[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #639
See <https://build.geoserver.org/job/geoserver-java11/639/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] correct path to generated manual.pdf
[Jody Garnett] okay pdf not being generated yet
[Jody Garnett] ignoring manual.pdf
[...truncated 2.33 MB...]
Jun 12, 2019 7:18:07 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Jun 12, 2019 7:18:07 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jun 12, 2019 7:18:07 AM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Jun 12, 2019 7:18:07 AM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 135
Jun 12, 2019 7:18:08 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
Jun 12, 2019 7:18:08 AM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 12, 2019 7:18:08 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 4101a63e-8428-46c7-94e2-f3fe91f90b72
Jun 12, 2019 7:18:08 AM com.hazelcast.internal.cluster.ClusterService
Members {size:1, ver:3} [
  Member [127.0.0.1]:5701 - dee55305-918d-4ac0-90b7-ae61e944778d this
Jun 12, 2019 7:18:08 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 4101a63e-8428-46c7-94e2-f3fe91f90b72
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
Jun 12, 2019 7:18:08 AM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Jun 12, 2019 7:18:08 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 238 ms.
Jun 12, 2019 7:18:08 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 10 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.62 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] Skipping CSW UI Module
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.613 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.633 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.630 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.744 s]
[INFO] Main Module ........................................ SUCCESS [01:18 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.098 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:31 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 44.000 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 24.909 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.800 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.027 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.059 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:45 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:25 min]
[INFO] Web Map Service Module ............................. FAILURE [01:59 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 9.353 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:38 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.525 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 15.539 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.085 s]
[INFO] Core UI Module ..................................... SUCCESS [01:05 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 8.915 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.049 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:12 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 52.848 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.140 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.495 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.046 s]
[INFO] Printing Module .................................... SUCCESS [ 38.069 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.632 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.114 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.106 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.082 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.080 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.051 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.052 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.085 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.083 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.546 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.162 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.041 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.666 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.267 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.713 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.398 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.422 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.560 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.191 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.610 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.510 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.471 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.037 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Module ...................... FAILURE [ 3.194 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.961 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.051 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.725 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.665 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 26.786 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.022 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.329 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.990 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.023 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.702 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.988 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 13.346 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.024 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:31 min (Wall Clock)
[INFO] Finished at: 2019-06-12T07:18:10Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal on project gs-sec-cas: Could not resolve dependencies for project org.geoserver.security:gs-sec-cas:jar:2.16-SNAPSHOT: Could not transfer artifact org.jasig.cas.client:cas-client-core:jar:3.4.1 from/to central (https://repo.maven.apache.org/maven2): Connection reset -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
Not sending mail to unregistered user etj@anonymised.com
Not sending mail to unregistered user milkymike45@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/640/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9246] WMTS multidimensional, GetDomain: allow using bbox in other
[Andrea Aime] [GEOS-9247] WMTS multidimensional, support bboxes spanning the dateline
[...truncated 2.14 MB...]
  at org.geoserver.config.impl.GeoServerImpl.<init>(GeoServerImpl.java:54)
  at org.geoserver.data.test.SystemTestData.createConfig(SystemTestData.java:324)
  at org.geoserver.data.test.SystemTestData.setUp(SystemTestData.java:137)
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:129)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
Jun 12, 2019 12:54:58 PM com.hazelcast.instance.Node
Jun 12, 2019 12:54:58 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 12, 2019 12:54:58 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 868a35e7-b7d9-409d-802c-5755d53c2133
Jun 12, 2019 12:54:58 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 868a35e7-b7d9-409d-802c-5755d53c2133
Jun 12, 2019 12:54:58 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - cb3ed781-08df-40cc-a5b1-8743e565e83e this
Jun 12, 2019 12:54:58 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 12, 2019 12:54:58 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 322 ms.
Jun 12, 2019 12:54:58 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 17 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.734 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.123 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.969 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.578 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.220 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.125 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:27 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 44.200 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.812 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.386 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.952 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.243 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:47 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:13 min]
[INFO] Web Map Service Module ............................. FAILURE [01:47 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.389 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:30 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.699 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 14.513 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.060 s]
[INFO] Core UI Module ..................................... SUCCESS [ 49.945 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.143 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.048 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:06 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 50.411 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.189 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.672 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.048 s]
[INFO] Printing Module .................................... SUCCESS [ 7.387 s]
[INFO] Community Space .................................... SUCCESS [ 0.037 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.036 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.377 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.826 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.997 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.085 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.084 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.268 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.098 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.092 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.058 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.672 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.191 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 59.701 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.962 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.977 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.063 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.514 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.060 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.099 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.624 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.985 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.388 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.066 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.185 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.056 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.374 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.475 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.959 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.576 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 26.559 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.267 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.452 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.018 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.217 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.213 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.686 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.061 s]
[INFO] Total time: 11:12 min (Wall Clock)
[INFO] Finished at: 2019-06-12T12:55:02Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/641/display/redirect?page=changes&gt;
Changes:
[Torben Barsballe] TestWfsPost - improve url validation
[Torben Barsballe] TestWfsPost - don't forward Authentication header
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 2b3bb5f8-682d-467f-9dd7-6c075b787a83
Jun 12, 2019 6:12:14 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - eee34caf-53fb-43a4-831a-8b85091f92d5 this
Jun 12, 2019 6:12:14 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 2b3bb5f8-682d-467f-9dd7-6c075b787a83
Jun 12, 2019 6:12:14 PM com.hazelcast.instance.Node
Jun 12, 2019 6:12:14 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 12, 2019 6:12:14 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 350 ms.
Jun 12, 2019 6:12:14 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 11 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.701 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
WARNING: Illegal reflective access by org.geotools.image.ImageWorker (<https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geotools/gt-coverage/22-SNAPSHOT/gt-coverage-22-SNAPSHOT.jar)> to constructor com.sun.imageio.plugins.jpeg.JPEGImageWriterSpi()
  at org.geotools.image.ImageWorker.<clinit>(ImageWorker.java:224)
  at org.geoserver.config.impl.JAIEXTInfoImpl.<clinit>(JAIEXTInfoImpl.java:28)
  at org.geoserver.config.impl.JAIInfoImpl.<init>(JAIInfoImpl.java:54)
  at org.geoserver.config.impl.GeoServerInfoImpl.<init>(GeoServerInfoImpl.java:26)
  at org.geoserver.config.impl.GeoServerFactoryImpl.createGlobal(GeoServerFactoryImpl.java:38)
  at org.geoserver.config.impl.DefaultGeoServerFacade.<init>(DefaultGeoServerFacade.java:41)
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.6 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.902 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.962 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.217 s]
[INFO] Main Module ........................................ SUCCESS [01:03 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.493 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 18.581 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.109 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.540 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.552 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:31 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:10 min]
[INFO] Web Map Service Module ............................. FAILURE [01:40 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.949 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:25 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.051 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 14.244 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.074 s]
[INFO] Core UI Module ..................................... SUCCESS [ 51.528 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.779 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:07 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 51.714 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.584 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.415 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.050 s]
[INFO] Printing Module .................................... SUCCESS [ 7.345 s]
[INFO] Community Space .................................... SUCCESS [ 0.045 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.244 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.539 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.324 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.079 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.160 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.063 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.095 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.162 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.060 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.406 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.544 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 55.391 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.933 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.844 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.065 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.351 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.065 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.416 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.964 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.417 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.056 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.541 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.385 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.174 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.661 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.435 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 23.326 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.954 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.847 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.731 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.267 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.630 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.074 s]
[INFO] Total time: 10:55 min (Wall Clock)
[INFO] Finished at: 2019-06-12T18:12:18Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/642/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] make use of release artifacts to upload
[Jody Garnett] recreate release branch from tag
[Jody Garnett] ignore copied git artifacts in release folder
[...truncated 4.93 MB...]
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/csw/gs-csw-api/2.16-SNAPSHOT/maven-metadata.xml (1.4 kB at 14 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/csw/gs-csw-api/2.16-SNAPSHOT/gs-csw-api-2.16-20190612.202752-192.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.csw/22-SNAPSHOT/net.opengis.csw-22-20190612.055418-117.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-csw/22-SNAPSHOT/gt-xsd-csw-22-20190612.055518-117.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/ows-1.0/1.0.0-2/ows-1.0-1.0.0-2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/xlink-1.0/1.0.0-3/xlink-1.0-1.0.0-3.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/filter-1.1/1.1.1-2/filter-1.1-1.1.1-2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/gml-3.1/3.1.1-4/gml-3.1-3.1.1-4.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.csw/22-SNAPSHOT/net.opengis.csw-22-20190612.055418-117.jar (155 kB at 12 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/gml-3.2/3.2.1-1/gml-3.2-3.2.1-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/iso-19139-2007/1.0.0-1/iso-19139-2007-1.0.0-1.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-csw/22-SNAPSHOT/gt-xsd-csw-22-20190612.055518-117.jar (242 kB at 10 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/csw/gs-csw-api/2.16-SNAPSHOT/gs-csw-api-2.16-20190612.202752-192.jar (195 kB at 7.2 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/ows-1.0/1.0.0-2/ows-1.0-1.0.0-2.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/xlink-1.0/1.0.0-3/xlink-1.0-1.0.0-3.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/filter-1.1/1.1.1-2/filter-1.1-1.1.1-2.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/gml-3.1/3.1.1-4/gml-3.1-3.1.1-4.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/gml-3.2/3.2.1-1/gml-3.2-3.2.1-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/filter-1.1/1.1.1-2/filter-1.1-1.1.1-2.jar (7.2 kB at 34 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/iso-19139-2007/1.0.0-1/iso-19139-2007-1.0.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/xlink-1.0/1.0.0-3/xlink-1.0-1.0.0-3.jar (3.9 kB at 18 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/ows-1.0/1.0.0-2/ows-1.0-1.0.0-2.jar (20 kB at 68 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/gml-3.2/3.2.1-1/gml-3.2-3.2.1-1.jar (94 kB at 234 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/iso-19139-2007/1.0.0-1/iso-19139-2007-1.0.0-1.jar (47 kB at 115 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/gml-3.1/3.1.1-4/gml-3.1-3.1.1-4.jar (103 kB at 234 kB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-csw-simple-store ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-csw-simple-store ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-csw-simple-store ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-csw-simple-store ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/simple-store/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/simple-store/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-csw-simple-store ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/simple-store/src/main/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/simple-store/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-csw-simple-store ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-csw-simple-store ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/simple-store/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/simple-store/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-csw-simple-store ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-csw-simple-store ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-csw-simple-store ---
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 29.086 s]
[INFO] Core Platform Module ............................... SUCCESS [ 28.185 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.053 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.072 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:21 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [ 8.056 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 24.894 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.915 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.762 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.014 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 5.718 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:11 min]
[INFO] Web Map Service Module ............................. FAILURE [01:21 min]
[INFO] gs-rest ............................................ SUCCESS [ 9.296 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. FAILURE [ 0.672 s]
[INFO] gs-restconfig-wfs .................................. FAILURE [ 0.031 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.104 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.389 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI Core Module ............................ FAILURE [ 0.995 s]
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... FAILURE [ 0.253 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] Printing Module .................................... SUCCESS [ 37.663 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.020 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.511 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.634 s]
[INFO] H2 DataStore Extension ............................. FAILURE [ 0.032 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.801 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.285 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.897 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 14.720 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 4.311 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.415 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.804 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 13.156 s]
[INFO] Chart external graphics support .................... SUCCESS [ 5.798 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.619 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.583 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.024 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.425 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.546 s]
[INFO] GeoServer Monitor Extensions ....................... FAILURE [ 8.928 s]
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] XLST based WFS output format ....................... FAILURE [ 0.053 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.028 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.704 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation FAILURE [ 0.674 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.017 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.563 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 27.025 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 3.884 s]
[INFO] Total time: 07:45 min (Wall Clock)
[INFO] Finished at: 2019-06-12T20:51:19Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-monitor: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sec-jdbc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-restconfig-wcs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig-wcs/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-restconfig-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig-wfs/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/core/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-h2: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/h2/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-rest: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/rest/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-xslt: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/xslt/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-simple-store: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/simple-store/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <https://build.geoserver.org/job/geoserver-java11/643/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] optimization, fetch single tag
[Jody Garnett] do not commit generated release folder
[Jody Garnett] only fetch single tag
[Jody Garnett] correct repo name
[Jody Garnett] ignore change to release branch due to presense of release folder
Members {size:1, ver:1} [
  Member [127.0.0.1]:5701 - 36d060ed-28e4-4813-a322-e836db2d6100 this
Jun 12, 2019 10:54:04 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is STARTED
Jun 12, 2019 10:54:04 PM com.hazelcast.system
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast 3.11.1 (20181218 - d294f31) starting at [127.0.0.1]:5702
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Copyright (c) 2008-2018, Hazelcast, Inc. All Rights Reserved.
Jun 12, 2019 10:54:04 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] A non-empty group password is configured for the Hazelcast member. Starting with Hazelcast version 3.8.2, members with the same group name, but with different group passwords (that do not use authentication) form a cluster. The group password configuration will be removed completely in a future release.
Jun 12, 2019 10:54:04 PM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Backpressure is disabled
Jun 12, 2019 10:54:04 PM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Starting 8 partition threads and 5 generic threads (1 dedicated for priority tasks)
Jun 12, 2019 10:54:04 PM com.hazelcast.internal.diagnostics.Diagnostics
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Diagnostics disabled. To enable add -Dhazelcast.diagnostics.enabled=true to the JVM arguments.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTING
Jun 12, 2019 10:54:04 PM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 12, 2019 10:54:04 PM com.hazelcast.internal.cluster.ClusterService
Members {size:2, ver:2} [
  Member [127.0.0.1]:5702 - af88e0ef-5383-4642-941c-027b42cfb616
  Member [127.0.0.1]:5702 - af88e0ef-5383-4642-941c-027b42cfb616 this
Jun 12, 2019 10:54:04 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 12, 2019 10:54:04 PM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 12, 2019 10:54:04 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 12, 2019 10:54:05 PM com.hazelcast.instance.Node
Jun 12, 2019 10:54:05 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 12, 2019 10:54:05 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - af88e0ef-5383-4642-941c-027b42cfb616
Jun 12, 2019 10:54:05 PM com.hazelcast.internal.cluster.ClusterService
Jun 12, 2019 10:54:05 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: af88e0ef-5383-4642-941c-027b42cfb616
Jun 12, 2019 10:54:05 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 211 ms.
Jun 12, 2019 10:54:05 PM com.hazelcast.core.LifecycleService
Jun 12, 2019 10:54:05 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 15 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.153 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.934 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.403 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.965 s]
[INFO] Main Module ........................................ SUCCESS [ 56.318 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.138 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:24 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.671 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.504 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.153 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.699 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.128 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:34 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:09 min]
[INFO] Web Map Service Module ............................. FAILURE [01:41 min]
[INFO] gs-rest ............................................ SUCCESS [ 8.191 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.729 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.352 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.063 s]
[INFO] Core UI Module ..................................... SUCCESS [ 49.234 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.171 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.041 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:05 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 49.898 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.081 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.048 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] Printing Module .................................... SUCCESS [ 7.364 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.706 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.316 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.569 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.061 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.059 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.057 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.265 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.062 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.403 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.972 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.324 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.563 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.289 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.325 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.050 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.987 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 14.351 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.419 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.418 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.033 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.032 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.363 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.063 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.455 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.786 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.036 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.043 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.352 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 24.180 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.019 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.526 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.746 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.160 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.964 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.757 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.080 s]
[INFO] Total time: 10:44 min (Wall Clock)
[INFO] Finished at: 2019-06-12T22:54:05Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/644/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] include MAVEN_SETTINGS in MAVEN_FLAGS if provided
[Jody Garnett] git user credentials not used by publish
[Jody Garnett] Check MAVEN_SETTING passed in
[Jody Garnett] do not require unused user / email parameters
[Jody Garnett] use settings override if provided
[Jody Garnett] do not deploy community modules
[gabriel.roldan] Fix data/minimal/styles/generic.xml pointing at generic.sld instead of
  Member [127.0.0.1]:5701 - 0a54f8a8-8c44-4574-aea4-15cfc88b00d6 this
Jun 13, 2019 8:08:13 PM com.hazelcast.core.LifecycleService
Jun 13, 2019 8:08:13 PM com.hazelcast.system
Jun 13, 2019 8:08:13 PM com.hazelcast.instance.Node
Jun 13, 2019 8:08:13 PM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
Jun 13, 2019 8:08:13 PM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
Jun 13, 2019 8:08:13 PM com.hazelcast.internal.diagnostics.Diagnostics
Jun 13, 2019 8:08:13 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 13, 2019 8:08:13 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5702 - 476f5768-9911-4fb8-83dc-717b45efa73f
  Member [127.0.0.1]:5702 - 476f5768-9911-4fb8-83dc-717b45efa73f this
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Jun 13, 2019 8:08:13 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jun 13, 2019 8:08:13 PM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Jun 13, 2019 8:08:13 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 136
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 13, 2019 8:08:13 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 476f5768-9911-4fb8-83dc-717b45efa73f
Members {size:1, ver:3} [
Jun 13, 2019 8:08:13 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 476f5768-9911-4fb8-83dc-717b45efa73f
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Jun 13, 2019 8:08:13 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 171 ms.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
Jun 13, 2019 8:08:14 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 8 ms.
Jun 13, 2019 8:08:14 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.885 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.724 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.829 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.865 s]
[INFO] Main Module ........................................ SUCCESS [ 55.429 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.121 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:23 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.746 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.939 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.052 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.960 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.077 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:24 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:08 min]
[INFO] Web Map Service Module ............................. FAILURE [01:33 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.809 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:18 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.970 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.545 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.056 s]
[INFO] Core UI Module ..................................... SUCCESS [ 48.275 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.899 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.044 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 45.883 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.442 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.645 s]
[INFO] Printing Module .................................... SUCCESS [ 6.931 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.601 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.662 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.316 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.090 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.142 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.170 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.096 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.132 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.093 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.032 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.423 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.861 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.028 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 51.693 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.473 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.439 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.066 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.479 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.052 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.021 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.073 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.678 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.377 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.035 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.276 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.033 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.541 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.892 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.033 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 22.212 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.882 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.334 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.347 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.339 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.170 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.062 s]
[INFO] Total time: 10:10 min (Wall Clock)
[INFO] Finished at: 2019-06-13T20:08:14Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user gabriel.roldan@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/645/display/redirect?page=changes&gt;
Changes:
[niels] GEOS-9188 image insert namespace support
[...truncated 2.15 MB...]
  Member [127.0.0.1]:5701 - d3c36cd8-e135-433e-b83e-d721632d1f6c this
Jun 14, 2019 8:53:25 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: ad48c7c5-9c3e-402f-b7c5-a2b76fd05a2b
Jun 14, 2019 8:53:25 AM com.hazelcast.instance.Node
Jun 14, 2019 8:53:25 AM com.hazelcast.internal.partition.impl.MigrationManager
Jun 14, 2019 8:53:25 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 357 ms.
Jun 14, 2019 8:53:25 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 10 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.458 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.211 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.773 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.749 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.821 s]
[INFO] Main Module ........................................ SUCCESS [ 55.664 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.092 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:25 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.543 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 18.602 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.155 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.433 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.400 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:26 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:06 min]
[INFO] Web Map Service Module ............................. FAILURE [01:35 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 7.258 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:26 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.758 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.279 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] Core UI Module ..................................... SUCCESS [ 48.191 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 6.418 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Core Module ............................ SUCCESS [01:04 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 45.460 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.741 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.892 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.062 s]
[INFO] Printing Module .................................... SUCCESS [ 7.087 s]
[INFO] Community Space .................................... SUCCESS [ 0.079 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.045 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.360 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.895 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.688 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.102 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.077 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.060 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.079 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.154 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.063 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.028 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.486 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.825 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 53.025 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.508 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.527 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.061 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.329 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.049 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.793 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.518 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.785 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.401 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.042 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.190 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.382 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.965 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.034 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.543 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.849 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 22.787 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.018 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.508 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.440 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.651 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.414 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.885 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.060 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:18 min (Wall Clock)
[INFO] Finished at: 2019-06-14T08:53:29Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
Not sending mail to unregistered user etj@anonymised.com
Not sending mail to unregistered user milkymike45@anonymised.com
Not sending mail to unregistered user niels@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/646/display/redirect&gt;
[...truncated 1.98 MB...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.63 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.287 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [71/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.061 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.458 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.333 s]
[INFO] Main Module ........................................ SUCCESS [01:19 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.110 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:34 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:01 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.897 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.297 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.201 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 23.537 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:51 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:13 min]
[INFO] Web Map Service Module ............................. FAILURE [03:12 min]
[INFO] gs-rest ............................................ SUCCESS [ 17.358 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:19 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 18.975 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 21.412 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.131 s]
[INFO] Core UI Module ..................................... SUCCESS [01:41 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 16.814 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.055 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:58 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:20 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 25.048 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.169 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.097 s]
[INFO] Printing Module .................................... SUCCESS [ 14.851 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.043 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 14.163 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.983 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.121 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.170 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.947 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.379 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.455 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.069 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.452 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.105 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.638 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.332 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.062 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:40 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.520 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.246 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.712 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.753 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.756 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.960 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 14.890 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.950 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.990 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.131 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.098 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.913 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.100 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.456 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 23.289 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.085 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.204 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.781 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 36.442 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.083 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.577 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.061 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.056 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.876 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 24.725 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.764 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.876 s]
[INFO] Total time: 16:04 min (Wall Clock)
[INFO] Finished at: 2019-06-15T23:03:11Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Installer "Extract *.zip/*.tar.gz" cannot be used to install "OpenJDK 11.0.3" on the node "Jenkins"
Can anyone reproduce these? I was thinking maybe a UTF-8 related issues but the WMS failing test is using a SLD that’s embeeded as a string in the java file…
Travis seems to be happy, (https://travis-ci.org/geoserver/geoserver/builds/546848565) the build is fine on
my local machine too
On Fri, Jun 14, 2019 at 10:53 AM Jenkins <gtbuildergh@anonymised.com> wrote:
See <https://build.geoserver.org/job/geoserver-java11/645/display/redirect?page=changes>
Changes:
[…truncated 2.15 MB…]
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine…
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data…
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager…
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine…
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast —
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar>
WARNING: Illegal reflective access by org.geotools.image.ImageWorker (<https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geotools/gt-coverage/22-SNAPSHOT/gt-coverage-22-SNAPSHOT.jar)> to constructor com.sun.imageio.plugins.jpeg.JPEGImageWriterSpi()
at org.geotools.image.ImageWorker.(ImageWorker.java:224)
at org.geoserver.config.impl.JAIEXTInfoImpl.(JAIEXTInfoImpl.java:28)
at org.geoserver.config.impl.JAIInfoImpl.(JAIInfoImpl.java:54)
at org.geoserver.config.impl.GeoServerInfoImpl.(GeoServerInfoImpl.java:26)
at org.geoserver.config.impl.GeoServerFactoryImpl.createGlobal(GeoServerFactoryImpl.java:38)
at org.geoserver.config.impl.DefaultGeoServerFacade.(DefaultGeoServerFacade.java:41)
at org.geoserver.config.impl.GeoServerImpl.(GeoServerImpl.java:54)
at org.geoserver.data.test.SystemTestData.createConfig(SystemTestData.java:324)
at org.geoserver.data.test.SystemTestData.setUp(SystemTestData.java:137)
at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:129)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
SLF4J: Failed to load class “org.slf4j.impl.StaticLoggerBinder”.
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps —
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] GeoServer … SUCCESS [ 2.773 s]
[INFO] Core Platform Module … SUCCESS [ 10.749 s]
[INFO] Open Web Service Module … SUCCESS [ 4.821 s]
[INFO] Main Module … SUCCESS [ 55.664 s]
[INFO] GeoServer Security Modules … SUCCESS [ 0.092 s]
[INFO] GeoServer Security Tests Module … SUCCESS [01:25 min]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 40.543 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [ 18.602 s]
[INFO] Web Coverage Service Module … SUCCESS [ 1.155 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 13.433 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 14.400 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [03:26 min]
[INFO] Web Feature Service Module … SUCCESS [01:06 min]
[INFO] Web Map Service Module … FAILURE [01:35 min]
[INFO] KML support for GeoServer … SKIPPED
[INFO] gs-rest … SUCCESS [ 7.258 s]
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] gs-restconfig … SUCCESS [01:26 min]
[INFO] gs-restconfig-wcs … SUCCESS [ 11.758 s]
[INFO] gs-restconfig-wfs … SUCCESS [ 13.279 s]
[INFO] gs-restconfig-wms … SKIPPED
[INFO] GeoServer Web Modules … SUCCESS [ 0.056 s]
[INFO] Core UI Module … SUCCESS [ 48.191 s]
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SUCCESS [ 6.418 s]
[INFO] Demos Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] Security UI Modules … SUCCESS [ 0.036 s]
[INFO] Security UI Core Module … SUCCESS [01:04 min]
[INFO] Security UI JDBC Module … SUCCESS [ 45.460 s]
[INFO] Security UI LDAP Module … SUCCESS [ 13.741 s]
[INFO] REST UI Module … SUCCESS [ 6.892 s]
[INFO] GeoServer Extensions … SUCCESS [ 0.062 s]
[INFO] Printing Module … SUCCESS [ 7.087 s]
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SUCCESS [ 0.079 s]
[INFO] Application Schema Support … SUCCESS [ 0.045 s]
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SUCCESS [ 7.360 s]
[INFO] ArcSDE DataStore Extension … SUCCESS [ 5.895 s]
[INFO] H2 DataStore Extension … SUCCESS [ 7.688 s]
[INFO] SQL Server DataStore Extension … SUCCESS [ 0.102 s]
[INFO] Oracle DataStore Extension … SUCCESS [ 0.077 s]
[INFO] MySQL DataStore Extension … SUCCESS [ 0.060 s]
[INFO] DB2 DataStore Extension … SUCCESS [ 0.079 s]
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [ 1.154 s]
[INFO] JP2K Coverage Extension … SUCCESS [ 0.063 s]
[INFO] OGR parent … SUCCESS [ 0.028 s]
[INFO] OGR CORE … SUCCESS [ 0.486 s]
[INFO] OGR WFS … SUCCESS [ 4.825 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module … SUCCESS [ 53.025 s]
[INFO] OGR WPS … SUCCESS [ 5.508 s]
[INFO] Excel Output Format … SUCCESS [ 8.527 s]
[INFO] Chart external graphics support … SUCCESS [ 0.061 s]
[INFO] Feature Generalization Extension … SUCCESS [ 0.329 s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [ 0.049 s]
[INFO] OWS request flow controller … SUCCESS [ 10.793 s]
[INFO] Web process status sharing with Hazelcast … SUCCESS [ 7.518 s]
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SUCCESS [ 9.785 s]
[INFO] Teradata DataStore Extension … SUCCESS [ 0.401 s]
[INFO] GeoServer Monitor Extensions … SUCCESS [ 0.042 s]
[INFO] Core Monitor Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Module … SUCCESS [ 2.190 s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [ 0.382 s]
[INFO] XLST based WFS output format … SUCCESS [ 12.965 s]
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SUCCESS [ 0.034 s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [ 4.543 s]
[INFO] Catalog Services for the Web core module … FAILURE [ 22.787 s]
[INFO] CSW UI Module … SKIPPED
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [ 0.018 s]
[INFO] DXF WFS output format … SUCCESS [ 7.508 s]
[INFO] DXF WPS PPIO … SUCCESS [ 5.440 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [ 0.019 s]
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] Importer REST Api Module-ng … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO] GRIB Coverage Format … SUCCESS [ 9.885 s]
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[INFO] Vector Tiles … SKIPPED
[INFO] Ysld GeoServer Plugin … SKIPPED
[INFO] MongoDB Data Store … SUCCESS [ 0.060 s]
[INFO] REST SLD service … SKIPPED
[INFO] GeoFence security integration … SKIPPED
[INFO] GeoFence Server … SKIPPED
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-wms
Build step ‘Invoke top-level Maven targets’ marked build as failure
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I was not able to reproduce locally either.
Some thoughts:
  • Differences in Java minor versions (I hope this isn’t the issue, but Jenkins will be using the latest Java 11 release)
  • Differences in maven minor versions - this has definately caused differences in behaviour before, but Jenkins should be on a modern version of maven - its just downloading the latest from the Ubuntu 18 apt repository
  • Java 11 has a bunch of flags that affect how it runs - I wonder if Jenkins is setting an environment variable (e.g. JAVA_OPTS) that is overriding the expected settings.
    I’ll try replicating the Jenkins environment (Java version, maven version, OS, etc.) in a VM, and see if I can reproduce there.
Torben
On Mon, Jun 17, 2019 at 11:35 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
Changes:
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
I was eventually able to reproduce this in a VM. Oddly enough, it appears to be being caused by the -Dmaven.repo.local setting. My only guess is perhaps there is a permissions issue, maybe write permissions are available but read are not? I’ve tried modifying the job in jenkins to create and chmod 777 the m2 directory, but that appeared to still fail. I’m not sure what could be different about the local repo configuration that would cause this failure, and its not really something we can turn off on the Jenkins server (since that will pollute the server with Java 11 artifacts).
I did also see some problems when threading was enabled, but wasn’t able to consistently reproduce those.
This worked fine:
mvn -f geoserver/src/pom.xml -B -P allExtensions,printing,secJdbcJndiTest clean install -DconfigDirectory=…/…/…/data -fae
Whereas this failed:
mvn -f geoserver/src/pom.xml -B -P allExtensions,printing,secJdbcJndiTest clean install -DconfigDirectory=…/…/…/data -fae -Dmaven.repo.local=./m2
On Tue, Jun 18, 2019 at 10:30 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Some thoughts:
Torben
Changes:
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
The only thing odd localRepository thing I see in our root pom is the following:
-J-Xbootclasspath/p:${settings.localRepository}/com/google/errorprone/javac/${javac.version}/javac-${javac.version}.jar
Any way to confirm that maven.repo.local and settings.localRepository are the same?
Jody Garnett
Most recent failure https://build.geoserver.org/job/geoserver-java11/653/ is:
Jody Garnett
On Wed, Jun 19, 2019 at 9:24 AM Jody Garnett <jody.garnett@anonymised.com.> wrote:
mkdir: cannot create directory ‘./m2’: File exists
Whoops. The one before that should have run “properly”; I’ve fixed the config so it’ll work now if the dir exists.
On Wed, 19 Jun 2019 at 09:20, Jody Garnett <jody.garnett@anonymised.com> wrote:
I’m not sure, we’d probably have to add a maven build step to echo the value, since thats an internal maven property.
The actual error doesn’t seem to be related to errorprone, but who knows.
Torben
Jody Garnett
On Wed, 19 Jun 2019 at 09:12, Torben Barsballe <tbarsballe@anonymised.com> wrote:
This worked fine:
Some thoughts:
Torben
Changes:
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
