[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #882
See <https://build.geoserver.org/job/geoserver-java11/882/display/redirect&gt;
[...truncated 150.28 KB...]
[INFO]
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO] Skipping REST SLD service
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping GeoFence security integration
[INFO]
[INFO] Skipping Authentication by unique url key
[INFO]
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 28.826 s]
[INFO] Core Platform Module ............................... SKIPPED
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 30.919 s (Wall Clock)
[INFO] Finished at: 2019-08-23T15:51:10Z
[ERROR] Failed to execute goal pl.project13.maven:git-commit-id-plugin:2.1.15:revision (default) on project geoserver: Could not complete Mojo execution... Could not get HEAD Ref, are you sure you have some commits in the dotGitDirectory? -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <https://build.geoserver.org/job/geoserver-java11/883/display/redirect&gt;
[...truncated 253.33 KB...]
[ERROR] location: class org.geoserver.platform.Operation
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/Operation.java&gt;:\[65,12\] cannot find symbol
[ERROR] symbol: class Method
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/Operation.java&gt;:\[70,12\] cannot find symbol
[ERROR] symbol: class Object
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/Operation.java&gt;:\[74,27\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/Operation.java&gt;:\[100,12\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[58,8\] cannot access org.geoserver
[ERROR] zip END header not found
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[58,46\] cannot find symbol
[ERROR] symbol: class DefaultResourceLoader
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[59,20\] cannot find symbol
[ERROR] symbol: class ResourceStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[59,35\] cannot find symbol
[ERROR] symbol: class ServletContextAware
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[60,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.platform.GeoServerResourceLoader
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[69,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[72,5\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[90,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[100,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[105,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[121,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[130,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[138,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[160,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[172,29\] cannot find symbol
[ERROR] symbol: class URL
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[172,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[184,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[196,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[196,46\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[210,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[210,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[210,63\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[235,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[235,49\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[254,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[254,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[254,66\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[275,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[275,66\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[287,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[287,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[287,83\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[299,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[299,63\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[312,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[312,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[312,80\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[322,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[322,60\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[337,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[337,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[337,77\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[353,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[353,57\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[370,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[370,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[370,74\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[384,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[384,55\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[398,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[398,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[413,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[413,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[413,72\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[432,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[432,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[432,69\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[447,85\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[458,61\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[458,81\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[469,61\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[469,74\] cannot find symbol
[ERROR] symbol: class Class
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[470,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[488,73\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[488,13\] cannot find symbol
[ERROR] symbol: class InputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[489,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[532,55\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[631,12\] cannot find symbol
[ERROR] symbol: class ResourceNotificationDispatcher
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[635,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/OWS20Exception.java&gt;:\[19,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/ServiceException.java&gt;:\[8,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/ServiceException.java&gt;:\[8,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/ServiceException.java&gt;:\[8,17\] import requires canonical name for <any>.ArrayList
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/OWS20Exception.java&gt;:\[21,26\] cannot find symbol
[ERROR] location: class org.geoserver.platform.OWS20Exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/OWS20Exception.java&gt;:\[29,30\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] location: class org.geoserver.platform.OWS20Exception.OWSExceptionCode
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java&gt;:\[13,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java&gt;:\[13,18\] cannot access org.apache.commons
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java&gt;:\[13,29\] import requires canonical name for <any>.io.IOUtils
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/ModuleStatusImpl.java&gt;:\[14,17\] cannot access java.util.logging
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/platform/src/main/java/org/geoserver/platform/ModuleStatusImpl.java&gt;:\[16,11\] cannot access org.geotools
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
See <https://build.geoserver.org/job/geoserver-java11/884/display/redirect&gt;
