See <https://build.geoserver.org/job/geoserver-java11/403/display/redirect>
[...truncated 2.25 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/web/WmsRepresentativeOperationPanel.java>:\[20,55\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] location: class org.geoserver.qos.web.WmsRepresentativeOperationPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/xml/QosRepresentativeOperation.java>:\[18,18\] cannot find symbol
[ERROR] symbol: class QualityOfServiceStatement
[ERROR] location: class org.geoserver.qos.xml.QosRepresentativeOperation
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/xml/QosRepresentativeOperation.java>:\[41,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/xml/QosRepresentativeOperation.java>:\[46,18\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/web/QosWMSOperationsListPanel.java>:\[23,15\] cannot find symbol
[ERROR] location: class org.geoserver.qos.web.QosWMSOperationsListPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/web/QosWMSOperationsListPanel.java>:\[25,49\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/web/QosWMSOperationsListPanel.java>:\[65,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/web/LimitedConstraintsPanel.java>:\[9,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/web/LimitedConstraintsPanel.java>:\[10,31\] package org.apache.wicket.model does not exist
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-ogr: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/web-ogr/src/main/java/org/geoserver/ogr/OGRDataStorePanel.java>:\[6,1\] cannot access org.geoserver.ogr
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geotools/ogc/org.w3.xlink/22-SNAPSHOT/org.w3.xlink-22-SNAPSHOT.jar>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-notification: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationListener.java>:\[6,1\] cannot access org.geoserver.notification
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/net/sf/ezmorph/ezmorph/1.0.6/ezmorph-1.0.6.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[11,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[11,42\] cannot find symbol
[ERROR] symbol: class Notification
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[13,13\] cannot find symbol
[ERROR] symbol: class Type
[ERROR] location: class org.geoserver.notification.NotificationImpl
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[15,13\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[17,13\] cannot find symbol
[ERROR] symbol: class Action
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[19,13\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[19,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[19,25\] cannot find symbol
[ERROR] symbol: class Object
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[21,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[23,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[26,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[27,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[28,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[29,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[30,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[30,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[30,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[31,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[41,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[46,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[51,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[56,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[61,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[61,16\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[61,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationImpl.java>:\[66,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessorFactory.java>:\[13,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessorFactory.java>:\[13,61\] cannot find symbol
[ERROR] symbol: class PropertyAccessorFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>:\[15,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>:\[15,54\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessorFactory.java>:\[19,13\] cannot find symbol
[ERROR] symbol: class Class
[ERROR] location: class org.geoserver.notification.NotificationPropertyAccessorFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessorFactory.java>:\[19,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessorFactory.java>:\[19,59\] cannot find symbol
[ERROR] symbol: class Hints
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessorFactory.java>:\[18,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>:\[17,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>:\[20,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>:\[25,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>:\[37,63\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[8,8\] cannot access com
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[8,11\] cannot access com.thoughtworks
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[8,32\] import requires canonical name for <any>.xstream.XStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[9,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[9,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[9,17\] import requires canonical name for <any>.List
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[10,17\] cannot access java.util.logging
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[12,21\] cannot access org.geoserver.config
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[12,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[13,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[14,34\] cannot access org.geoserver.notification.common
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[14,41\] package org.geoserver.notification.common does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[15,41\] package org.geoserver.notification.common does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[16,21\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[16,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[17,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[18,30\] cannot access org.geoserver.platform.resource
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[18,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[19,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[20,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[21,21\] cannot access org.geoserver.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[21,26\] package org.geoserver.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[22,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[22,20\] cannot access org.geotools.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[22,33\] import requires canonical name for <any>.logging.Logging
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[24,45\] cannot find symbol
[ERROR] symbol: class GeoServerInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[31,13\] cannot find symbol
[ERROR] symbol: class GeoServerResourceLoader
[ERROR] location: class org.geoserver.notification.NotifierInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[33,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[37,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[64,56\] cannot find symbol
[ERROR] symbol: class XStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotifierInitializer.java>:\[64,13\] cannot find symbol
[ERROR] symbol: class NotificationConfiguration
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[10,8\] cannot access net
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[10,11\] cannot access net.opengis
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[10,23\] import requires canonical name for <any>.wfs.TransactionResponseType
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[11,19\] cannot access net.opengis.wfs
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[11,23\] package net.opengis.wfs does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[12,21\] cannot access org.geoserver.catalog
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[13,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[14,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[15,29\] cannot access org.geoserver.catalog.impl
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[15,34\] package org.geoserver.catalog.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[16,41\] package org.geoserver.notification.common does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[17,41\] package org.geoserver.notification.common does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[18,21\] cannot access org.geoserver.wfs
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[18,25\] package org.geoserver.wfs does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[19,25\] package org.geoserver.wfs does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[20,25\] package org.geoserver.wfs does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[21,20\] cannot access org.geotools.geometry
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[21,29\] cannot access org.geotools.geometry.jts
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[21,33\] import requires canonical name for <any>.ReferencedEnvelope
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[22,11\] cannot access org.opengis
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[22,19\] cannot access org.opengis.feature
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[22,32\] import requires canonical name for <any>.type.FeatureType
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[23,11\] cannot access org.springframework
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[23,27\] cannot access org.springframework.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[23,41\] import requires canonical name for <any>.core.Authentication
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[24,36\] cannot access org.springframework.security.core
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[24,41\] cannot access org.springframework.security.core.context
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[24,49\] import requires canonical name for <any>.SecurityContextHolder
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationTransactionListener.java>:\[26,54\] cannot find symbol
[ERROR] symbol: class NotificationListener
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-taskmanager-s3
