[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #989
See <https://build.geoserver.org/job/geoserver-java11/989/display/redirect?page=changes&gt;
Changes:
[Torben Barsballe] Updated version to 2.17-SNAPSHOT, updated GeoTools dependency to
[...truncated 2.10 MB...]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.732 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.801 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [100/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 34.958 s - in org.geoserver.importer.bdb.BDBImportStoreTest
[INFO] Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.373 s - in org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.158 s - in org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 25.117 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.204 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.803 s]
[INFO] Main Module ........................................ SUCCESS [01:10 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.039 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:21 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 38.688 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.342 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.552 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.457 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.059 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:13 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:07 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:53 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 16.466 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.631 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 53.125 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:13 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.205 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.059 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.616 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.110 s]
[INFO] Core UI Module ..................................... SUCCESS [ 58.747 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 20.709 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 26.841 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.645 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.897 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 7.298 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.030 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 57.864 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [05:38 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.575 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.194 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.030 s]
[INFO] Printing Module .................................... SUCCESS [ 37.107 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.694 s]
[INFO] Community Space .................................... SUCCESS [ 0.020 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.018 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:59 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.244 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.552 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.421 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.135 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.121 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.901 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.228 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.295 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.623 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.260 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.395 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.861 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:14 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.054 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.045 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.113 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.603 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.850 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.957 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.951 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 15.091 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.997 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.534 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 49.851 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.479 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.352 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.750 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 17.208 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.958 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.042 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.634 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.605 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [02:51 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.276 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.015 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.114 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.164 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.014 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.960 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [06:15 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.587 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.342 s]
[INFO] Importer Core Module ............................... SUCCESS [ 29.223 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 26.050 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 40.137 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.484 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 27.369 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 18.380 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [02:51 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 15.487 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.689 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.781 s]
[INFO] REST SLD service ................................... SUCCESS [05:47 min]
[INFO] GeoFence security integration ...................... SUCCESS [05:35 min]
[INFO] GeoFence Server .................................... SUCCESS [06:42 min]
[INFO] Authentication by unique url key ................... SUCCESS [09:29 min]
[INFO] BUILD SUCCESS
[INFO] Total time: 39:16 min (Wall Clock)
[INFO] Finished at: 2019-08-30T21:38:22Z
[java11] $ mvn -f geoserver/src/community/pom.xml -B -DskipTests -PcommunityRelease clean install -DconfigDirectory=../../../data -fae -Dmaven.repo.local=m2 -Dfmt.action=check
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.google.inject.internal.cglib.core.$ReflectUtils$1 (file:/usr/share/maven/lib/guice.jar) to method java.lang.ClassLoader.defineClass(java.lang.String,byte,int,int,java.security.ProtectionDomain)
WARNING: Please consider reporting this to the maintainers of com.google.inject.internal.cglib.core.$ReflectUtils$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-resolvable parent POM for org.geoserver.community:gs-ogcapi-tiles:[unknown-version]: Could not find artifact org.geoserver.community:gs-ogcapi:pom:2.16-SNAPSHOT and 'parent.relativePath' points at wrong local POM @ line 5, column 13
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: xmlunit:xmlunit:jar -> duplicate declaration of version (?) @ line 278, column 17
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: junit:junit:jar -> duplicate declaration of version (?) @ line 129, column 15
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.easymock:easymock:jar -> duplicate declaration of version (?) @ line 134, column 15
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.geoserver.community:gs-ogcapi-tiles:[unknown-version] (<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/ogcapi/ogcapi-tiles/pom.xml)> has 1 error
[ERROR] Non-resolvable parent POM for org.geoserver.community:gs-ogcapi-tiles:[unknown-version]: Could not find artifact org.geoserver.community:gs-ogcapi:pom:2.16-SNAPSHOT and 'parent.relativePath' points at wrong local POM @ line 5, column 13 -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/UnresolvableModelException
See <https://build.geoserver.org/job/geoserver-java11/990/display/redirect?page=changes&gt;
