[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #864
See <https://build.geoserver.org/job/geoserver-java11/864/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9308] LayerInfo.getAbstract always returns nothing as the
[...truncated 1.16 MB...]
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.901 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.394 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [98/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 183.073 s - in org.geoserver.importer.bdb.BDBImportStoreTest
[INFO] Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.473 s - in org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.987 s - in org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.998 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.277 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.547 s]
[INFO] Main Module ........................................ SUCCESS [01:08 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.092 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:42 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [ 0.469 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.883 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.294 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.170 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.621 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:30 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:53 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:11 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 22.700 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.985 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [06:43 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:40 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 13.184 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 15.209 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [04:06 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.057 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SUCCESS [01:59 min]
[INFO] GWC UI Module ...................................... SUCCESS [02:27 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.101 s]
[INFO] Demos Module ....................................... SUCCESS [ 13.975 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.171 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.056 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:11 min]
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.247 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.770 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.046 s]
[INFO] Printing Module .................................... SUCCESS [ 8.555 s]
[INFO] Community Space .................................... SUCCESS [ 0.030 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.047 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:39 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.216 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.403 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.394 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.084 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.244 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.107 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.327 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.418 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.096 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.030 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.590 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.942 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:11 min]
[INFO] OGR WPS ............................................ SUCCESS [ 6.199 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.604 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.072 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.518 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.066 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.996 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.648 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 17.522 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.589 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.487 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.036 s]
[INFO] Core Monitor Extension ............................. SUCCESS [09:24 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.940 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.423 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.994 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 21.898 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.166 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.101 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.252 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.849 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 27.607 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.413 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.669 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.077 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.023 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.759 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 46.022 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.692 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.050 s]
[INFO] Importer Core Module ............................... SUCCESS [ 27.725 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 30.804 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:08 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.708 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.556 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.344 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [03:32 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.248 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 8.887 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.466 s]
[INFO] REST SLD service ................................... SUCCESS [ 47.256 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 17.493 s]
[INFO] GeoFence Server .................................... SUCCESS [03:39 min]
[INFO] Authentication by unique url key ................... SUCCESS [ 45.681 s]
[INFO] BUILD FAILURE
[INFO] Total time: 35:04 min (Wall Clock)
[INFO] Finished at: 2019-08-22T07:27:07Z
[ERROR] Failed to execute goal on project gs-sec-jdbc: Could not resolve dependencies for project org.geoserver.security:gs-sec-jdbc:jar:2.16-SNAPSHOT: Failed to collect dependencies at simple-jndi:simple-jndi:jar:0.11.4.1: Failed to read artifact descriptor for simple-jndi:simple-jndi:jar:0.11.4.1: Could not transfer artifact simple-jndi:simple-jndi:pom:0.11.4.1 from/to central (https://repo.maven.apache.org/maven2): Connection reset -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-sec-jdbc
See <https://build.geoserver.org/job/geoserver-java11/865/display/redirect&gt;
