-xsd-core/22-SNAPSHOT/gt-xsd-core-22-SNAPSHOT.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[30,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[30,41\] cannot find symbol
[ERROR] symbol: class DisposableBean
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[31,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.wps.hz.HazelcastLoader
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[34,25\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[37,13\] cannot find symbol
[ERROR] symbol: class HazelcastInstance
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[45,28\] cannot find symbol
[ERROR] symbol: class ResourceStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[45,56\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[67,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[77,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[86,40\] cannot find symbol
[ERROR] symbol: class Config
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[118,34\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[69,8\] cannot access org.geoserver.wps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[69,42\] cannot find symbol
[ERROR] symbol: class FilterVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[119,25\] cannot find symbol
[ERROR] symbol: class ExcludeFilter
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[124,25\] cannot find symbol
[ERROR] symbol: class IncludeFilter
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[130,25\] cannot find symbol
[ERROR] symbol: class And
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[139,25\] cannot find symbol
[ERROR] symbol: class Id
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[148,25\] cannot find symbol
[ERROR] symbol: class Not
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[153,25\] cannot find symbol
[ERROR] symbol: class Or
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[162,25\] cannot find symbol
[ERROR] symbol: class PropertyIsBetween
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[169,36\] cannot find symbol
[ERROR] symbol: class Expression
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[183,25\] cannot find symbol
[ERROR] symbol: class PropertyIsEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[189,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNotEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[195,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[203,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[211,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[219,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[227,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLike
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[238,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNull
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[244,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNil
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[250,25\] cannot find symbol
[ERROR] symbol: class BBOX
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[255,25\] cannot find symbol
[ERROR] symbol: class Beyond
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[260,25\] cannot find symbol
[ERROR] symbol: class Contains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[265,25\] cannot find symbol
[ERROR] symbol: class Crosses
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[270,25\] cannot find symbol
[ERROR] symbol: class Disjoint
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[275,25\] cannot find symbol
[ERROR] symbol: class DWithin
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[280,25\] cannot find symbol
[ERROR] symbol: class Equals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[285,25\] cannot find symbol
[ERROR] symbol: class Intersects
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[290,25\] cannot find symbol
[ERROR] symbol: class Overlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[295,25\] cannot find symbol
[ERROR] symbol: class Touches
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[300,25\] cannot find symbol
[ERROR] symbol: class Within
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[305,25\] cannot find symbol
[ERROR] symbol: class After
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[313,25\] cannot find symbol
[ERROR] symbol: class AnyInteracts
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[318,25\] cannot find symbol
[ERROR] symbol: class Before
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[326,25\] cannot find symbol
[ERROR] symbol: class Begins
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[331,25\] cannot find symbol
[ERROR] symbol: class BegunBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[336,25\] cannot find symbol
[ERROR] symbol: class During
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[341,25\] cannot find symbol
[ERROR] symbol: class EndedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[346,25\] cannot find symbol
[ERROR] symbol: class Ends
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[351,25\] cannot find symbol
[ERROR] symbol: class Meets
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[356,25\] cannot find symbol
[ERROR] symbol: class MetBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[361,25\] cannot find symbol
[ERROR] symbol: class OverlappedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[366,25\] cannot find symbol
[ERROR] symbol: class TContains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[371,25\] cannot find symbol
[ERROR] symbol: class TEquals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[377,25\] cannot find symbol
[ERROR] symbol: class TOverlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[78,35\] cannot find symbol
[ERROR] symbol: class BinaryComparisonOperator
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria.PropertyComparable
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[95,35\] cannot find symbol
[ERROR] symbol: class BinaryTemporalOperator
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-css
Hudson
February 14, 2019, 11:24am
2
See <https://build.geoserver.org/job/geoserver-java11/341/display/redirect> ;
[...truncated 1.38 MB...]
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Feb 14, 2019 11:24:23 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
at jdk.internal.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 25.803 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.146 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> ;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.740 s]
[INFO] Core Platform Module ............................... SUCCESS [ 32.230 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 20.394 s]
[INFO] Main Module ........................................ SUCCESS [02:19 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.336 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:27 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:10 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.005 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.549 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 29.115 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.376 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [06:02 min]
[INFO] Web Feature Service Module ......................... SUCCESS [03:08 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:18 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 45.644 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.572 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:49 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:25 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 26.361 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 33.372 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 18.132 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.185 s]
[INFO] Core UI Module ..................................... SUCCESS [02:19 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 44.855 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:06 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 19.832 s]
[INFO] Demos Module ....................................... SUCCESS [ 34.254 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.371 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.257 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:30 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:28 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.428 s]
[INFO] REST UI Module ..................................... SUCCESS [ 18.204 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.161 s]
[INFO] Printing Module .................................... SUCCESS [ 16.455 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.150 s]
[INFO] Community Space .................................... SUCCESS [ 0.144 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.081 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:20 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 17.187 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 15.784 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 18.351 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.078 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.069 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.924 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.944 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 13.415 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.104 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.494 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.093 s]
[INFO] OGR CORE ........................................... SUCCESS [ 6.543 s]
[INFO] OGR WFS ............................................ SUCCESS [ 14.811 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.043 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:27 min]
[INFO] Excel Output Format ................................ SUCCESS [ 21.898 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.218 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.147 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.788 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 22.707 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 24.865 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.753 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.204 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 34.447 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.127 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 9.748 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.151 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.490 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 30.576 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 34.051 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.817 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.154 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 14.477 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 13.984 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 47.106 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.973 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.078 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 23.209 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.088 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 22.901 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.587 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 15.132 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.346 s]
[INFO] Importer Core Module ............................... SUCCESS [01:10 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:14 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 31.007 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 26.840 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 22.726 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 30.976 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:00 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 24.579 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.960 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.723 s]
[INFO] REST SLD service ................................... SUCCESS [ 27.146 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 32.422 s]
[INFO] GeoFence Server .................................... SUCCESS [ 47.251 s]
[INFO] BUILD FAILURE
[INFO] Total time: 31:20 min (Wall Clock)
[INFO] Finished at: 2019-02-14T11:24:28+00:00
[INFO] Final Memory: 476M/1541M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-core/target/surefire-reports> ; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
Hudson
February 14, 2019, 4:40pm
3
See <https://build.geoserver.org/job/geoserver-java11/342/display/redirect?page=changes> ;
Changes:
[niels] GEOS-9096 jdbcconfig/hazelcast thread safety fixes
[...truncated 1.53 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionMockData.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ConnectionUsageMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ConnectionUsageMockData.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ConnectionUsageMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XPathPredicateTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XPathPredicateTest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XPathPredicateTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/Gml32LinksTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/Gml32LinksTest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/Gml32LinksTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupMockData.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineTest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MeasureTypeBindingTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MeasureTypeBindingTest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MeasureTypeBindingTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecuredFeatureChainingTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecuredFeatureChainingTest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecuredFeatureChainingTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsSupportMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsSupportMockData.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsSupportMockData.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[5,1\] cannot access org.geoserver.geofence.rest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/mosaic/jt-mosaic/1.1.7/jt-mosaic-1.1.7.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java>:\[5,1\] cannot access org.geoserver.geofence.internal
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java>:\[5,1\] cannot access org.geoserver.geofence.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[29,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[29,51\] cannot find symbol
[ERROR] symbol: class GeofenceBaseTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[31,15\] cannot find symbol
[ERROR] symbol: class AdminRulesRestController
[ERROR] location: class org.geoserver.geofence.rest.AdminRulesRestControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[33,15\] cannot find symbol
[ERROR] symbol: class AdminRuleAdminService
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[257,13\] cannot find symbol
[ERROR] symbol: class ResponseEntity
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[257,28\] cannot find symbol
[ERROR] symbol: class JaxbAdminRuleList
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[257,55\] cannot find symbol
[ERROR] symbol: class HttpStatus
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[271,42\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[271,57\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[280,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[280,57\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[280,72\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[301,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java>:\[21,8\] cannot access org.geoserver.geofence
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java>:\[23,13\] cannot find symbol
[ERROR] symbol: class MultiPolygonAdapter
[ERROR] location: class org.geoserver.geofence.rest.MultiPolygonAdapterTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[34,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[34,47\] cannot find symbol
[ERROR] symbol: class AbstractSecurityServiceTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[36,15\] cannot find symbol
[ERROR] symbol: class GeoServerRoleService
[ERROR] location: class org.geoserver.geofence.internal.InternalUserResolverTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[38,15\] cannot find symbol
[ERROR] symbol: class GeoServerRoleStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[41,28\] cannot find symbol
[ERROR] symbol: class SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[75,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[101,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[120,13\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[121,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java>:\[122,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java>:\[23,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java>:\[23,45\] cannot find symbol
[ERROR] symbol: class GeoServerWicketTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java>:\[26,31\] cannot find symbol
[ERROR] location: class org.geoserver.geofence.web.GeofenceRulesModelTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java>:\[93,36\] cannot find symbol
[ERROR] symbol: class GeofenceRulesModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[7,18\] cannot access org.junit
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[7,24\] import requires canonical name for <any>.Assert
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[9,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[9,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[9,25\] import requires canonical name for <any>.logging.Level
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[10,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[10,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[10,42\] import requires canonical name for <any>.ajax.markup.html.AjaxLink
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[11,25\] cannot access org.apache.wicket.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[11,30\] cannot access org.apache.wicket.util.tester
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[11,37\] import requires canonical name for <any>.FormTester
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[12,21\] cannot access org.geoserver.data
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[12,26\] cannot access org.geoserver.data.test
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[12,31\] import requires canonical name for <any>.SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[13,30\] cannot access org.geoserver.geofence.config
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[13,37\] package org.geoserver.geofence.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[14,30\] cannot access org.geoserver.geofence.services
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[14,39\] cannot access org.geoserver.geofence.services.dto
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[14,43\] import requires canonical name for <any>.ShortAdminRule
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[15,21\] cannot access org.geoserver.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[15,25\] package org.geoserver.web does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[16,25\] cannot access org.geoserver.web.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[16,32\] package org.geoserver.web.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[17,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[18,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[20,50\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[22,12\] cannot find symbol
[ERROR] symbol: class GeoFencePropertyPlaceholderConfigurer
[ERROR] location: class org.geoserver.geofence.web.GeofenceServerAdminPageTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[25,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java>:\[36,31\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-ogr-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/test/java/org/geoserver/wps/ogr/WPSOgrTest.java>:\[5,1\] cannot access org.geoserver.wps.ogr
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/shadedrelief/jt-shadedrelief/1.1.7/jt-shadedrelief-1.1.7.jar>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-csw: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/test/java/org/geoserver/wfs/web/CSWAdminPageTest.java>:\[6,1\] cannot access org.geoserver.wfs.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/com/thoughtworks/xstream/xstream/1.4.10/xstream-1.4.10.jar>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-inspire: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-ysld
Not sending mail to unregistered user niels@anonymised.com
Hudson
February 15, 2019, 11:56am
4
