See <http://build.geoserver.org/job/geoserver-java11/572/display/redirect>
Started by an SCM change
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-java11/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-java11/lastSuccessful
at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
at java.nio.file.Files.deleteIfExists(Files.java:1165)
at hudson.Util.createSymlink(Util.java:1193)
at hudson.model.Run.createSymlink(Run.java:1955)
at hudson.model.Run.updateSymlinks(Run.java:1936)
at hudson.model.Run.execute(Run.java:1814)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-java11/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-java11/lastStable
at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on i-05928bcb8900bdb98 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-java11/ws/>
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from git://github.com/geoserver/geoserver.git
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:894)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1161)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1192)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1816)
Caused by: hudson.plugins.git.GitException: Command "git config remote.origin.url git://github.com/geoserver/geoserver.git" returned status code 4:
stdout:
stderr: error: failed to write new configuration file <http://build.geoserver.org/job/geoserver-java11/ws/.git/config.lock>
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2010)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2006)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1638)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1650)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.setRemoteUrl(CliGitAPIImpl.java:1284)
at hudson.plugins.git.GitAPI.setRemoteUrl(GitAPI.java:160)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:566)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.lang.Thread.run(Thread.java:834)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-05928bcb8900bdb98
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:957)
at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
at com.sun.proxy.$Proxy88.setRemoteUrl(Unknown Source)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl.setRemoteUrl(RemoteGitImpl.java:295)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:882)
