[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #648
See <https://build.geoserver.org/job/geoserver-java11/648/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] [community module AuthKey] - Allows the REST service to inject
[...truncated 2.14 MB...]
INFO: [127.0.0.1]:5701 [dev] [3.11.1]
Members {size:1, ver:3} [
  Member [127.0.0.1]:5701 - ae107932-52ce-47b4-a1e6-7319b69bd312 this
Jun 17, 2019 8:42:31 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: c55a11c1-0504-4cd1-bf2e-891730d45e32
Jun 17, 2019 8:42:31 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
Jun 17, 2019 8:42:31 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Jun 17, 2019 8:42:31 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 150 ms.
Jun 17, 2019 8:42:31 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
Jun 17, 2019 8:42:32 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 7 ms.
Jun 17, 2019 8:42:32 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.294 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
WARNING: Illegal reflective access by org.geotools.image.ImageWorker (<https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geotools/gt-coverage/22-SNAPSHOT/gt-coverage-22-SNAPSHOT.jar)> to constructor com.sun.imageio.plugins.jpeg.JPEGImageWriterSpi()
  at org.geotools.image.ImageWorker.<clinit>(ImageWorker.java:224)
  at org.geoserver.config.impl.JAIEXTInfoImpl.<clinit>(JAIEXTInfoImpl.java:28)
  at org.geoserver.config.impl.JAIInfoImpl.<init>(JAIInfoImpl.java:54)
  at org.geoserver.config.impl.GeoServerInfoImpl.<init>(GeoServerInfoImpl.java:26)
  at org.geoserver.config.impl.GeoServerFactoryImpl.createGlobal(GeoServerFactoryImpl.java:38)
  at org.geoserver.config.impl.DefaultGeoServerFacade.<init>(DefaultGeoServerFacade.java:41)
  at org.geoserver.config.impl.GeoServerImpl.<init>(GeoServerImpl.java:54)
  at org.geoserver.data.test.SystemTestData.createConfig(SystemTestData.java:324)
  at org.geoserver.data.test.SystemTestData.setUp(SystemTestData.java:137)
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:129)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.249 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.547 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.284 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.588 s]
[INFO] Main Module ........................................ SUCCESS [ 52.861 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.082 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:22 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.261 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.864 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.025 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.383 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.592 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:21 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:04 min]
[INFO] Web Map Service Module ............................. FAILURE [01:32 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 7.321 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:19 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.504 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.708 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.064 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.345 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 6.357 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.075 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 44.304 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.223 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.303 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.045 s]
[INFO] Printing Module .................................... SUCCESS [ 6.769 s]
[INFO] Community Space .................................... SUCCESS [ 0.037 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.173 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.825 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.530 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.113 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.062 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.100 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.121 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.106 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.065 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.382 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.625 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 50.173 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.362 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.994 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.064 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.372 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.057 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.901 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.395 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.172 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.345 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.032 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.115 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.384 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.889 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.036 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.618 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.892 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 21.767 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.022 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.675 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.584 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.198 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.219 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 8.996 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.072 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 09:54 min (Wall Clock)
[INFO] Finished at: 2019-06-17T20:42:35Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user etj@anonymised.com
Not sending mail to unregistered user milkymike45@anonymised.com
Not sending mail to unregistered user niels@anonymised.com
Not sending mail to unregistered user gabriel.roldan@anonymised.com
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/649/display/redirect?page=changes&gt;
Changes:
[noreply] GEOS-9239: optional flag(s) to remove root layer from WMS capabilitie…
Jun 18, 2019 10:35:21 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is STARTED
Jun 18, 2019 10:35:21 AM com.hazelcast.system
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast 3.11.1 (20181218 - d294f31) starting at [127.0.0.1]:5702
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Copyright (c) 2008-2018, Hazelcast, Inc. All Rights Reserved.
Jun 18, 2019 10:35:21 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] A non-empty group password is configured for the Hazelcast member. Starting with Hazelcast version 3.8.2, members with the same group name, but with different group passwords (that do not use authentication) form a cluster. The group password configuration will be removed completely in a future release.
Jun 18, 2019 10:35:21 AM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Backpressure is disabled
Jun 18, 2019 10:35:21 AM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Starting 8 partition threads and 5 generic threads (1 dedicated for priority tasks)
Jun 18, 2019 10:35:21 AM com.hazelcast.internal.diagnostics.Diagnostics
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Diagnostics disabled. To enable add -Dhazelcast.diagnostics.enabled=true to the JVM arguments.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTING
Jun 18, 2019 10:35:21 AM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 18, 2019 10:35:21 AM com.hazelcast.internal.cluster.ClusterService
Members {size:2, ver:2} [
  Member [127.0.0.1]:5701 - 040794a6-c2b6-4f92-8975-9c4a2b7d8cc2 this
  Member [127.0.0.1]:5702 - 00fe1a27-04d1-4699-a110-2797c3cd64bc
  Member [127.0.0.1]:5702 - 00fe1a27-04d1-4699-a110-2797c3cd64bc this
Jun 18, 2019 10:35:22 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Jun 18, 2019 10:35:22 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jun 18, 2019 10:35:22 AM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Jun 18, 2019 10:35:22 AM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 135
Jun 18, 2019 10:35:22 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
Jun 18, 2019 10:35:22 AM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 18, 2019 10:35:22 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 00fe1a27-04d1-4699-a110-2797c3cd64bc
Jun 18, 2019 10:35:22 AM com.hazelcast.internal.cluster.ClusterService
Jun 18, 2019 10:35:22 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 00fe1a27-04d1-4699-a110-2797c3cd64bc
Jun 18, 2019 10:35:22 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 126 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 6 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.643 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.307 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.420 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.930 s]
[INFO] Main Module ........................................ SUCCESS [ 45.087 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.061 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:18 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.490 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 18.017 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.751 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 9.030 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 10.996 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:05 min]
[INFO] Web Feature Service Module ......................... SUCCESS [ 56.622 s]
[INFO] Web Map Service Module ............................. FAILURE [01:20 min]
[INFO] gs-rest ............................................ SUCCESS [ 6.780 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:03 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 8.381 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.428 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.045 s]
[INFO] Core UI Module ..................................... SUCCESS [ 40.453 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.446 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.029 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 51.450 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 38.873 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 12.296 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.212 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] Printing Module .................................... SUCCESS [ 5.781 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.126 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 4.753 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 5.503 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.063 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.100 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.102 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.091 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.972 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.059 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.305 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.068 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 42.095 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.391 s]
[INFO] Excel Output Format ................................ SUCCESS [ 6.994 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.091 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.308 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.042 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.477 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 11.990 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 7.770 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.290 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.027 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.032 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.780 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.314 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.167 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.028 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 3.860 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.007 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 18.886 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.015 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.397 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.036 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.015 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.236 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 5.873 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 7.663 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.060 s]
[INFO] Total time: 08:41 min (Wall Clock)
[INFO] Finished at: 2019-06-18T10:35:22Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/650/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] [GEOS-9240] Add App-Schema MongoDb PropertyIsNull filter testing.
  Member [127.0.0.1]:5701 - 5557514b-62b2-44dc-90f2-a88ca7c7d842 this
Jun 18, 2019 2:03:21 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 2d06e7b8-ef7f-4117-b564-0c2cfe83c4a5
Jun 18, 2019 2:03:21 PM com.hazelcast.instance.Node
Jun 18, 2019 2:03:21 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 18, 2019 2:03:21 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 158 ms.
Jun 18, 2019 2:03:21 PM com.hazelcast.core.LifecycleService
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.129 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.021 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.773 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.995 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.486 s]
[INFO] Main Module ........................................ SUCCESS [ 54.061 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.380 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 17.389 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.160 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.223 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.340 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:31 min]
[INFO] Web Map Service Module ............................. FAILURE [01:33 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.338 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:16 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.930 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.122 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.595 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.367 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.041 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:00 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 45.265 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.899 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.395 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 7.040 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.291 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.596 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.547 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.118 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.078 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.185 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.087 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.089 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.046 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.400 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.656 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 51.243 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.083 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.141 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.054 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.354 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.056 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.841 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.104 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.174 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.342 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.034 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.176 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.408 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.810 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.500 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.769 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 22.671 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.541 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.190 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.827 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.232 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 8.733 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.123 s]
[INFO] Total time: 09:55 min (Wall Clock)
[INFO] Finished at: 2019-06-18T14:03:24Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/651/display/redirect?page=changes&gt;
Changes:
[daniele.romagnoli] Updating NetCDF Documentation - 2D coord variables
  Member [127.0.0.1]:5701 - 66818a13-a2d6-4df8-b06d-2944be8728b5 this
Jun 18, 2019 3:19:07 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 32bb9507-63eb-4b0b-b1d2-ef59ef7fcb0d
Jun 18, 2019 3:19:07 PM com.hazelcast.instance.Node
Jun 18, 2019 3:19:07 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 18, 2019 3:19:07 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 160 ms.
Jun 18, 2019 3:19:07 PM com.hazelcast.core.LifecycleService
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.148 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.843 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.611 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.763 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.655 s]
[INFO] Main Module ........................................ SUCCESS [ 53.764 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.051 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:32 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 38.414 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.580 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.105 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.493 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.615 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:23 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:06 min]
[INFO] Web Map Service Module ............................. FAILURE [01:35 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.919 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.331 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.185 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.056 s]
[INFO] Core UI Module ..................................... SUCCESS [ 47.130 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.371 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.035 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 44.222 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.282 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.403 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.053 s]
[INFO] Printing Module .................................... SUCCESS [ 6.997 s]
[INFO] Community Space .................................... SUCCESS [ 0.054 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.061 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.271 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.588 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.534 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.151 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.072 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.195 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.049 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.102 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.060 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.366 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.869 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 48.631 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.232 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.295 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.089 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.324 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.059 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.860 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.252 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.300 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.367 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.105 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.388 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.508 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.503 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.566 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 21.376 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.428 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.016 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.485 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.878 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.018 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.069 s]
[INFO] Total time: 10:02 min (Wall Clock)
[INFO] Finished at: 2019-06-18T15:19:10Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/652/display/redirect&gt;
[...truncated 2.84 MB...]
  Member [127.0.0.1]:5702 - b7b7afa8-c8f1-4e3e-a2f7-bb00904fd32c
Jun 19, 2019 1:46:56 AM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - b5e43f29-1fe8-4c46-a22b-c5d515c13f06
  Member [127.0.0.1]:5702 - b7b7afa8-c8f1-4e3e-a2f7-bb00904fd32c this
Jun 19, 2019 1:46:57 AM com.hazelcast.core.LifecycleService
Jun 19, 2019 1:46:57 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 19, 2019 1:46:57 AM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 19, 2019 1:46:57 AM com.hazelcast.internal.partition.impl.MigrationManager
Jun 19, 2019 1:46:57 AM com.hazelcast.instance.Node
Jun 19, 2019 1:46:57 AM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 19, 2019 1:46:57 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - b7b7afa8-c8f1-4e3e-a2f7-bb00904fd32c
Jun 19, 2019 1:46:57 AM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - b5e43f29-1fe8-4c46-a22b-c5d515c13f06 this
Jun 19, 2019 1:46:57 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: b7b7afa8-c8f1-4e3e-a2f7-bb00904fd32c
Jun 19, 2019 1:46:57 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 171 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.179 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.847 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 23.693 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.960 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.701 s]
[INFO] Main Module ........................................ SUCCESS [01:08 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:21 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.340 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 24.874 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.595 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.498 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.632 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:22 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:07 min]
[INFO] Web Map Service Module ............................. FAILURE [01:49 min]
[INFO] gs-rest ............................................ SUCCESS [ 8.107 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.584 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.998 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.126 s]
[INFO] Core UI Module ..................................... SUCCESS [ 54.931 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.452 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.042 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 59.170 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 44.541 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.763 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.412 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.026 s]
[INFO] Printing Module .................................... SUCCESS [ 31.700 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.612 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.228 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.579 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.438 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.122 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.256 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.227 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 10.663 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.191 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.017 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.409 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.758 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.016 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 50.226 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.153 s]
[INFO] Excel Output Format ................................ SUCCESS [ 13.212 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.398 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.624 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.357 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.803 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.008 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.087 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.528 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.030 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.019 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.382 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.267 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.547 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.676 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 22.825 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.403 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.009 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.014 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.014 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.007 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 24.076 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 3.560 s]
[INFO] Total time: 11:41 min (Wall Clock)
[INFO] Finished at: 2019-06-19T01:46:58Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/653/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Initial concept of Spring MVC like API support
[Andrea Aime] Collection description operation
[Andrea Aime] Migrating from ogc to ogcapi module
[Andrea Aime] Switching from api/ to ogc/ and adding conformance output
[Andrea Aime] OpenAPI integration, some fixes to pom wiring
[Andrea Aime] Assembly descriptor
[Andrea Aime] Adding styles and swagger support to make HTML pages more functional
[Andrea Aime] Removing extra dependencies breaking the build
Started by an SCM change
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-java11/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-java11/lastSuccessful
  at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
  at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
  at java.nio.file.Files.deleteIfExists(Files.java:1165)
  at hudson.Util.createSymlink(Util.java:1193)
  at hudson.model.Run.createSymlink(Run.java:1955)
  at hudson.model.Run.updateSymlinks(Run.java:1936)
  at hudson.model.Run.execute(Run.java:1814)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:97)
  at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-java11/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-java11/lastStable
  at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on FleetCloud i-03a1b471e243104be (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-java11/ws/&gt;
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <https://build.geoserver.org/job/geoserver-java11/ws/geoserver&gt; # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 88d91dc0f419f9784b91344eace24f983d69c7ae (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 88d91dc0f419f9784b91344eace24f983d69c7ae
Commit message: "Merge pull request #3591 from aaime/api"
> git rev-list --no-walk 5304cda70a4ed6b20575a864607cd69b0dca4386 # timeout=10
[java11] $ /bin/sh -xe /tmp/jenkins3992352021664767847.sh
+ mkdir ./m2
mkdir: cannot create directory ‘./m2’: File exists
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/geoserver-java11/654/display/redirect&gt;
[...truncated 2.85 MB...]
Jun 19, 2019 5:12:35 PM com.hazelcast.core.LifecycleService
Jun 19, 2019 5:12:35 PM com.hazelcast.system
Jun 19, 2019 5:12:35 PM com.hazelcast.instance.Node
Jun 19, 2019 5:12:35 PM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
Jun 19, 2019 5:12:35 PM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
Jun 19, 2019 5:12:35 PM com.hazelcast.internal.diagnostics.Diagnostics
Jun 19, 2019 5:12:35 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 19, 2019 5:12:35 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - f47f8e42-f93c-4ec6-a800-c5470355f72f this
  Member [127.0.0.1]:5702 - 777f966e-c433-4364-a754-af194dabdba9
  Member [127.0.0.1]:5702 - 777f966e-c433-4364-a754-af194dabdba9 this
Jun 19, 2019 5:12:36 PM com.hazelcast.core.LifecycleService
Jun 19, 2019 5:12:36 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 19, 2019 5:12:36 PM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 19, 2019 5:12:36 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 136
Jun 19, 2019 5:12:36 PM com.hazelcast.instance.Node
Jun 19, 2019 5:12:36 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 19, 2019 5:12:36 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 777f966e-c433-4364-a754-af194dabdba9
Jun 19, 2019 5:12:36 PM com.hazelcast.internal.cluster.ClusterService
Jun 19, 2019 5:12:36 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 777f966e-c433-4364-a754-af194dabdba9
Jun 19, 2019 5:12:36 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 358 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 9 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.905 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 33.170 s]
[INFO] Core Platform Module ............................... SUCCESS [ 27.728 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.165 s]
[INFO] Main Module ........................................ SUCCESS [01:22 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.073 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:25 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 44.916 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 28.232 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.740 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.579 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.260 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:40 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:16 min]
[INFO] Web Map Service Module ............................. FAILURE [02:05 min]
[INFO] gs-rest ............................................ SUCCESS [ 8.125 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:27 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.710 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 14.341 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.123 s]
[INFO] Core UI Module ..................................... SUCCESS [01:05 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.785 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.032 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:07 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 48.564 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.681 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.850 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] Printing Module .................................... SUCCESS [ 30.093 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.652 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.594 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.810 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 3.037 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.804 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.045 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.335 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 13.720 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 4.955 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.019 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.445 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.886 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.560 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.757 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.247 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.466 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.619 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.552 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.239 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 16.784 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.095 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.622 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.326 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.424 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.198 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.042 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.088 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.341 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 26.052 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.730 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.407 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.023 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.254 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.680 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 28.923 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 3.186 s]
[INFO] Total time: 13:17 min (Wall Clock)
[INFO] Finished at: 2019-06-19T17:12:36Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/655/display/redirect&gt;
[...truncated 2.34 MB...]
Jun 19, 2019 7:35:43 PM com.hazelcast.core.LifecycleService
Jun 19, 2019 7:35:43 PM com.hazelcast.system
Jun 19, 2019 7:35:43 PM com.hazelcast.instance.Node
Jun 19, 2019 7:35:43 PM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
Jun 19, 2019 7:35:43 PM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
Jun 19, 2019 7:35:43 PM com.hazelcast.internal.diagnostics.Diagnostics
Jun 19, 2019 7:35:43 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 19, 2019 7:35:43 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - 78d7c7c2-b167-4fcb-bcd9-21715c1dee1d this
  Member [127.0.0.1]:5702 - a5d03504-cf6d-4e2f-9191-17df5038d3f5
  Member [127.0.0.1]:5702 - a5d03504-cf6d-4e2f-9191-17df5038d3f5 this
Jun 19, 2019 7:35:43 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 19, 2019 7:35:43 PM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 19, 2019 7:35:44 PM com.hazelcast.core.LifecycleService
Jun 19, 2019 7:35:44 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 19, 2019 7:35:44 PM com.hazelcast.instance.Node
Jun 19, 2019 7:35:44 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 19, 2019 7:35:44 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - a5d03504-cf6d-4e2f-9191-17df5038d3f5
Jun 19, 2019 7:35:44 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: a5d03504-cf6d-4e2f-9191-17df5038d3f5
Jun 19, 2019 7:35:44 PM com.hazelcast.internal.cluster.ClusterService
Members {size:1, ver:3} [
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Jun 19, 2019 7:35:44 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 249 ms.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 8 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.513 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.595 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.110 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.985 s]
[INFO] Main Module ........................................ SUCCESS [01:16 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.118 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:34 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 47.192 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 28.805 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.008 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.847 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.915 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:56 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:30 min]
[INFO] Web Map Service Module ............................. FAILURE [02:15 min]
[INFO] gs-rest ............................................ SUCCESS [ 9.729 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:30 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.623 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.762 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.077 s]
[INFO] Core UI Module ..................................... SUCCESS [01:10 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.307 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.037 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:24 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 53.394 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.648 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.887 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.038 s]
[INFO] Printing Module .................................... SUCCESS [ 35.011 s]
[INFO] Community Space .................................... SUCCESS [ 0.042 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.984 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.229 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.590 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.071 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.060 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.047 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.045 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.983 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.048 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.018 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.513 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.913 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:03 min]
[INFO] OGR WPS ............................................ SUCCESS [ 6.027 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.956 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.584 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.443 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.213 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.225 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.986 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.940 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.447 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.769 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.080 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.459 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 15.325 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.033 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.995 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 6.004 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 29.095 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.423 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.996 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.028 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.548 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.688 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 13.461 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.143 s]
[INFO] Total time: 13:08 min (Wall Clock)
[INFO] Finished at: 2019-06-19T19:35:44Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/656/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Whoops, adding missing file
[...truncated 2.86 MB...]
Jun 20, 2019 9:36:53 AM com.hazelcast.core.LifecycleService
Jun 20, 2019 9:36:53 AM com.hazelcast.system
Jun 20, 2019 9:36:53 AM com.hazelcast.instance.Node
Jun 20, 2019 9:36:53 AM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
Jun 20, 2019 9:36:53 AM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
Jun 20, 2019 9:36:53 AM com.hazelcast.internal.diagnostics.Diagnostics
Jun 20, 2019 9:36:53 AM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 20, 2019 9:36:53 AM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - 8f554064-d2d0-46a8-b5af-5b10f49bbbda this
  Member [127.0.0.1]:5702 - f2b6fa84-9f5a-48be-9957-01bada15297b
  Member [127.0.0.1]:5702 - f2b6fa84-9f5a-48be-9957-01bada15297b this
Jun 20, 2019 9:36:54 AM com.hazelcast.core.LifecycleService
Jun 20, 2019 9:36:54 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 20, 2019 9:36:54 AM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 20, 2019 9:36:54 AM com.hazelcast.internal.partition.impl.MigrationManager
Jun 20, 2019 9:36:54 AM com.hazelcast.instance.Node
Jun 20, 2019 9:36:54 AM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 20, 2019 9:36:54 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - f2b6fa84-9f5a-48be-9957-01bada15297b
Jun 20, 2019 9:36:54 AM com.hazelcast.internal.cluster.ClusterService
Jun 20, 2019 9:36:54 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: f2b6fa84-9f5a-48be-9957-01bada15297b
Jun 20, 2019 9:36:54 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 132 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.681 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 23.283 s]
[INFO] Core Platform Module ............................... SUCCESS [ 24.225 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.122 s]
[INFO] Main Module ........................................ SUCCESS [01:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.037 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.314 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 24.872 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.487 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 10.932 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.948 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:12 min]
[INFO] Web Feature Service Module ......................... SUCCESS [ 59.468 s]
[INFO] Web Map Service Module ............................. FAILURE [01:39 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 6.941 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:08 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.621 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.786 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.069 s]
[INFO] Core UI Module ..................................... SUCCESS [ 49.202 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 5.635 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Core Module ............................ SUCCESS [ 54.391 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 41.560 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.265 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.724 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.028 s]
[INFO] Printing Module .................................... SUCCESS [ 25.713 s]
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.364 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.759 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 5.899 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.129 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.123 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.912 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.228 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.341 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.046 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.015 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.325 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.224 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.013 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 45.129 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.611 s]
[INFO] Excel Output Format ................................ SUCCESS [ 10.627 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.029 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.510 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.675 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.563 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.536 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.246 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.028 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.135 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.334 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.564 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.025 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.045 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.271 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 24.623 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.014 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.804 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.375 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.012 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.730 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.770 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.854 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 3.199 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:53 min (Wall Clock)
[INFO] Finished at: 2019-06-20T09:36:54Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user etj@anonymised.com
Not sending mail to unregistered user milkymike45@anonymised.com
Not sending mail to unregistered user niels@anonymised.com
Not sending mail to unregistered user gabriel.roldan@anonymised.com
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/657/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] Change staging directory from release to distribution
[Jody Garnett] minor updates to release instructions
[...truncated 2.33 MB...]
  Member [127.0.0.1]:5702 - 929adb46-cce6-429b-b0a8-450f504ddb5c
Jun 21, 2019 8:28:54 AM com.hazelcast.internal.cluster.ClusterService
Members {size:2, ver:2} [
  Member [127.0.0.1]:5701 - 990a0724-a52d-4fb8-997d-6b32e8f88356
  Member [127.0.0.1]:5702 - 929adb46-cce6-429b-b0a8-450f504ddb5c this
Jun 21, 2019 8:28:55 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Jun 21, 2019 8:28:55 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jun 21, 2019 8:28:55 AM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Jun 21, 2019 8:28:55 AM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 135
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.333 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
Jun 21, 2019 8:28:55 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
Jun 21, 2019 8:28:55 AM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 21, 2019 8:28:55 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 929adb46-cce6-429b-b0a8-450f504ddb5c
Jun 21, 2019 8:28:55 AM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - 990a0724-a52d-4fb8-997d-6b32e8f88356 this
Jun 21, 2019 8:28:55 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 929adb46-cce6-429b-b0a8-450f504ddb5c
Jun 21, 2019 8:28:55 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 5 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.051 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.237 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.367 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.864 s]
[INFO] Main Module ........................................ SUCCESS [ 45.531 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.042 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:23 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.376 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 17.831 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.911 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 9.630 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.817 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:07 min]
[INFO] Web Feature Service Module ......................... SUCCESS [ 55.678 s]
[INFO] Web Map Service Module ............................. FAILURE [01:21 min]
[INFO] gs-rest ............................................ SUCCESS [ 6.568 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:03 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 8.806 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.338 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.047 s]
[INFO] Core UI Module ..................................... SUCCESS [ 40.075 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.576 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.031 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 52.771 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 39.281 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.078 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.414 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 33.838 s]
[INFO] Community Space .................................... SUCCESS [ 0.024 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.432 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.411 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 5.576 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.392 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.254 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.945 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.247 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.507 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.349 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.355 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.118 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.015 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 43.760 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.379 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.495 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.705 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.523 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.310 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.523 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.824 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.026 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.519 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.025 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.698 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.348 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.694 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.026 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.884 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.044 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 20.565 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.018 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.428 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.369 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.016 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.545 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.047 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 22.320 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.485 s]
[INFO] Total time: 09:20 min (Wall Clock)
[INFO] Finished at: 2019-06-21T08:28:55Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/658/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] [GEOS-9256]: fixed conflict between params-extractor and monitor
  Member [127.0.0.1]:5702 - 905c9713-0e75-46bc-8a41-a545c583be12
Jun 21, 2019 9:01:15 AM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - fe207dd5-7416-4a15-a7df-c965d393fd47
  Member [127.0.0.1]:5702 - 905c9713-0e75-46bc-8a41-a545c583be12 this
Jun 21, 2019 9:01:16 AM com.hazelcast.core.LifecycleService
Jun 21, 2019 9:01:16 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 21, 2019 9:01:16 AM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 21, 2019 9:01:16 AM com.hazelcast.internal.partition.impl.MigrationManager
Jun 21, 2019 9:01:16 AM com.hazelcast.instance.Node
Jun 21, 2019 9:01:16 AM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 21, 2019 9:01:16 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 905c9713-0e75-46bc-8a41-a545c583be12
Jun 21, 2019 9:01:16 AM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - fe207dd5-7416-4a15-a7df-c965d393fd47 this
Jun 21, 2019 9:01:16 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 905c9713-0e75-46bc-8a41-a545c583be12
Jun 21, 2019 9:01:16 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 133 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 6 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.975 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.433 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 24.578 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.408 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.050 s]
[INFO] Main Module ........................................ SUCCESS [01:10 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.063 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:19 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.961 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.207 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.609 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 10.206 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.003 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:09 min]
[INFO] Web Map Service Module ............................. FAILURE [01:41 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.805 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.205 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.097 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.132 s]
[INFO] Core UI Module ..................................... SUCCESS [ 53.462 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.889 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.034 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 54.765 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 40.903 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.975 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.520 s]
[INFO] Printing Module .................................... SUCCESS [ 36.744 s]
[INFO] Community Space .................................... SUCCESS [ 0.020 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.018 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.759 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.723 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 5.734 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.168 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.351 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.906 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.241 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.625 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.402 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.313 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.254 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.018 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 44.536 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.525 s]
[INFO] Excel Output Format ................................ SUCCESS [ 10.432 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.539 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.778 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.677 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.677 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.009 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.027 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.240 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.328 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.399 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.027 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.762 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.242 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 21.036 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.015 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.416 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.524 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.867 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.360 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 26.357 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.818 s]
[INFO] Total time: 11:03 min (Wall Clock)
[INFO] Finished at: 2019-06-21T09:01:17Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/659/display/redirect?page=changes&gt;
Changes:
[noreply] [GEOS-9259]: renamed onelogin community module to saml and added several
[...truncated 2.30 MB...]
  Member [127.0.0.1]:5702 - 80269d7e-0f2b-4b57-ba18-caff6b942d1d
Jun 21, 2019 6:03:36 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - f8829d15-e4d8-4ebd-bd20-ac27d3a0090a
  Member [127.0.0.1]:5702 - 80269d7e-0f2b-4b57-ba18-caff6b942d1d this
Jun 21, 2019 6:03:36 PM com.hazelcast.core.LifecycleService
Jun 21, 2019 6:03:36 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 21, 2019 6:03:36 PM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 21, 2019 6:03:36 PM com.hazelcast.internal.partition.impl.MigrationManager
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.321 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Jun 21, 2019 6:03:37 PM com.hazelcast.instance.Node
Jun 21, 2019 6:03:37 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 21, 2019 6:03:37 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 80269d7e-0f2b-4b57-ba18-caff6b942d1d
Jun 21, 2019 6:03:37 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - f8829d15-e4d8-4ebd-bd20-ac27d3a0090a this
Jun 21, 2019 6:03:37 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 80269d7e-0f2b-4b57-ba18-caff6b942d1d
Jun 21, 2019 6:03:37 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 21, 2019 6:03:37 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 547 ms.
Jun 21, 2019 6:03:37 PM com.hazelcast.core.LifecycleService
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.389 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 3.041 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.234 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.237 s]
[INFO] Main Module ........................................ SUCCESS [ 59.742 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.052 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:27 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 46.054 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.290 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.162 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.314 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.550 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:31 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:12 min]
[INFO] gs-rest ............................................ SUCCESS [ 8.136 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:23 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 13.181 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 15.081 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.055 s]
[INFO] Core UI Module ..................................... SUCCESS [ 52.165 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.900 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:10 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 49.700 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.632 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.130 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.040 s]
[INFO] Printing Module .................................... SUCCESS [ 38.121 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.040 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.549 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.501 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.822 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.534 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.273 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.412 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.274 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.196 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.334 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.030 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.436 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.750 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 59.850 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.258 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.126 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.533 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.579 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.560 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.994 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.100 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.138 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.689 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.392 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.580 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.217 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.056 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.916 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 6.529 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 27.841 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.038 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.059 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.637 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.027 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.619 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.703 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 26.541 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 3.309 s]
[INFO] Total time: 11:48 min (Wall Clock)
[INFO] Finished at: 2019-06-21T18:03:37Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/660/display/redirect?page=changes&gt;
Changes:
[bradh] docs: Update user manual to reflect modified mapbox vector tiles MIME
[...truncated 2.84 MB...]
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is STARTED
Jun 22, 2019 11:17:19 AM com.hazelcast.system
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast 3.11.1 (20181218 - d294f31) starting at [127.0.0.1]:5702
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Copyright (c) 2008-2018, Hazelcast, Inc. All Rights Reserved.
Jun 22, 2019 11:17:19 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] A non-empty group password is configured for the Hazelcast member. Starting with Hazelcast version 3.8.2, members with the same group name, but with different group passwords (that do not use authentication) form a cluster. The group password configuration will be removed completely in a future release.
Jun 22, 2019 11:17:19 AM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Backpressure is disabled
Jun 22, 2019 11:17:19 AM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Starting 8 partition threads and 5 generic threads (1 dedicated for priority tasks)
Jun 22, 2019 11:17:19 AM com.hazelcast.internal.diagnostics.Diagnostics
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Diagnostics disabled. To enable add -Dhazelcast.diagnostics.enabled=true to the JVM arguments.
Jun 22, 2019 11:17:19 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTING
Jun 22, 2019 11:17:19 AM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 22, 2019 11:17:19 AM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - b9a153cc-4000-4a04-9a29-4ca1de0d5ec4 this
  Member [127.0.0.1]:5702 - a68c400f-785f-44dd-8a4c-86b6a414d1a9
  Member [127.0.0.1]:5702 - a68c400f-785f-44dd-8a4c-86b6a414d1a9 this
Jun 22, 2019 11:17:19 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 22, 2019 11:17:19 AM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 22, 2019 11:17:20 AM com.hazelcast.core.LifecycleService
Jun 22, 2019 11:17:20 AM com.hazelcast.internal.partition.impl.MigrationManager
Jun 22, 2019 11:17:20 AM com.hazelcast.instance.Node
Jun 22, 2019 11:17:20 AM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 22, 2019 11:17:20 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - a68c400f-785f-44dd-8a4c-86b6a414d1a9
Jun 22, 2019 11:17:20 AM com.hazelcast.internal.cluster.ClusterService
Jun 22, 2019 11:17:20 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: a68c400f-785f-44dd-8a4c-86b6a414d1a9
Jun 22, 2019 11:17:20 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 128 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.664 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 33.522 s]
[INFO] Core Platform Module ............................... SUCCESS [ 28.623 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.672 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.055 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:16 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.138 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.435 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.532 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 9.664 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.430 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 57.295 s]
[INFO] Web Map Service Module ............................. FAILURE [01:49 min]
[INFO] gs-rest ............................................ SUCCESS [ 6.486 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:05 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 8.588 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.200 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.095 s]
[INFO] Core UI Module ..................................... SUCCESS [ 51.681 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.309 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.025 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 54.213 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 39.513 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 12.443 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.471 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.025 s]
[INFO] Printing Module .................................... SUCCESS [ 30.826 s]
[INFO] Community Space .................................... SUCCESS [ 0.017 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.016 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.339 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 5.747 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.575 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.453 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 3.191 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.233 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.375 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 4.426 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.013 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.338 s]
[INFO] OGR WFS ............................................ SUCCESS [ 3.845 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.012 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 46.064 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.392 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.184 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.634 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.486 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.920 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.702 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 15.230 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 7.665 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.482 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.920 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.023 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.313 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.471 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.032 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.484 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.002 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 19.965 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.200 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.415 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.013 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.331 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.266 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 26.407 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 4.365 s]
[INFO] Total time: 11:08 min (Wall Clock)
[INFO] Finished at: 2019-06-22T11:17:20Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user bradh@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/661/display/redirect?page=changes&gt;
Changes:
[bradh] [GEOS-9261] Update name to id in OGC API Collection
[...truncated 233.66 KB...]
[INFO]
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO] Skipping GeoFence security integration
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO] Skipping GeoFence Server
[INFO]
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 33.599 s]
[INFO] Core Platform Module ............................... FAILURE [ 17.879 s]
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.090 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] Total time: 53.476 s (Wall Clock)
[INFO] Finished at: 2019-06-23T10:52:31Z
[ERROR] Failed to execute goal on project gs-platform: Could not resolve dependencies for project org.geoserver:gs-platform:jar:2.16-SNAPSHOT: Could not transfer artifact xmlunit:xmlunit:jar:1.3 from/to central (https://repo.maven.apache.org/maven2): Connection reset -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
See <https://build.geoserver.org/job/geoserver-java11/662/display/redirect?page=changes&gt;
Changes:
[niels] GEOS-9117 add wcs and wmts endpoint placeholders
[...truncated 2.14 MB...]
  Member [127.0.0.1]:5701 - 06d87110-e716-4864-a23b-8a0c4e154f5f this
Jun 23, 2019 12:52:28 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 54f88eef-e5db-4f10-8792-a93b2c753926
Jun 23, 2019 12:52:28 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
Jun 23, 2019 12:52:28 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Jun 23, 2019 12:52:28 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 162 ms.
Jun 23, 2019 12:52:28 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 7 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.124 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
WARNING: Illegal reflective access by org.geotools.image.ImageWorker (<https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geotools/gt-coverage/22-SNAPSHOT/gt-coverage-22-SNAPSHOT.jar)> to constructor com.sun.imageio.plugins.jpeg.JPEGImageWriterSpi()
  at org.geotools.image.ImageWorker.<clinit>(ImageWorker.java:224)
  at org.geoserver.config.impl.JAIEXTInfoImpl.<clinit>(JAIEXTInfoImpl.java:28)
  at org.geoserver.config.impl.JAIInfoImpl.<init>(JAIInfoImpl.java:54)
  at org.geoserver.config.impl.GeoServerInfoImpl.<init>(GeoServerInfoImpl.java:26)
  at org.geoserver.config.impl.GeoServerFactoryImpl.createGlobal(GeoServerFactoryImpl.java:38)
  at org.geoserver.config.impl.DefaultGeoServerFacade.<init>(DefaultGeoServerFacade.java:41)
  at org.geoserver.config.impl.GeoServerImpl.<init>(GeoServerImpl.java:54)
  at org.geoserver.data.test.SystemTestData.createConfig(SystemTestData.java:324)
  at org.geoserver.data.test.SystemTestData.setUp(SystemTestData.java:137)
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:129)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.583 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.406 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.620 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.062 s]
[INFO] Main Module ........................................ SUCCESS [ 46.600 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 38.088 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.502 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.837 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 9.774 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.969 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:14 min]
[INFO] Web Feature Service Module ......................... SUCCESS [ 57.998 s]
[INFO] Web Map Service Module ............................. FAILURE [01:26 min]
[INFO] gs-rest ............................................ SUCCESS [ 6.832 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.463 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.600 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.051 s]
[INFO] Core UI Module ..................................... SUCCESS [ 41.628 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.809 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.049 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 55.705 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 41.742 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.438 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.037 s]
[INFO] Printing Module .................................... SUCCESS [ 6.116 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.548 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.024 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.107 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.102 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.135 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.149 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.054 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.921 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.048 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.018 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.320 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.328 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 47.539 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.926 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.470 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.060 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.307 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.090 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.559 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 6.969 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.398 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.322 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.053 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.377 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.848 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.043 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.177 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.400 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 20.998 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.020 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.862 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.745 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.312 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.742 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 8.102 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.067 s]
[INFO] Total time: 09:10 min (Wall Clock)
[INFO] Finished at: 2019-06-23T12:52:31Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/663/display/redirect?page=changes&gt;
Changes:
[bradh] [GEOS-9262] Update ogcapi module to return title and description in
[...truncated 2.65 MB...]
  Member [127.0.0.1]:5701 - 63eda2ee-57ff-4413-941c-8fc5cddf4aa1
  Member [127.0.0.1]:5702 - 29d4f3db-e22f-48e2-9e44-046211e8a71f this
Jun 23, 2019 2:16:16 PM com.hazelcast.core.LifecycleService
Jun 23, 2019 2:16:16 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 23, 2019 2:16:16 PM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 23, 2019 2:16:16 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 136
Jun 23, 2019 2:16:16 PM com.hazelcast.instance.Node
Jun 23, 2019 2:16:16 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 23, 2019 2:16:16 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 29d4f3db-e22f-48e2-9e44-046211e8a71f
Jun 23, 2019 2:16:16 PM com.hazelcast.internal.cluster.ClusterService
Members {size:1, ver:3} [
  Member [127.0.0.1]:5701 - 63eda2ee-57ff-4413-941c-8fc5cddf4aa1 this
Jun 23, 2019 2:16:16 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 29d4f3db-e22f-48e2-9e44-046211e8a71f
Jun 23, 2019 2:16:16 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 160 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.157 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.643 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.690 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.021 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.392 s]
[INFO] Main Module ........................................ SUCCESS [01:07 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.037 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:28 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.915 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 27.308 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.509 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.776 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.230 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:18 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:03 min]
[INFO] Web Map Service Module ............................. FAILURE [01:56 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 6.631 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:19 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.994 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.336 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SUCCESS [ 57.956 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 6.076 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.027 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:00 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 43.680 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.005 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.009 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 35.912 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.970 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.341 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.422 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.634 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.415 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.309 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.236 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 15.418 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 5.998 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.017 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.433 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.891 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.048 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 49.528 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.047 s]
[INFO] Excel Output Format ................................ SUCCESS [ 13.178 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.120 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.630 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.529 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.070 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.396 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.930 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.521 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.030 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.484 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.339 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.224 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.412 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.233 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 23.058 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.013 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.593 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.790 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.012 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.577 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.578 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 26.656 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 3.403 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:26 min (Wall Clock)
[INFO] Finished at: 2019-06-23T14:16:18Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user etj@anonymised.com
Not sending mail to unregistered user milkymike45@anonymised.com
Not sending mail to unregistered user niels@anonymised.com
Not sending mail to unregistered user gabriel.roldan@anonymised.com
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/664/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Adding callback support for Operation, clean up leftovers argument
[Andrea Aime] Feature service core almost rewrote
[Andrea Aime] GetFeature working
[Andrea Aime] GetFeature for collections of features working
[Andrea Aime] Completed work on bbox and time filtering, single feature return,
  Member [127.0.0.1]:5701 - f5f5c03d-cfba-4f32-9c9e-f7d45c8a862d this
Jun 23, 2019 8:57:45 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: b7872c0b-9b7f-47be-89e2-67575c023953
Jun 23, 2019 8:57:45 PM com.hazelcast.instance.Node
Jun 23, 2019 8:57:45 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 23, 2019 8:57:45 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 194 ms.
Jun 23, 2019 8:57:45 PM com.hazelcast.core.LifecycleService
Jun 23, 2019 8:57:46 PM com.hazelcast.instance.NodeExtension
Jun 23, 2019 8:57:46 PM com.hazelcast.core.LifecycleService
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.352 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.402 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.668 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.917 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.211 s]
[INFO] Main Module ........................................ SUCCESS [01:01 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.103 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:26 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.872 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.747 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.116 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.162 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.154 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:26 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:13 min]
[INFO] Web Map Service Module ............................. FAILURE [01:44 min]
[INFO] gs-rest ............................................ SUCCESS [ 8.181 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:25 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.262 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.982 s]
[INFO] Core UI Module ..................................... SUCCESS [ 50.812 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.284 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:04 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 48.671 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.172 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.356 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 7.618 s]
[INFO] Community Space .................................... SUCCESS [ 0.035 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.853 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.437 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.469 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.075 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.111 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.142 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.152 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.265 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.070 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.496 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.138 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 53.682 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.742 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.639 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.068 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.374 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.061 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.907 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.786 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.966 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.431 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.035 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.315 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.035 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.397 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.012 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.047 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.204 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.615 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 24.255 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.961 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.742 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.691 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.514 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.042 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.113 s]
[INFO] Total time: 10:48 min (Wall Clock)
[INFO] Finished at: 2019-06-23T20:57:49Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/665/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] [GEOS-9241] Enhance mongodb schema generation. (#3561)
Jun 24, 2019 12:03:48 PM com.hazelcast.internal.cluster.ClusterService
Members {size:2, ver:2} [
  Member [127.0.0.1]:5701 - 163ba1c3-d8fb-4dad-b0b5-0fe0357f51db
  Member [127.0.0.1]:5702 - 65d820fd-711a-40c6-b500-72a8bc1ea433 this
Jun 24, 2019 12:03:49 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Jun 24, 2019 12:03:49 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jun 24, 2019 12:03:49 PM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Jun 24, 2019 12:03:49 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 135
Jun 24, 2019 12:03:49 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
Jun 24, 2019 12:03:49 PM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 24, 2019 12:03:49 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 65d820fd-711a-40c6-b500-72a8bc1ea433
Jun 24, 2019 12:03:49 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - 163ba1c3-d8fb-4dad-b0b5-0fe0357f51db this
Jun 24, 2019 12:03:49 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 65d820fd-711a-40c6-b500-72a8bc1ea433
Jun 24, 2019 12:03:49 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 151 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 8 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.249 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.624 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 24.626 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.222 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.910 s]
[INFO] Main Module ........................................ SUCCESS [01:06 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.046 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.756 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 23.892 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.629 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 10.626 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.895 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:05 min]
[INFO] Web Map Service Module ............................. FAILURE [01:59 min]
[INFO] gs-rest ............................................ SUCCESS [ 8.384 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:14 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.822 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.186 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.092 s]
[INFO] Core UI Module ..................................... SUCCESS [ 59.721 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.268 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.029 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 58.738 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 45.178 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.964 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.111 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.046 s]
[INFO] Printing Module .................................... SUCCESS [ 32.803 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.907 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.027 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.306 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.598 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.219 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.301 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.234 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 10.704 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.478 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.417 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.289 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 45.761 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.366 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.464 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.219 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.546 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.620 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.795 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.527 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.642 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.506 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.026 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.794 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.322 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.218 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.027 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.844 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.844 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 20.695 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.017 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.842 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.887 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.016 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.439 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.402 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 26.623 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.617 s]
[INFO] Total time: 11:37 min (Wall Clock)
[INFO] Finished at: 2019-06-24T12:03:50Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/666/display/redirect?page=changes&gt;
Changes:
[noreply] [GEOS-9264]: moved some message properties to the GWC-S3 module (#3606)
  Member [127.0.0.1]:5701 - 138a9a05-f1a1-4503-a1fc-16dc47677e53 this
Jun 24, 2019 1:02:48 PM com.hazelcast.instance.Node
Jun 24, 2019 1:02:48 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: c225fd6b-ce75-41d3-a4d1-9b87126e424d
Jun 24, 2019 1:02:48 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 24, 2019 1:02:48 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 140 ms.
Jun 24, 2019 1:02:48 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 6 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.054 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.285 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.531 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.560 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.120 s]
[INFO] Main Module ........................................ SUCCESS [ 47.982 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.080 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:20 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.051 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.773 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.051 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 10.075 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.984 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:11 min]
[INFO] Web Feature Service Module ......................... SUCCESS [ 59.750 s]
[INFO] Web Map Service Module ............................. FAILURE [01:24 min]
[INFO] gs-rest ............................................ SUCCESS [ 6.645 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:08 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.861 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.655 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.062 s]
[INFO] Core UI Module ..................................... SUCCESS [ 42.261 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.612 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.032 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 54.248 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 41.697 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.604 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.908 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 6.127 s]
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.426 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 4.923 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.120 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.148 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.113 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.080 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.069 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.050 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.055 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.334 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.121 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 45.550 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.724 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.140 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.058 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.296 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.048 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.568 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 6.681 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.254 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.309 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.028 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.952 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.346 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.745 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.030 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.086 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.290 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 20.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.590 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.414 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.018 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.845 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.414 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 7.954 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.322 s]
[INFO] Total time: 09:06 min (Wall Clock)
[INFO] Finished at: 2019-06-24T13:02:51Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/667/display/redirect?page=changes&gt;
Changes:
[Steve.Ikeoka] [GEOS-9260] Update the session token after a successful login.
[...truncated 2.27 MB...]
Jun 24, 2019 11:56:50 PM com.hazelcast.system
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast 3.11.1 (20181218 - d294f31) starting at [127.0.0.1]:5702
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Copyright (c) 2008-2018, Hazelcast, Inc. All Rights Reserved.
Jun 24, 2019 11:56:50 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] A non-empty group password is configured for the Hazelcast member. Starting with Hazelcast version 3.8.2, members with the same group name, but with different group passwords (that do not use authentication) form a cluster. The group password configuration will be removed completely in a future release.
Jun 24, 2019 11:56:50 PM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Backpressure is disabled
Jun 24, 2019 11:56:50 PM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Starting 8 partition threads and 5 generic threads (1 dedicated for priority tasks)
Jun 24, 2019 11:56:50 PM com.hazelcast.internal.diagnostics.Diagnostics
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Diagnostics disabled. To enable add -Dhazelcast.diagnostics.enabled=true to the JVM arguments.
Jun 24, 2019 11:56:50 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTING
Jun 24, 2019 11:56:50 PM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jun 24, 2019 11:56:50 PM com.hazelcast.internal.cluster.ClusterService
  Member [127.0.0.1]:5701 - b240c6bc-e46b-4e4f-b364-536ed5b35daa this
  Member [127.0.0.1]:5702 - dc93431f-07e7-438d-b0fd-e855df7d3bb9
  Member [127.0.0.1]:5702 - dc93431f-07e7-438d-b0fd-e855df7d3bb9 this
Jun 24, 2019 11:56:51 PM com.hazelcast.core.LifecycleService
Jun 24, 2019 11:56:51 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jun 24, 2019 11:56:51 PM com.hazelcast.internal.partition.impl.PartitionStateManager
Jun 24, 2019 11:56:51 PM com.hazelcast.internal.partition.impl.MigrationManager
Jun 24, 2019 11:56:51 PM com.hazelcast.instance.Node
Jun 24, 2019 11:56:51 PM com.hazelcast.test.mocknetwork.MockConnectionManager
Jun 24, 2019 11:56:51 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - dc93431f-07e7-438d-b0fd-e855df7d3bb9
Jun 24, 2019 11:56:51 PM com.hazelcast.internal.cluster.ClusterService
Jun 24, 2019 11:56:51 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: dc93431f-07e7-438d-b0fd-e855df7d3bb9
Jun 24, 2019 11:56:51 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 125 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.793 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.764 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.641 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.441 s]
[INFO] Main Module ........................................ SUCCESS [ 58.722 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.057 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:24 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.353 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.227 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.002 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.616 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.570 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:04 min]
[INFO] Web Map Service Module ............................. FAILURE [01:31 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.347 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:12 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.113 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.614 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.055 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.370 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.204 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.034 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 53.194 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 40.131 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 12.695 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.621 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.035 s]
[INFO] Printing Module .................................... SUCCESS [ 6.475 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.314 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.237 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 5.586 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.843 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.658 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.230 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.239 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.389 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.676 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.357 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.718 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.016 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 45.054 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.545 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.307 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.845 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.579 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.454 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.683 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.240 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.992 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.537 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.034 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.833 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.023 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.344 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.514 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.031 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.718 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.072 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 19.160 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.373 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.600 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.806 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.493 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.335 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.802 s]
[INFO] Total time: 09:42 min (Wall Clock)
[INFO] Finished at: 2019-06-24T23:56:51Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user Steve.Ikeoka@anonymised.com
Not sending mail to unregistered user bradh@anonymised.com
