See <http://build.geoserver.org/job/geoserver-java11/560/display/redirect?page=changes>
Changes:
[Andrea Aime] Makng GeoServer compile after removal of deprecated methods/objects in
[Andrea Aime] Removing/replacing all deprecated calls to IOUtils.closeQuietly
[Andrea Aime] Switching from old junit assert to the current one
[Andrea Aime] Removing easymock classpath extension, is deprecated and has been merged
[Andrea Aime] Removing RequestUtils deprecated method
[Andrea Aime] Removing HTTPServletAware and its usage points
[Andrea Aime] Replacing deprecated DefaultServiceExceptionHandler with its superclass
[Andrea Aime] Completing cleanup of the gs-ows module, removed the deprecated OWS
[Andrea Aime] Replacing commons deprecated MultiHashMap with MultiValueHashMap
[Andrea Aime] Replacing deprecated Wrapper and AbstractCatalogDecorator with the
[Andrea Aime] Bye bye DataAccessManager
[Andrea Aime] Sweeping under the rug a bit of deprecatd org.vfny stuff, unfortunately
[Andrea Aime] Replacing deprecated Spring Base64 class with java own
[Andrea Aime] Resource step one
[Andrea Aime] Replacing deprecated url method in GeoServerResourceLoader
[Andrea Aime] Cleaning up GeoServerDataDirectory deprecated methods
[Andrea Aime] Removing deprecated ResourceInfo.getPrefixedName
[Andrea Aime] Removing deprecated methods from Catalog
[Andrea Aime] Removing deprecated prefixedName from PublishedInfo
[Andrea Aime] Removing deprecated methods from ContactInfo and GeoServerInfo
[Andrea Aime] Removing deprecated methods from JAIInfo
[Andrea Aime] The concurrent operation registry is in jai-ext
[Andrea Aime] Fixing IOUtils.write calls and removing GeoServeFeatureLocking
[Andrea Aime] Replacing calls to Throwables deprecated methods
[Andrea Aime] Dude, this is the two arguments constructor....
[Andrea Aime] Fixing deprecated calls to Spring Assert methos, use junit assert in
[Andrea Aime] Removing CatalogFacade deprecated method
[Andrea Aime] Removing StyleInfo deprecated methods
[Andrea Aime] Removing deprecated methods from template loader
[Andrea Aime] Resolving assorted deprecations in gs-main tests, fixing pmd and
[Andrea Aime] Fixing deprecated calls to Capture
[Andrea Aime] Removing PropertyFileWatcher deprecated constructor
[Andrea Aime] Removing deprecated methods from FileWatcher and friends
[Andrea Aime] Fixing deprecated class usage in LDAP module... finger crossed, I don't
[Andrea Aime] Fixing deprecated calls to readFileToString
[Andrea Aime] Fixed usage of deprecated SimpleEnumerationType
[Andrea Aime] Removed dodgy deprecation, was deprecated but GMLInfo was not given a
[Andrea Aime] Goodbye TransactionPlugin
[Andrea Aime] Removing deprecated method from Response
[Andrea Aime] Removing usage of deprecated EMFUtils.clone method
[Andrea Aime] Fixing calls to URLDecoder.decode deprecated method version
[Andrea Aime] Fixing deprecated point constructor call
[Andrea Aime] Removing ShapeZipOutputFormat deprecated constructor
[Andrea Aime] Small deprecation and PMD fixes
[Andrea Aime] Removing deprecated call to ExpressionDOMParser static method
[Andrea Aime] GetLegendGraphicRequest deprecated methods removal
[Andrea Aime] Ignore deprecatins in MockHttpClientConnectionManager, nothing we can do
[Andrea Aime] Completing WMS small cleanups
[Andrea Aime] Fixing deprecated calls to FileUtils.write
[Andrea Aime] Fixing usage of deprecated constructor of
[Andrea Aime] Removing deprecated methods in GeoServerTileLayer
[Andrea Aime] Handling assorted deprecations in gwc src/main
[Andrea Aime] Assorted deprecation fixes. Some are just suppressions, the author of
[Andrea Aime] Assorted deprecated call fixes in restconfig
[Andrea Aime] Fixing assorted deprecations in web/core
[Andrea Aime] Removing deprecated method from GeoServerSecurityManager
[Andrea Aime] Ignoring deprecation on wicket method call that has no obvious
[Andrea Aime] web/app deprecation fixes. Start.java uses a bunch of deprecated
[Andrea Aime] Removing deprecated IOUtils class, switch usage points to its superclass
[Andrea Aime] Completing app-schema-test cleanup
[Andrea Aime] Cleaning up html image map
[Andrea Aime] Fixing ogr output format
[Andrea Aime] Cleaning up GSProcess usage
[Andrea Aime] Assorted minor fixes in wps
[Andrea Aime] Cleaning up geofence and monitoring
[Andrea Aime] Follow up on GeoTools changes
[Andrea Aime] Making community modules in communityRelease compile
[Andrea Aime] Fixing build after deprecated method removal in GeoWebCache
[Andrea Aime] Deprecated API checkpoint on main, more deprecated API yet to remove
[Andrea Aime] Closing up main
[Andrea Aime] Make community modules compile
[Andrea Aime] java 11 fixes
[Andrea Aime] More java 11 fixes. WCS 1.1 has the same 'fix' as CQL, cannot have
[Andrea Aime] Add extensibility of common preview formats via beans (#3521)
[Andrea Aime] GEOS-9184 style image upload: NPE if new style (#3443)
[Andrea Aime] Revert "Resource step one"
[Andrea Aime] Resources.find( resource, force ) javadoc Implement
[...truncated 201.26 KB...]
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping GeoFence security integration
[INFO]
[INFO] Skipping REST SLD service
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 3.325 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.743 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.906 s]
[INFO] Main Module ........................................ FAILURE [ 5.751 s]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.051 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.050 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.070 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.144 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.091 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.046 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.062 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.018 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.052 s]
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.059 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.070 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 25.076 s (Wall Clock)
[INFO] Finished at: 2019-06-01T17:21:31Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureStore.java>:\[36,8\] org.vfny.geoserver.global.GeoServerFeatureStore is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureLocking.java>:\[31,8\] org.vfny.geoserver.global.GeoServerFeatureLocking is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredStructuredGridCoverage2DReader.java>:\[21,8\] org.geoserver.security.decorators.SecuredStructuredGridCoverage2DReader is not abstract and does not override abstract method removeCoverage(java.lang.String) in org.geotools.coverage.grid.io.StructuredGridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java>:\[67,8\] org.geoserver.catalog.CoverageDimensionCustomizerReader is not abstract and does not override abstract method getNumOverviews(java.lang.String) in org.geotools.coverage.grid.io.GridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java>:\[77,12\] org.geoserver.catalog.CoverageDimensionCustomizerReader.CoverageDimensionCustomizerStructuredReader is not abstract and does not override abstract method removeCoverage(java.lang.String) in org.geotools.coverage.grid.io.StructuredGridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/catalog/SingleGridCoverage2DReader.java>:\[29,8\] org.geoserver.catalog.SingleGridCoverage2DReader is not abstract and does not override abstract method getNumOverviews(java.lang.String) in org.geotools.coverage.grid.io.GridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureStore.java>:\[42,8\] org.geoserver.security.decorators.SecuredFeatureStore is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureLocking.java>:\[26,8\] org.geoserver.security.decorators.SecuredFeatureLocking is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredSimpleFeatureLocking.java>:\[31,8\] org.geoserver.security.decorators.SecuredSimpleFeatureLocking is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/catalog/StructuredSingleGridCoverage2DReader.java>:\[23,8\] org.geoserver.catalog.StructuredSingleGridCoverage2DReader is not abstract and does not override abstract method removeCoverage(java.lang.String) in org.geotools.coverage.grid.io.StructuredGridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/feature/retype/RetypingFeatureStore.java>:\[33,8\] org.geoserver.feature.retype.RetypingFeatureStore is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/feature/retype/RetypingFeatureLocking.java>:\[19,1\] org.geoserver.feature.retype.RetypingFeatureLocking is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java>:\[85,8\] org.geoserver.catalog.CoverageViewReader is not abstract and does not override abstract method getNumOverviews(java.lang.String) in org.geotools.coverage.grid.io.GridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/catalog/StructuredCoverageViewReader.java>:\[43,8\] org.geoserver.catalog.StructuredCoverageViewReader is not abstract and does not override abstract method removeCoverage(java.lang.String) in org.geotools.coverage.grid.io.StructuredGridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/feature/retype/WrappingFeatureListener.java>:\[26,62\] incompatible types: org.geotools.data.FeatureEvent.Type cannot be converted to int
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredGridCoverage2DReader.java>:\[41,8\] org.geoserver.security.decorators.SecuredGridCoverage2DReader is not abstract and does not override abstract method getNumOverviews(java.lang.String) in org.geotools.coverage.grid.io.GridCoverage2DReader
[ERROR] <http://build.geoserver.org/job/geoserver-java11/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredSimpleFeatureStore.java>:\[30,8\] org.geoserver.security.decorators.SecuredSimpleFeatureStore is not abstract and does not override abstract method modifyFeatures(org.opengis.feature.type.AttributeDescriptor,java.lang.Object,org.opengis.filter.Filter) in org.geotools.data.FeatureStore
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
