See <https://build.geoserver.org/job/geoserver-java11/364/display/redirect>
[...truncated 1.48 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.182 s]
[INFO] Core Platform Module ............................... SUCCESS [ 24.167 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 17.154 s]
[INFO] Main Module ........................................ SUCCESS [01:50 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.141 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:06 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.086 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 11.023 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.431 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.659 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 33.736 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:48 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:36 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:24 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 42.157 s]
[INFO] gs-rest ............................................ SUCCESS [ 21.825 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:51 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:48 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 25.932 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 28.851 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 16.175 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.122 s]
[INFO] Core UI Module ..................................... SUCCESS [01:48 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 57.317 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 58.086 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 14.368 s]
[INFO] Demos Module ....................................... SUCCESS [ 38.166 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 22.074 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.096 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:21 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:32 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.511 s]
[INFO] REST UI Module ..................................... SUCCESS [ 19.981 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.099 s]
[INFO] Printing Module .................................... SUCCESS [ 12.179 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.891 s]
[INFO] Community Space .................................... SUCCESS [ 0.059 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.063 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.324 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.442 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.287 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.157 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.867 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.262 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.935 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 15.793 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.519 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.862 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.064 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.135 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.013 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.046 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:42 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.178 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.664 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.787 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.342 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.765 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 23.917 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 16.867 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 35.489 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.087 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.036 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.086 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 30.239 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.139 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 12.026 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.185 s]
[INFO] GeoServer CAS Security Web Module .................. FAILURE [ 0.514 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 29.077 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 44.001 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 19.074 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.132 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 15.443 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 14.165 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 49.254 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.345 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.068 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 19.761 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.854 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.062 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.723 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 19.100 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 15.636 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.242 s]
[INFO] Importer Core Module ............................... SUCCESS [01:05 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.955 s]
[INFO] Importer Berkley DB Persistence Module ............. FAILURE [ 3.388 s]
[INFO] Importer Web UI Module ............................. FAILURE [ 0.603 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 21.195 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 29.093 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:09 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 24.683 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 14.836 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.742 s]
[INFO] REST SLD service ................................... SUCCESS [ 29.747 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 32.979 s]
[INFO] GeoFence Server .................................... SUCCESS [01:00 min]
[INFO] BUILD FAILURE
[INFO] Total time: 29:17 min (Wall Clock)
[INFO] Finished at: 2019-02-20T03:05:08+00:00
[INFO] Final Memory: 592M/1412M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBindingTest.java>:\[6,1\] cannot access org.geoserver.importer.bdb
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geotools/xsd/gt-xsd-wmts/22-SNAPSHOT/gt-xsd-wmts-22-SNAPSHOT.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java>:\[29,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java>:\[29,51\] cannot find symbol
[ERROR] symbol: class ImporterTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java>:\[32,52\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] location: class org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java>:\[71,18\] cannot find symbol
[ERROR] symbol: class DatabaseEntry
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java>:\[71,5\] cannot find symbol
[ERROR] symbol: class Document
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java>:\[71,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/XStreamInfoSerialBindingTest.java>:\[78,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[33,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[33,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[32,2\] cannot find symbol
[ERROR] symbol: class RunWith
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[36,19\] cannot find symbol
[ERROR] symbol: class Collection
[ERROR] location: class org.geoserver.importer.bdb.BDBImportStoreTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[44,5\] cannot find symbol
[ERROR] symbol: class BDBImportStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[45,5\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[47,13\] cannot find symbol
[ERROR] symbol: class BindingType
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[49,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[94,48\] cannot find symbol
[ERROR] symbol: class ImportContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[205,39\] cannot find symbol
[ERROR] symbol: class ImportVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/BDBImportStoreTest.java>:\[213,27\] cannot find symbol
[ERROR] location: class org.geoserver.importer.bdb.BDBImportStoreTest.SearchingVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/CountingVisitor.java>:\[11,1\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/CountingVisitor.java>:\[11,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/CountingVisitor.java>:\[15,23\] cannot find symbol
[ERROR] location: class org.geoserver.importer.bdb.CountingVisitor
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-bdb
