See <https://build.geoserver.org/job/geoserver-java11/513/display/redirect>
[...truncated 2.13 MB...]
[INFO] ColorMap ........................................... SUCCESS [ 1.212 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 1.361 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 1.410 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 0.547 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 1.283 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 1.064 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 0.996 s]
[INFO] DownloadProcess .................................... SUCCESS [ 2.011 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.029 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 1.683 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 0.405 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 2.470 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 1.587 s]
[INFO] Solr Module ........................................ SUCCESS [ 1.153 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 1.394 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 1.969 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 1.013 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 1.222 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 0.542 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 0.965 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.025 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 0.847 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 0.826 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 1.059 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 1.011 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.429 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 2.254 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 1.118 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 0.676 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 1.053 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 1.470 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 0.867 s]
[INFO] WMTS Style editing extension ....................... SUCCESS [ 1.201 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.019 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 1.002 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 0.934 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 0.825 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 0.848 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 0.896 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 1.064 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 1.015 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.197 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 0.434 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 0.798 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 0.475 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.015 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 1.929 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 1.043 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 1.625 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 0.951 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.018 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.377 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 1.250 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 1.229 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 1.966 s]
[INFO] MapML Support ...................................... SUCCESS [ 0.799 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 0.391 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 1.283 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.022 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 3.798 s]
[INFO] GeoServer Task Manager S3 .......................... FAILURE [ 0.802 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 2.838 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 1.068 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SUCCESS [ 0.977 s]
[INFO] BUILD FAILURE
[INFO] Total time: 01:34 min
[INFO] Finished at: 2019-05-03T08:56:51+00:00
[INFO] Final Memory: 191M/647M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-taskmanager-s3: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/CopyS3FileTaskTest.java>:\[5,1\] cannot access org.geoserver.taskmanager.tasks
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/springframework/spring-tx/5.1.1.RELEASE/spring-tx-5.1.1.RELEASE.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/external/S3FileServiceDataTest.java>:\[5,1\] cannot access org.geoserver.taskmanager.external
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[52,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[52,54\] cannot find symbol
[ERROR] symbol: class AbstractTaskManagerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[54,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.taskmanager.tasks.FileRemoteS3PublicationTaskTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[57,20\] cannot find symbol
[ERROR] symbol: class QName
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[58,20\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[59,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[60,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[61,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[67,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[68,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[69,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[70,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[71,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[77,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[79,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[80,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[81,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[82,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[84,24\] cannot find symbol
[ERROR] symbol: class LookupService
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[84,38\] cannot find symbol
[ERROR] symbol: class ExternalGS
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[86,24\] cannot find symbol
[ERROR] symbol: class TaskManagerDao
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[88,24\] cannot find symbol
[ERROR] symbol: class TaskManagerFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[90,24\] cannot find symbol
[ERROR] symbol: class TaskManagerDataUtil
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[92,24\] cannot find symbol
[ERROR] symbol: class TaskManagerTaskUtil
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[94,24\] cannot find symbol
[ERROR] symbol: class BatchJobService
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[96,24\] cannot find symbol
[ERROR] symbol: class Scheduler
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[98,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[98,38\] cannot find symbol
[ERROR] symbol: class FileService
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[100,13\] cannot find symbol
[ERROR] symbol: class Configuration
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[102,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[105,48\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[128,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[171,20\] cannot find symbol
[ERROR] symbol: class SchedulerException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[171,40\] cannot find symbol
[ERROR] symbol: class SQLException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[171,54\] cannot find symbol
[ERROR] symbol: class MalformedURLException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[228,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[228,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileRemoteS3PublicationTaskTest.java>:\[228,54\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[40,8\] cannot access org.geoserver.taskmanager
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[40,53\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[42,26\] cannot find symbol
[ERROR] location: class org.geoserver.taskmanager.tasks.FileLocalS3PublicationTaskTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[59,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[61,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[63,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[65,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[67,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[69,24\] cannot find symbol
[ERROR] symbol: class Catalog
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[71,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[73,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[73,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[75,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[77,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[85,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[127,48\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/tasks/FileLocalS3PublicationTaskTest.java>:\[127,68\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-taskmanager-s3
