See <https://build.geoserver.org/job/geoserver-java11/831/display/redirect>
[...truncated 1.27 MB...]
[INFO] Copying 27 resources
[INFO] Copying 20 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-importer-web ---
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 77, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 33 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/classes>
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [99/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.106 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.966 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.995 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.291 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 8.445 s]
[INFO] Main Module ........................................ SUCCESS [01:20 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.087 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:43 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 46.869 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.239 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.363 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.926 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.217 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:38 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:40 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.614 s]
[INFO] gs-rest ............................................ SUCCESS [ 10.218 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:01 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:00 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.177 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 15.517 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 11.585 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.189 s]
[INFO] Core UI Module ..................................... SUCCESS [01:17 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 25.997 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 35.069 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.779 s]
[INFO] Demos Module ....................................... SUCCESS [ 15.497 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.623 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.057 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:11 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [08:09 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.594 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.123 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.067 s]
[INFO] Printing Module .................................... SUCCESS [ 28.808 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.148 s]
[INFO] Community Space .................................... SUCCESS [ 0.064 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.058 s]
[INFO] Application Schema Integration Test ................ SUCCESS [07:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.963 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.277 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.935 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.425 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.454 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.245 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.377 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.159 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.936 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.410 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.032 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.551 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.616 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [05:42 min]
[INFO] OGR WPS ............................................ SUCCESS [ 7.272 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.325 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.990 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.722 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.998 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.870 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.745 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 21.262 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 14.282 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.455 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [01:17 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 3.272 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.628 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.451 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 21.691 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.651 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.056 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.463 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.790 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [03:57 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.153 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.030 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 12.165 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.388 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.039 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.523 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [03:37 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.744 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.047 s]
[INFO] Importer Core Module ............................... SUCCESS [ 30.403 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 37.587 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 31.601 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.849 s]
[INFO] GRIB Coverage Format ............................... FAILURE [ 1.254 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.820 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.244 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.387 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.404 s]
[INFO] REST SLD service ................................... SUCCESS [04:55 min]
[INFO] GeoFence security integration ...................... SUCCESS [07:34 min]
[INFO] GeoFence Server .................................... SUCCESS [10:18 min]
[INFO] Authentication by unique url key ................... SUCCESS [06:04 min]
[INFO] BUILD FAILURE
[INFO] Total time: 45:13 min (Wall Clock)
[INFO] Finished at: 2019-08-19T23:28:32Z
[ERROR] Failed to execute goal on project gs-grib: Could not resolve dependencies for project org.geoserver.extension:gs-grib:jar:2.16-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-grib:jar:22-SNAPSHOT -> org.geotools:gt-netcdf:jar:22-SNAPSHOT -> edu.ucar:netcdf4:jar:4.6.11 -> net.java.dev.jna:jna:jar:4.2.2: Failed to read artifact descriptor for net.java.dev.jna:jna:jar:4.2.2: Could not transfer artifact net.java.dev.jna:jna:pom:4.2.2 from/to central (https://repo.maven.apache.org/maven2): <https://build.geoserver.org/job/geoserver-java11/ws/m2/net/java/dev/jna/jna/4.2.2/jna-4.2.2.pom.part> (No such file or directory) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-grib
