See <https://build.geoserver.org/job/geoserver-java11-qa/1041/display/redirect>
[...truncated 901.55 KB...]
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/src/main/java/org/geoserver/gwc/wmts/WMTSInfoImpl.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-gwc ---
[INFO] Copying 2 resources
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-gwc ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 31 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/test-classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/src/test/java/org/geoserver/gwc/GWCTransactionListenerTest.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/src/test/java/org/geoserver/gwc/GWCTransactionListenerTest.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-gwc ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-gwc ---
[java] [debug] Using AOSP style
[INFO] Processed 87 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-gwc >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-gwc ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-kml <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-kml ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-kml ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-kml ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/kml/target/gs-kml-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-kml/2.17-SNAPSHOT/gs-kml-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/kml/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-kml/2.17-SNAPSHOT/gs-kml-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/kml/target/gs-kml-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-kml/2.17-SNAPSHOT/gs-kml-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/kml/target/gs-kml-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-kml/2.17-SNAPSHOT/gs-kml-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/kml/target/gs-kml-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-kml/2.17-SNAPSHOT/gs-kml-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] ------------------< org.geoserver:gs-restconfig-wms >-------------------
[INFO] Building gs-restconfig-wms 2.17-SNAPSHOT [25/36]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-restconfig-wms ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-restconfig-wms ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-restconfig-wms ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-restconfig-wms ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-restconfig-wms ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/classes>
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-gwc <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-gwc ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-gwc >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-gwc ---
[INFO] Fork Value is true
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-restconfig-wms ---
[INFO] Copying 0 resource
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-restconfig-wms ---
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-restconfig-wms ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-restconfig-wms ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-restconfig-wms ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-restconfig-wms ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-restconfig-wms ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-restconfig-wms ---
[INFO] Processed 4 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-restconfig-wms >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-restconfig-wms ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-restconfig-wms <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-restconfig-wms ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-restconfig-wms >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-restconfig-wms ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-restconfig-wms <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-restconfig-wms ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-restconfig-wms ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-restconfig-wms ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wms/2.17-SNAPSHOT/gs-restconfig-wms-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wms/2.17-SNAPSHOT/gs-restconfig-wms-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wms/2.17-SNAPSHOT/gs-restconfig-wms-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wms/2.17-SNAPSHOT/gs-restconfig-wms-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms/target/gs-restconfig-wms-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wms/2.17-SNAPSHOT/gs-restconfig-wms-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demos Module
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-gwc <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-gwc ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-gwc ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-gwc ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-gwc/2.17-SNAPSHOT/gs-gwc-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-gwc/2.17-SNAPSHOT/gs-gwc-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-gwc/2.17-SNAPSHOT/gs-gwc-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-gwc/2.17-SNAPSHOT/gs-gwc-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc/target/gs-gwc-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-gwc/2.17-SNAPSHOT/gs-gwc-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 30.381 s]
[INFO] Core Platform Module ............................... SUCCESS [ 40.694 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 20.579 s]
[INFO] Main Module ........................................ SUCCESS [01:40 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.082 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 6.653 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 10.235 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.873 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 8.013 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.002 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.540 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 15.293 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 39.527 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:07 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 15.759 s]
[INFO] gs-rest ............................................ SUCCESS [ 12.461 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 26.287 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 22.291 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 5.908 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 7.298 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 6.589 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.154 s]
[INFO] Core UI Module ..................................... FAILURE [ 9.351 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.065 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.051 s]
[INFO] BUILD FAILURE
[INFO] Total time: 06:01 min (Wall Clock)
[INFO] Finished at: 2019-09-19T04:58:37Z
[ERROR] Failed to execute goal on project gs-web-core: Could not resolve dependencies for project org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.apache.wicket:wicket-util:jar:7.6.0, org.apache.wicket:wicket-request:jar:7.6.0: Could not transfer artifact org.apache.wicket:wicket-util:jar:7.6.0 from/to central (https://repo.maven.apache.org/maven2): Connection reset -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
