See <https://build.geoserver.org/job/geoserver-java11/692/display/redirect?page=changes>
Changes:
[fernandomino7] [GEOS-9276] WMS configuration UI, watermark file URL input allows to
[noreply] Revert "[GEOS-9276] WMS configuration UI, watermark file input allows to
[...truncated 841.02 KB...]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/target/gs-web-sec-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-sec/2.16-SNAPSHOT/gs-web-sec-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/target/gs-web-sec-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-sec/2.16-SNAPSHOT/gs-web-sec-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [72/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 57.73 s - in org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.682 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.556 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.979 s]
[INFO] Main Module ........................................ SUCCESS [ 54.521 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.053 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:23 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [03:37 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.242 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.088 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.063 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.552 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:21 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:33 min]
[INFO] Web Map Service Module ............................. FAILURE [01:34 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 7.709 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [02:54 min]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.696 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.061 s]
[INFO] Core UI Module ..................................... SUCCESS [ 50.832 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 6.875 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.035 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:41 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:13 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 12.991 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.658 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 6.732 s]
[INFO] Community Space .................................... SUCCESS [ 0.030 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.031 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.505 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.959 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.498 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.118 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.230 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.115 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.048 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.400 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.066 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.027 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.631 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.257 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SUCCESS [04:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.360 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.777 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.070 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.354 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.064 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.385 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.187 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.791 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.415 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.032 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.241 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.039 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.346 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.714 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.033 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.780 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.003 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [03:49 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.546 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.019 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.049 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.034 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.018 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.685 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [01:02 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.475 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.355 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 18:36 min (Wall Clock)
[INFO] Finished at: 2019-07-04T09:37:55Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user fernandomino7@anonymised.com
Not sending mail to unregistered user noreply@anonymised.com
