See <https://build.geoserver.org/job/geoserver-java11/426/display/redirect>
[...truncated 1.44 MB...]
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.995 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.593 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.456 s]
[INFO] Main Module ........................................ SUCCESS [01:37 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.181 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:17 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 46.540 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.774 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.471 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 27.079 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.164 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:03 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:36 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 21.326 s]
[INFO] gs-rest ............................................ SUCCESS [ 17.022 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:09 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:01 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.568 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 15.473 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.609 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.187 s]
[INFO] Core UI Module ..................................... SUCCESS [02:05 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.267 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 50.485 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 19.002 s]
[INFO] Demos Module ....................................... SUCCESS [ 23.718 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.114 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.072 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:28 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:24 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 12.516 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.066 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.077 s]
[INFO] Printing Module .................................... SUCCESS [ 13.203 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 9.065 s]
[INFO] Community Space .................................... SUCCESS [ 0.059 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.064 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:13 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 19.857 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.953 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.898 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.858 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.671 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.288 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.351 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.259 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.497 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.363 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.049 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.164 s]
[INFO] OGR WFS ............................................ SUCCESS [ 11.824 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.056 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:29 min]
[INFO] OGR WPS ............................................ FAILURE [ 1.366 s]
[INFO] Excel Output Format ................................ SUCCESS [ 24.206 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.538 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.481 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.553 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 13.688 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 11.262 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.401 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 20.820 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.963 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.138 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 20.062 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 3.502 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Web Module .................. FAILURE [ 0.428 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 15.351 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 28.937 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.825 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.081 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.184 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 6.519 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.135 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 17.328 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.074 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.625 s]
[INFO] DXF WPS PPIO ....................................... FAILURE [ 0.703 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.073 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.803 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.244 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.121 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.136 s]
[INFO] Importer Core Module ............................... SUCCESS [ 55.655 s]
[INFO] Importer REST Api Module-ng ........................ FAILURE [ 3.136 s]
[INFO] Importer Berkley DB Persistence Module ............. FAILURE [ 0.691 s]
[INFO] Importer Web UI Module ............................. FAILURE [ 3.155 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.774 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.468 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 40.324 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 16.517 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 10.570 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.601 s]
[INFO] REST SLD service ................................... SUCCESS [ 24.483 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 21.843 s]
[INFO] GeoFence Server .................................... SUCCESS [ 57.859 s]
[INFO] BUILD FAILURE
[INFO] Total time: 24:26 min (Wall Clock)
[INFO] Finished at: 2019-03-16T11:03:16+00:00
[INFO] Final Memory: 434M/1176M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-ogr-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/test/java/org/geoserver/wps/ogr/WPSOgrTest.java>:\[5,1\] cannot access org.geoserver.wps.ogr
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/bandselect/jt-bandselect/1.1.7/jt-bandselect-1.1.7.jar>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>:\[6,1\] cannot access org.geoserver.wps.ppio
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/apache/commons/commons-text/1.4/commons-text-1.4.jar>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportTaskControllerTest.java>:\[6,1\] cannot access org.geoserver.importer.rest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/xalan/xalan/2.7.2/xalan-2.7.2.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/converters/ImportJSONIOTest.java>:\[6,1\] cannot access org.geoserver.importer.rest.converters
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[20,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[20,47\] cannot find symbol
[ERROR] symbol: class ImporterTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[22,38\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] location: class org.geoserver.importer.rest.ImportDataControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[29,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[36,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[42,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[51,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[19,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[30,17\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[30,52\] cannot find symbol
[ERROR] symbol: class DataTestCase
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[49,47\] cannot find symbol
[ERROR] symbol: class ParseException
[ERROR] location: class org.geoserver.importer.rest.DateFormatTransformTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[80,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[36,28\] cannot find symbol
[ERROR] symbol: class ImportTransform
[ERROR] location: class org.geoserver.importer.rest.TransformTestSupport
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java>:\[6,1\] cannot access org.geoserver.importer.bdb
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/warp/jt-warp/1.1.7/jt-warp-1.1.7.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[27,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[27,50\] cannot find symbol
[ERROR] symbol: class SerialBase
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[27,72\] cannot find symbol
[ERROR] symbol: class EntryBinding
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[29,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.importer.bdb.XStreamInfoSerialBinding<T>
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[31,19\] cannot find symbol
[ERROR] symbol: class XStreamPersister
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[37,19\] cannot find symbol
[ERROR] symbol: class Class
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[40,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[40,60\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[51,28\] cannot find symbol
[ERROR] symbol: class DatabaseEntry
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>:\[79,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>:\[15,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>:\[15,48\] cannot find symbol
[ERROR] symbol: class Converter
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>:\[17,31\] cannot find symbol
[ERROR] location: class org.geoserver.importer.bdb.CatalogObjectConverter
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>:\[22,28\] cannot find symbol
[ERROR] symbol: class HierarchicalStreamWriter
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>:\[22,61\] cannot find symbol
[ERROR] symbol: class MarshallingContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>:\[24,29\] cannot find symbol
[ERROR] symbol: class HierarchicalStreamReader
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>:\[24,62\] cannot find symbol
[ERROR] symbol: class UnmarshallingContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>:\[15,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>:\[15,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>:\[15,78\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>:\[18,28\] cannot find symbol
[ERROR] location: class org.geoserver.importer.bdb.SerialVersionSafeSerialBinding<T>
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>:\[31,36\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/test/java/org/geoserver/importer/web/ImportTaskTableTest.java>:\[6,1\] cannot access org.geoserver.importer.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/net/sf/geographiclib/GeographicLib-Java/1.49/GeographicLib-Java-1.49.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/test/java/org/geoserver/importer/web/AbstractDBPanelTest.java>:\[19,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/test/java/org/geoserver/importer/web/AbstractDBPanelTest.java>:\[19,42\] cannot find symbol
[ERROR] symbol: class GeoServerWicketUnitTestSupport
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java>:\[6,1\] cannot access org.geoserver.security.web.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geotools/ogc/net.opengis.wfs/22-SNAPSHOT/net.opengis.wfs-22-SNAPSHOT.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>:\[17,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>:\[18,17\] cannot find symbol
[ERROR] symbol: class AuthenticationFilterPanelInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>:\[18,47\] cannot find symbol
[ERROR] symbol: class CasAuthenticationFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>:\[18,78\] cannot find symbol
[ERROR] symbol: class CasAuthFilterPanel
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ogr-wps
