See <https://build.geoserver.org/job/geoserver-java11/979/display/redirect>
[...truncated 2.12 MB...]
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-grib/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-grib/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/extension/gs-grib/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-grib/2.16-SNAPSHOT/maven-metadata.xml (1.4 kB at 15 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-jts-wrapper/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-jts-wrapper/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/22-SNAPSHOT/maven-metadata.xml (986 B at 35 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/22-SNAPSHOT/gt-jts-wrapper-22-20190820.222408-157.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/22-SNAPSHOT/gt-jts-wrapper-22-20190820.222408-157.pom (3.4 kB at 264 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-netcdf/2.16-SNAPSHOT/gs-netcdf-2.16-20190830.025434-551.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-grib/2.16-SNAPSHOT/gs-grib-2.16-20190830.025409-551.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-grib/22-SNAPSHOT/gt-grib-22-20190820.222514-157.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/edu/ucar/grib/4.6.11/grib-4.6.11.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/edu/ucar/jj2000/5.3/jj2000-5.3.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-netcdf/2.16-SNAPSHOT/gs-netcdf-2.16-20190830.025434-551.jar (10 kB at 796 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/22-SNAPSHOT/gt-jts-wrapper-22-20190820.222408-157.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-grib/22-SNAPSHOT/gt-grib-22-20190820.222514-157.jar (8.1 kB at 449 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-grib/2.16-SNAPSHOT/gs-grib-2.16-20190830.025409-551.jar (5.1 kB at 223 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/edu/ucar/jj2000/5.3/jj2000-5.3.jar (544 kB at 11 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/22-SNAPSHOT/gt-jts-wrapper-22-20190820.222408-157.jar (84 kB at 1.6 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/edu/ucar/grib/4.6.11/grib-4.6.11.jar (5.3 MB at 40 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-netcdf-out ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-netcdf-out ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-netcdf-out ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-netcdf-out ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-netcdf-out ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-netcdf-out ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-netcdf-out ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-netcdf-out ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-netcdf-out ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-netcdf-out ---
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 31.786 s]
[INFO] Core Platform Module ............................... SUCCESS [ 24.461 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.299 s]
[INFO] Main Module ........................................ SUCCESS [01:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.071 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:26 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.796 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 26.623 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.669 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.489 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.529 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:26 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:15 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.956 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.397 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:29 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:26 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.843 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.645 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.770 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.174 s]
[INFO] Core UI Module ..................................... SUCCESS [01:10 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 23.704 s]
[INFO] GWC UI Module ...................................... FAILURE [ 0.643 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.799 s]
[INFO] Demos Module ....................................... SUCCESS [01:02 min]
[INFO] WCS UI Module ...................................... FAILURE [ 0.248 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.032 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:07 min]
[INFO] Security UI JDBC Module ............................ FAILURE [05:01 min]
[INFO] Security UI LDAP Module ............................ FAILURE [ 12.877 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.500 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 26.022 s]
[INFO] Community Space .................................... SUCCESS [ 0.067 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 6.230 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.765 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.023 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.478 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.618 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.283 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.899 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.245 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.549 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.584 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.242 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.400 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.502 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.018 s]
[INFO] Web Processing Service Module ...................... FAILURE [ 1.149 s]
[INFO] Excel Output Format ................................ SUCCESS [ 13.978 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.200 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.669 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.772 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.054 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.702 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.595 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. FAILURE [ 1.647 s]
[INFO] GeoServer Security Extension Modules ............... FAILURE [ 11.008 s]
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.955 s]
[INFO] GeoServer INSPIRE Extensions ....................... FAILURE [ 0.046 s]
[INFO] GeoServer CSS Styling .............................. FAILURE [ 4.204 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.581 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.716 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 1.471 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.708 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.017 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions FAILURE [ 1.103 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.463 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.025 s]
[INFO] Importer Core Module ............................... FAILURE [ 4.379 s]
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 23.777 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [02:03 min]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 0.727 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.815 s]
[INFO] Ysld GeoServer Plugin .............................. FAILURE [ 1.131 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.007 s]
[INFO] REST SLD service ................................... FAILURE [06:36 min]
[INFO] GeoFence security integration ...................... FAILURE [ 4.666 s]
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... FAILURE [ 4.007 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:35 min (Wall Clock)
[INFO] Finished at: 2019-08-30T03:06:43Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-web-sec-jdbc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/jdbc/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-sldservice: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-security: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-ldap: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/ldap/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:3.0.2:jar (default-jar) on project gs-geofence: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-authkey: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/authkey/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0-eo-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wps-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-gwc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/gwc/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-monitor-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-inspire: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/inspire/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ysld: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ysld/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wcs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wcs/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-css: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/css/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-importer-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-app-schema-test: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-netcdf-out: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/pom.xml> isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-jdbc
