[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #523
See <https://build.geoserver.org/job/geoserver-java11/523/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] appschema complex query tests (#3239)
[...truncated 2.17 MB...]
[INFO] Copying gs-wmts-styles-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-wmts-styles-2.16-SNAPSHOT.jar&gt;
[INFO] Copying gt-process-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-process-22-SNAPSHOT.jar&gt;
[INFO] Copying gs-web-oseo-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-web-oseo-2.16-SNAPSHOT.jar&gt;
[INFO] Copying gt-app-schema-resolver-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-app-schema-resolver-22-SNAPSHOT.jar&gt;
[INFO] Copying spring-security-oauth2-2.0.11.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-security-oauth2-2.0.11.RELEASE.jar&gt;
[INFO] Copying wicketstuff-select2-7.6.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/wicketstuff-select2-7.6.0.jar&gt;
[INFO] Copying prettytime-1.0.8.Final.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/prettytime-1.0.8.Final.jar&gt;
[INFO] Copying gs-netcdf-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-netcdf-2.16-SNAPSHOT.jar&gt;
[INFO] Copying jt-nullop-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-nullop-1.1.9.jar&gt;
[INFO] Copying gt-app-schema-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-app-schema-22-SNAPSHOT.jar&gt;
[INFO] Copying jt-lookup-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-lookup-1.1.9.jar&gt;
[INFO] Copying spring-batch-test-3.0.7.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-batch-test-3.0.7.RELEASE.jar&gt;
[INFO] Copying jasypt-springsecurity3-1.9.2.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jasypt-springsecurity3-1.9.2.jar&gt;
[INFO] Copying gs-web-resource-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-web-resource-2.16-SNAPSHOT.jar&gt;
[INFO] Copying jt-binarize-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-binarize-1.1.9.jar&gt;
[INFO] Copying log4j-over-slf4j-1.6.4.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/log4j-over-slf4j-1.6.4.jar&gt;
[INFO] Copying httpclient-cache-4.5.5.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/httpclient-cache-4.5.5.jar&gt;
[INFO] Copying javassist-3.19.0-GA.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/javassist-3.19.0-GA.jar&gt;
[INFO] Copying jt-rangelookup-1.5.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-rangelookup-1.5.0.jar&gt;
[INFO] Copying commons-beanutils-1.9.2-noclassprop.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/commons-beanutils-1.9.2-noclassprop.jar&gt;
[INFO] Copying gs-web-gwc-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-web-gwc-2.16-SNAPSHOT.jar&gt;
[INFO] Copying batik-awt-util-1.10.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/batik-awt-util-1.10.jar&gt;
[INFO] Copying org.eclipse.persistence.core-2.7.4.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/org.eclipse.persistence.core-2.7.4.jar&gt;
[INFO] Copying spring-jcl-5.1.1.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-jcl-5.1.1.RELEASE.jar&gt;
[INFO] Copying gt-complex-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-complex-22-SNAPSHOT.jar&gt;
[INFO] Copying batik-xml-1.10.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/batik-xml-1.10.jar&gt;
[INFO] Copying activemq-jms-pool-5.9.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/activemq-jms-pool-5.9.0.jar&gt;
[INFO] Copying jcommon-1.0.13.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jcommon-1.0.13.jar&gt;
[INFO] Copying activemq-openwire-legacy-5.9.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/activemq-openwire-legacy-5.9.0.jar&gt;
[INFO] Copying gs-wcs1_1-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-wcs1_1-2.16-SNAPSHOT.jar&gt;
[INFO] Copying mysql-connector-java-5.1.46.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/mysql-connector-java-5.1.46.jar&gt;
[INFO] Copying cdm-4.6.11.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/cdm-4.6.11.jar&gt;
[INFO] Copying jt-warp-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-warp-1.1.9.jar&gt;
[INFO] Copying gs-s3-geotiff-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-s3-geotiff-2.16-SNAPSHOT.jar&gt;
[INFO] Copying spring-aop-5.1.1.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-aop-5.1.1.RELEASE.jar&gt;
[INFO] Copying gt-geotiff-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-geotiff-22-SNAPSHOT.jar&gt;
[INFO] Copying ejml-core-0.34.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/ejml-core-0.34.jar&gt;
[INFO] Copying jt-zonal-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-zonal-1.1.9.jar&gt;
[INFO] Copying spring-expression-5.1.1.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-expression-5.1.1.RELEASE.jar&gt;
[INFO] Copying jt-rescale-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-rescale-1.1.9.jar&gt;
[INFO] Copying keycloak-authz-client-4.4.0.Final.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/keycloak-authz-client-4.4.0.Final.jar&gt;
[INFO] Copying imageio-ext-streams-1.3.1.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/imageio-ext-streams-1.3.1.jar&gt;
[INFO] Copying gt-xml-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-xml-22-SNAPSHOT.jar&gt;
[INFO] Copying gs-backup-restore-rest-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-backup-restore-rest-2.16-SNAPSHOT.jar&gt;
[INFO] Copying xmlpull-1.1.3.1.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/xmlpull-1.1.3.1.jar&gt;
[INFO] Copying batik-parser-1.10.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/batik-parser-1.10.jar&gt;
[INFO] Copying threetenbp-1.3.4.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/threetenbp-1.3.4.jar&gt;
[INFO] Copying jt-vectorize-1.5.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-vectorize-1.5.0.jar&gt;
[INFO] Copying hamcrest-core-1.3.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/hamcrest-core-1.3.jar&gt;
[INFO] Copying gt-coverage-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-coverage-22-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gwc-core-1.16-SNAPSHOT.jar&gt;
[INFO] Copying jackson-annotations-2.9.7.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jackson-annotations-2.9.7.jar&gt;
[INFO] Copying guava-27.0-jre.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/guava-27.0-jre.jar&gt;
[INFO] Copying org.eclipse.emf.common-2.12.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/org.eclipse.emf.common-2.12.0.jar&gt;
[INFO] Copying hsqldb-2.4.1.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/hsqldb-2.4.1.jar&gt;
[INFO] Copying gt-wms-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-wms-22-SNAPSHOT.jar&gt;
[INFO] Copying disruptor-1.2.13.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/disruptor-1.2.13.jar&gt;
[INFO] Copying not-yet-commons-ssl-0.3.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/not-yet-commons-ssl-0.3.9.jar&gt;
[INFO] Copying dnsjava-2.0.8.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/dnsjava-2.0.8.jar&gt;
[INFO] Copying imageio-ext-gdalframework-1.3.1.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/imageio-ext-gdalframework-1.3.1.jar&gt;
[INFO] Copying smack-extensions-4.0.5.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/smack-extensions-4.0.5.jar&gt;
[INFO] Copying gt-arcgrid-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-arcgrid-22-SNAPSHOT.jar&gt;
[INFO] Copying j2objc-annotations-1.1.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/j2objc-annotations-1.1.jar&gt;
[INFO] Copying gt-jdbc-oracle-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-jdbc-oracle-22-SNAPSHOT.jar&gt;
[INFO] Copying jna-platform-4.4.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jna-platform-4.4.0.jar&gt;
[INFO] Copying gt-jdbc-mysql-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-jdbc-mysql-22-SNAPSHOT.jar&gt;
[INFO] Copying spring-security-saml2-core-1.0.2.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-security-saml2-core-1.0.2.RELEASE.jar&gt;
[INFO] Copying woodstox-core-5.0.3.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/woodstox-core-5.0.3.jar&gt;
[INFO] Copying batik-css-1.10.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/batik-css-1.10.jar&gt;
[INFO] Copying metrics-core-4.0.3.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/metrics-core-4.0.3.jar&gt;
[INFO] Copying jt-colorconvert-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-colorconvert-1.1.9.jar&gt;
[INFO] Copying gt-arcsde-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-arcsde-22-SNAPSHOT.jar&gt;
[INFO] Copying jt-jiffle-op-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-jiffle-op-1.1.9.jar&gt;
[INFO] Copying gt-imagemosaic-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-imagemosaic-22-SNAPSHOT.jar&gt;
[INFO] Copying commons-text-1.4.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/commons-text-1.4.jar&gt;
[INFO] Copying gt-jdbc-teradata-21-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-jdbc-teradata-21-SNAPSHOT.jar&gt;
[INFO] Copying smack-compression-jzlib-4.0.5.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/smack-compression-jzlib-4.0.5.jar&gt;
[INFO] Copying GeographicLib-Java-1.49.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/GeographicLib-Java-1.49.jar&gt;
[INFO] Copying activemq-jdbc-store-5.9.0.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/activemq-jdbc-store-5.9.0.jar&gt;
[INFO] Copying gs-backup-restore-extension-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-backup-restore-extension-2.16-SNAPSHOT.jar&gt;
[INFO] Copying ezmorph-1.0.6.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/ezmorph-1.0.6.jar&gt;
[INFO] Copying gs-backup-restore-web-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-backup-restore-web-2.16-SNAPSHOT.jar&gt;
[INFO] Copying spring-context-support-5.1.1.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-context-support-5.1.1.RELEASE.jar&gt;
[INFO] Copying gs-wms-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-wms-2.16-SNAPSHOT.jar&gt;
[INFO] Copying janino-3.0.8.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/janino-3.0.8.jar&gt;
[INFO] Copying gt-svg-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gt-svg-22-SNAPSHOT.jar&gt;
[INFO] Copying spring-jdbc-5.1.1.RELEASE.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/spring-jdbc-5.1.1.RELEASE.jar&gt;
[INFO] Copying gs-mapml-2.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/gs-mapml-2.16-SNAPSHOT.jar&gt;
[INFO] Copying jt-format-1.1.9.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/jt-format-1.1.9.jar&gt;
[INFO] Copying keycloak-adapter-core-4.4.0.Final.jar to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/release/target/dependency/keycloak-adapter-core-4.4.0.Final.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (default) @ gs-release ---
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO] Building GeoServer notification event system 2.16-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-notification ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-notification ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-notification ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO] Copying 1 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-notification ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/INotificationTransactionListener.java&gt;: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/INotificationTransactionListener.java&gt; uses or overrides a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/INotificationTransactionListener.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/DefaultConfigTest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/DefaultConfigTest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/DefaultConfigTest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousSystemTest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousSystemTest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousSystemTest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/ReceiverService.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/ReceiverService.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/ReceiverService.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/Receiver.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/Receiver.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/Receiver.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/SystemTest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/SystemTest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/SystemTest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/BrokerManager.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/BrokerManager.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/BrokerManager.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/Utils.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/Utils.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/support/Utils.java&gt;: Too many open files
[INFO] 9 errors
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 5.189 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.073 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 2.288 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 3.441 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.152 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 1.909 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 1.598 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 1.116 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 1.557 s]
[INFO] WMS-EO ............................................. SUCCESS [ 1.714 s]
[INFO] ColorMap ........................................... SUCCESS [ 1.096 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 1.399 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 1.531 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 0.581 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 1.137 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 1.085 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 0.968 s]
[INFO] DownloadProcess .................................... SUCCESS [ 2.319 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.034 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 1.651 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 0.435 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 2.490 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 1.550 s]
[INFO] Solr Module ........................................ SUCCESS [ 1.002 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 1.571 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 1.685 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 1.064 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 1.212 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 0.567 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 0.936 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.017 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 0.826 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 0.848 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 1.164 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 0.913 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.515 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 2.420 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 1.227 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 0.716 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 0.915 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 1.341 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 0.871 s]
[INFO] WMTS Style editing extension ....................... SUCCESS [ 1.008 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 1.136 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 0.971 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 0.893 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 0.836 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 0.965 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 1.008 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 0.923 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.188 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 0.477 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 0.850 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 0.350 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.015 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 2.208 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 0.949 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 1.451 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 0.973 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.015 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.386 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 1.465 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 1.248 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 2.273 s]
[INFO] MapML Support ...................................... SUCCESS [ 0.817 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 0.449 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 1.381 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.035 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 6.306 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 0.960 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 1.864 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 0.407 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 0.614 s]
[INFO] GeoServer notification event system ................ FAILURE [ 0.787 s]
[INFO] BUILD FAILURE
[INFO] Total time: 01:37 min
[INFO] Finished at: 2019-05-06T18:08:17+00:00
[INFO] Final Memory: 411M/1092M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-notification: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-notification
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/524/display/redirect?page=changes&gt;
