See <https://build.geoserver.org/job/geoserver-java11/371/display/redirect>
[...truncated 1.49 MB...]
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Feb 23, 2019 11:40:14 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
at jdk.internal.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.493 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.481 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.581 s]
[INFO] Core Platform Module ............................... SUCCESS [ 31.633 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 26.383 s]
[INFO] Main Module ........................................ SUCCESS [02:40 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.259 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:54 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [ 57.248 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 10.335 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.124 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 33.818 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 39.983 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:32 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:54 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:29 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 27.753 s]
[INFO] gs-rest ............................................ SUCCESS [ 23.163 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:07 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:41 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 19.499 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 19.670 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.555 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.326 s]
[INFO] Core UI Module ..................................... SUCCESS [02:01 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.082 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.245 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 25.446 s]
[INFO] Demos Module ....................................... SUCCESS [ 19.806 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.490 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.115 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:38 min]
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SUCCESS [ 10.900 s]
[INFO] REST UI Module ..................................... SUCCESS [ 9.300 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.124 s]
[INFO] Printing Module .................................... SUCCESS [ 18.988 s]
[INFO] Community Space .................................... SUCCESS [ 0.123 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.170 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:26 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 17.935 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 17.946 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.331 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.028 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.884 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.428 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.514 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.921 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.862 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.709 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.090 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.306 s]
[INFO] OGR WFS ............................................ SUCCESS [ 14.933 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.077 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:19 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.218 s]
[INFO] Excel Output Format ................................ SUCCESS [ 20.436 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.512 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.345 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.309 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 23.740 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.956 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.610 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 21.802 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.364 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.216 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.318 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.110 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.290 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.053 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.429 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.589 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 29.500 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.983 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.121 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 14.373 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.498 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 37.293 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.727 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.113 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 19.111 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.397 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.073 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.641 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.690 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.996 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.110 s]
[INFO] Importer Core Module ............................... SUCCESS [ 54.156 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 37.287 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.313 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.510 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 23.957 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 18.599 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.073 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 16.567 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 11.413 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 3.188 s]
[INFO] REST SLD service ................................... SUCCESS [ 19.834 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 25.364 s]
[INFO] GeoFence Server .................................... SUCCESS [ 35.939 s]
[INFO] BUILD FAILURE
[INFO] Total time: 27:03 min (Wall Clock)
[INFO] Finished at: 2019-02-23T11:40:16+00:00
[INFO] Final Memory: 453M/1463M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-sec-jdbc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/security/jdbc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-sec-jdbc
