Hudson
February 16, 2019, 12:35pm
1
See <https://build.geoserver.org/job/geoserver-java11/344/display/redirect> ;
[...truncated 1.28 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/jasypt/jasypt-springsecurity3/1.9.2/jasypt-springsecurity3-1.9.2.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/OracleImportTest.java>:\[6,1\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/format/KMLFileFormatTest.java>:\[6,1\] cannot access org.geoserver.importer.format
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/transform/GdalTransformTest.java>:\[5,1\] cannot access org.geoserver.importer.transform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[19,17\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[22,17\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[53,17\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[53,51\] cannot find symbol
[ERROR] symbol: class GeoServerSystemTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[22,45\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] location: class org.geoserver.importer.ImporterDbTestBase
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[40,32\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[40,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[44,48\] cannot find symbol
[ERROR] symbol: class Statement
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[44,69\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[46,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[46,48\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[46,69\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[51,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[64,50\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestBase.java>:\[93,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[25,12\] cannot find symbol
[ERROR] symbol: class SystemTestData
[ERROR] location: class org.geoserver.importer.ImporterDbTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[33,15\] cannot find symbol
[ERROR] symbol: class Connection
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[37,15\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[37,48\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[41,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[41,57\] cannot find symbol
[ERROR] symbol: class SQLException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDbTestSupport.java>:\[45,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[55,12\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.importer.ImporterTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[57,18\] cannot find symbol
[ERROR] symbol: class Set
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[68,15\] cannot find symbol
[ERROR] symbol: class Importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[70,5\] cannot find symbol
[ERROR] symbol: class GeoServerDataDirectory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[73,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[101,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[107,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[120,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[146,15\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[150,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[154,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[154,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[158,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[162,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[162,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[162,55\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[192,15\] cannot find symbol
[ERROR] symbol: class DataStoreInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[262,15\] cannot find symbol
[ERROR] symbol: class MockHttpServletResponse
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[267,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[268,20\] cannot find symbol
[ERROR] symbol: class UnsupportedEncodingException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[8,18\] cannot access org.junit
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[8,24\] import requires canonical name for <any>.Assert
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[9,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[10,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[11,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[13,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[13,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[13,15\] import requires canonical name for <any>.File
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[14,12\] cannot access java.sql
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[15,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[15,17\] cannot find symbol
[ERROR] symbol: class Calendar
[ERROR] location: package java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[20,21\] cannot access org.geoserver.catalog
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[20,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[22,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[23,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[24,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[25,40\] cannot find symbol
[ERROR] symbol: class DateFormatTransform
[ERROR] location: package org.geoserver.importer.transform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[26,40\] cannot find symbol
[ERROR] symbol: class IntegerFieldToDateTransform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[27,40\] cannot find symbol
[ERROR] symbol: class NumberFormatTransform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[28,40\] cannot find symbol
[ERROR] symbol: class ReprojectTransform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[29,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[29,20\] cannot access org.geotools.feature
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[29,28\] import requires canonical name for <any>.FeatureIterator
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[30,20\] cannot access org.geotools.referencing
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[30,32\] package org.geotools.referencing does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[31,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[32,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[33,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[34,11\] cannot access org.opengis
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[34,19\] cannot access org.opengis.feature
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[34,34\] import requires canonical name for <any>.simple.SimpleFeature
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[35,27\] cannot access org.opengis.feature.simple
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[35,34\] package org.opengis.feature.simple does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImportTransformTest.java>:\[39,5\] cannot find symbol
[ERROR] location: class org.geoserver.importer.ImportTransformTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/SQLServerImportTest.java>:\[9,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/SQLServerImportTest.java>:\[11,2\] cannot find symbol
[ERROR] symbol: class Ignore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[8,18\] cannot access org.hamcrest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[8,27\] import requires canonical name for <any>.CoreMatchers
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[9,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[10,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[11,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[12,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[12,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[13,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterDataTest.java>:\[13,1\] static import only from classes and interfaces
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-csw: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
Hudson
February 16, 2019, 12:58pm
2
See <https://build.geoserver.org/job/geoserver-java11/345/display/redirect> ;
[...truncated 1.76 MB...]
[ERROR] location: class org.geoserver.wcs.responses.NetCDFCoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>:\[128,52\] cannot find symbol
[ERROR] symbol: class OutputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>:\[128,80\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>:\[147,39\] cannot find symbol
[ERROR] symbol: class ApplicationContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>:\[147,85\] cannot find symbol
[ERROR] symbol: class BeansException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>:\[152,31\] cannot find symbol
[ERROR] symbol: class GridCoverage2D
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java>:\[30,13\] cannot find symbol
[ERROR] symbol: class GranuleStack
[ERROR] location: interface org.geoserver.wcs.responses.NetCDFEncoderFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[11,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[13,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[14,21\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/si/uom/si-quantity/0.7.1/si-quantity-0.7.1.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[14,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[15,37\] package org.geoserver.wcs2_0.response does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[16,28\] cannot access org.geoserver.wcs2_0.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[16,33\] package org.geoserver.wcs2_0.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[19,8\] cannot access ucar
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[19,12\] cannot access ucar.ma2
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[19,16\] import requires canonical name for <any>.InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java>:\[43,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>:\[33,38\] cannot find symbol
[ERROR] symbol: class InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[13,8\] cannot access javax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[13,13\] cannot access javax.measure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[13,21\] import requires canonical name for <any>.Unit
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[14,21\] cannot access javax.measure.format
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[14,28\] package javax.measure.format does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[15,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[15,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[15,25\] import requires canonical name for <any>.Component
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[16,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[16,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[17,30\] cannot access org.apache.wicket.ajax.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[17,35\] package org.apache.wicket.ajax.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[18,25\] cannot access org.apache.wicket.extensions
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[18,36\] cannot access org.apache.wicket.extensions.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[18,66\] import requires canonical name for <any>.markup.html.autocomplete.AutoCompleteTextField
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[19,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[19,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[19,43\] import requires canonical name for <any>.basic.Label
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[20,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[20,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>:\[21,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java>:\[5,1\] cannot access org.geoserver.geofence.server.rest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/scale2/jt-scale2/1.1.7/jt-scale2-1.1.7.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java>:\[5,1\] cannot access org.geoserver.geofence.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java>:\[5,1\] cannot access org.geoserver.geofence.internal
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>:\[24,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>:\[24,46\] cannot find symbol
[ERROR] symbol: class GeoServerSecuredPage
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[19,8\] cannot access org.geoserver.geofence
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[19,46\] cannot find symbol
[ERROR] symbol: class GeoServerDataProvider
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[19,68\] cannot find symbol
[ERROR] symbol: class ShortAdminRule
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>:\[30,13\] cannot find symbol
[ERROR] symbol: class GeoServerTablePanel
[ERROR] location: class org.geoserver.geofence.web.GeofenceServerAdminPage
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>:\[30,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>:\[32,13\] cannot find symbol
[ERROR] symbol: class AjaxLink
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>:\[32,22\] cannot find symbol
[ERROR] symbol: class Object
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[49,25\] cannot find symbol
[ERROR] symbol: class Property
[ERROR] location: class org.geoserver.geofence.web.GeofenceAdminRulesModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[49,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[52,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[52,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[55,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[55,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[58,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[58,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[61,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[61,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[64,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[64,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[66,20\] cannot find symbol
[ERROR] symbol: class AdminRuleAdminService
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[70,15\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[70,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[78,56\] cannot find symbol
[ERROR] symbol: class SortParam
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[78,15\] cannot find symbol
[ERROR] symbol: class Comparator
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[78,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[83,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[89,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[89,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[89,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[94,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[94,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[98,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[119,24\] cannot find symbol
[ERROR] symbol: class Collection
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[119,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[126,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[130,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[139,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[143,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[152,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[152,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[159,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[177,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[184,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[184,62\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
Hudson
February 16, 2019, 7:42pm
3
See <https://build.geoserver.org/job/geoserver-java11/346/display/redirect> ;
[...truncated 1.38 MB...]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-sec-cas >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-sec-cas ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/pom.xml> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar> ;
Feb 16, 2019 7:42:03 PM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
at jdk.internal.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.777 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.519 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar> ;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> ; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> ;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.463 s]
[INFO] Core Platform Module ............................... SUCCESS [ 30.495 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 24.592 s]
[INFO] Main Module ........................................ SUCCESS [02:33 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.230 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:27 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:08 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 11.471 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.171 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 33.464 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 34.336 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [06:04 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:56 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:31 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 47.402 s]
[INFO] gs-rest ............................................ SUCCESS [ 25.022 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:52 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:49 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.815 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 27.956 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 17.613 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.131 s]
[INFO] Core UI Module ..................................... SUCCESS [01:59 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 46.506 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.477 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 21.147 s]
[INFO] Demos Module ....................................... SUCCESS [ 29.181 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.983 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.175 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:43 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:28 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.148 s]
[INFO] REST UI Module ..................................... SUCCESS [ 17.280 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.120 s]
[INFO] Printing Module .................................... SUCCESS [ 20.527 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.964 s]
[INFO] Community Space .................................... SUCCESS [ 0.095 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.150 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:27 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 17.909 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 20.196 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.661 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.420 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.458 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.266 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.434 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.461 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.931 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.102 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.102 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.900 s]
[INFO] OGR WFS ............................................ SUCCESS [ 15.486 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.065 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:25 min]
[INFO] Excel Output Format ................................ SUCCESS [ 21.214 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.325 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.364 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.985 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 22.483 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 23.159 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.578 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.299 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 22.706 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.246 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.809 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.149 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.930 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 34.741 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 28.958 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.336 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.216 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.681 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 16.900 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.583 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.091 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.087 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 20.707 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.082 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.869 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.681 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 13.124 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.209 s]
[INFO] Importer Core Module ............................... SUCCESS [ 54.446 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 38.948 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.877 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.360 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 25.203 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 25.637 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.147 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 21.206 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 11.618 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.958 s]
[INFO] REST SLD service ................................... SUCCESS [ 27.116 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 29.722 s]
[INFO] GeoFence Server .................................... SUCCESS [ 37.702 s]
[INFO] BUILD FAILURE
[INFO] Total time: 29:03 min (Wall Clock)
[INFO] Finished at: 2019-02-16T19:42:05+00:00
[INFO] Final Memory: 420M/1410M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-core/target/surefire-reports> ; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
Hudson
February 17, 2019, 9:01am
4
See <https://build.geoserver.org/job/geoserver-java11/347/display/redirect> ;
[...truncated 1.98 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[16,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geotools/gt-app-schema-resolver/22-SNAPSHOT/gt-app-schema-resolver-22-SNAPSHOT.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[16,47\] cannot find symbol
[ERROR] symbol: class FilterConfigException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[20,37\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.security.cas.CasFilterConfigException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[20,53\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[24,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[24,53\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[24,69\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[28,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[29,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[30,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[32,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[33,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>:\[15,8\] cannot access org.geoserver.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>:\[15,52\] cannot find symbol
[ERROR] symbol: class PreAuthenticatedUserNameFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[28,17\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[30,15\] cannot find symbol
[ERROR] symbol: class URL
[ERROR] location: class org.geoserver.security.cas.CasAuthenticationHelper
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[34,15\] cannot find symbol
[ERROR] symbol: class HttpCookie
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[41,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[51,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[67,35\] cannot find symbol
[ERROR] symbol: class HttpURLConnection
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[67,66\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[78,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[78,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[95,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[95,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[95,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[108,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[108,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[108,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[115,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[115,70\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[116,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[132,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[136,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[145,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[163,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[177,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[192,47\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[202,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[202,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[238,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[238,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[238,61\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[28,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[28,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[28,67\] cannot find symbol
[ERROR] symbol: class BeanNameAware
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[31,5\] cannot find symbol
[ERROR] symbol: class ProxyGrantingTicketStorage
[ERROR] location: class org.geoserver.security.cas.ProxyGrantingTicketCallbackFilter
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[33,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[47,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[47,56\] cannot find symbol
[ERROR] symbol: class ServletException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[54,26\] cannot find symbol
[ERROR] symbol: class ServletRequest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[54,50\] cannot find symbol
[ERROR] symbol: class ServletResponse
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[54,76\] cannot find symbol
[ERROR] symbol: class FilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[55,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[55,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[9,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[9,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[9,15\] import requires canonical name for <any>.IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[10,12\] cannot access java.net
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[11,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[11,17\] cannot access java.util.logging
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[11,25\] import requires canonical name for <any>.Level
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[12,8\] cannot access javax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[12,13\] cannot access javax.servlet
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[12,21\] import requires canonical name for <any>.FilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[13,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[14,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[15,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[16,21\] cannot access javax.servlet.http
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[16,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[17,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[18,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[19,21\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[19,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[20,30\] cannot find symbol
[ERROR] symbol: class LogoutFilterChain
[ERROR] location: package org.geoserver.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[21,30\] cannot access org.geoserver.security.config
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[21,37\] package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[22,30\] cannot access org.geoserver.security.filter
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[22,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[23,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[24,11\] cannot access org.jasig
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[24,17\] cannot access org.jasig.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[24,42\] import requires canonical name for <any>.client.configuration.ConfigurationKeys
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[25,21\] cannot access org.jasig.cas.client
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[25,28\] cannot access org.jasig.cas.client.proxy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[25,34\] import requires canonical name for <any>.ProxyGrantingTicketStorage
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[26,28\] cannot access org.jasig.cas.client.session
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[26,36\] package org.jasig.cas.client.session does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[27,28\] cannot access org.jasig.cas.client.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[27,33\] package org.jasig.cas.client.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[28,28\] cannot access org.jasig.cas.client.validation
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[28,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[29,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[30,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,11\] cannot access org.springframework
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,27\] cannot access org.springframework.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,40\] import requires canonical name for <any>.cas.ServiceProperties
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[32,36\] cannot access org.springframework.security.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[32,40\] cannot access org.springframework.security.cas.web
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java;> ; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-sldservice
Hudson
February 17, 2019, 9:47am
5
