See <https://build.geoserver.org/job/geoserver-java11/983/display/redirect>
[...truncated 2.06 MB...]
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.pom
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.pom (3.1 kB at 771 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/jasig/cas/client/cas-client/3.4.1/cas-client-3.4.1.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/jasig/cas/client/cas-client/3.4.1/cas-client-3.4.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/jasig/cas/client/cas-client/3.4.1/cas-client-3.4.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jasig/cas/client/cas-client/3.4.1/cas-client-3.4.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jasig/cas/client/cas-client/3.4.1/cas-client-3.4.1.pom (10 kB at 3.3 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/springframework/security/spring-security-cas/5.1.5.RELEASE/spring-security-cas-5.1.5.RELEASE.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/springframework/security/spring-security-cas/5.1.5.RELEASE/spring-security-cas-5.1.5.RELEASE.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/springframework/security/spring-security-cas/5.1.5.RELEASE/spring-security-cas-5.1.5.RELEASE.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/security/spring-security-cas/5.1.5.RELEASE/spring-security-cas-5.1.5.RELEASE.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jasig/cas/client/cas-client-core/3.4.1/cas-client-core-3.4.1.jar (137 kB at 23 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/security/spring-security-cas/5.1.5.RELEASE/spring-security-cas-5.1.5.RELEASE.jar (31 kB at 3.1 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sec-cas ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-sec-cas ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sec-cas ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 26.216 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.308 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.805 s]
[INFO] Main Module ........................................ SUCCESS [01:13 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.044 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:22 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.448 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 23.176 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.574 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.098 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.117 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:20 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:10 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:59 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 17.238 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.858 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 55.133 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.297 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.814 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.070 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.152 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.059 s]
[INFO] GWC UI Module ...................................... FAILURE [ 0.650 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.614 s]
[INFO] Demos Module ....................................... SUCCESS [ 12.178 s]
[INFO] WCS UI Module ...................................... FAILURE [ 0.236 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.034 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [06:15 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.681 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.660 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 27.369 s]
[INFO] Community Space .................................... SUCCESS [ 0.021 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 5.661 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.534 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.252 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.866 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.165 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.218 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.956 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.241 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.694 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.506 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.258 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.394 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.874 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... FAILURE [ 11.391 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.334 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.878 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.554 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.694 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.271 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.759 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.575 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.028 s]
[INFO] Core Monitor Extension ............................. FAILURE [ 1.096 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... FAILURE [ 2.120 s]
[INFO] GeoServer Security Extension Web Modules ........... FAILURE [ 0.219 s]
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.759 s]
[INFO] GeoServer INSPIRE Extensions ....................... FAILURE [ 0.046 s]
[INFO] GeoServer CSS Styling .............................. FAILURE [ 3.234 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.448 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.962 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 1.461 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.742 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.014 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions FAILURE [ 0.035 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.887 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.197 s]
[INFO] Importer Core Module ............................... FAILURE [ 3.379 s]
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 20.987 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [05:40 min]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 0.686 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 15.499 s]
[INFO] Ysld GeoServer Plugin .............................. FAILURE [ 0.934 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.788 s]
[INFO] REST SLD service ................................... FAILURE [ 15.753 s]
[INFO] GeoFence security integration ...................... FAILURE [ 44.775 s]
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... FAILURE [ 9.092 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:26 min (Wall Clock)
[INFO] Finished at: 2019-08-30T08:06:33Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-geofence: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-authkey: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/authkey/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wps-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0-eo-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sldservice: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-gwc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/gwc/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-css: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/css/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-inspire: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/inspire/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-monitor-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wcs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wcs/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ysld: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ysld/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-importer-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-netcdf-out: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-app-schema-test: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-web-sec: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sec-cas: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/pom.xml> isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence
