See <https://build.geoserver.org/job/geoserver-java11-qa/1069/display/redirect>
[...truncated 1.94 MB...]
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-ogr-wps ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-ogr-wps ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/dependency/gwc-core-1.17-SNAPSHOT.jar>
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/dependency/gt-main-23-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-ogr-wps ---
[debug] Using AOSP style
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-ogr-wps >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-ogr-wps ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-importer-web ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/dependency/gwc-core-1.17-SNAPSHOT.jar>
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/dependency/gt-main-23-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-web >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-web ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-ogr-wps <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-ogr-wps ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-ogr-wps >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-ogr-wps ---
[INFO] Fork Value is true
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-web ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-importer-web >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-importer-web ---
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-ogr-wps <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-ogr-wps ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-ogr-wps ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-ogr-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] -------------------< org.geoserver.csw:gs-csw-core >--------------------
[INFO] Building Catalog Services for the Web core module 2.17-SNAPSHOT [64/65]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.pom (1.1 kB at 273 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.jar (278 kB at 35 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-csw-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-csw-core ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-csw-core ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-csw-core ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-csw-core ---
[INFO] Compiling 62 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/CSWXStreamLoader.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/CSWXStreamLoader.java>: Recompile with -Xlint:unchecked for details.
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[1,40\] unclosed comment
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[1,6\] unclosed string literal
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[1,47\] unclosed comment
[INFO] 3 errors
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-importer-web ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-importer-web ---
[INFO] Reactor Summary for GeoServer Extensions 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 6.114 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.150 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 12.940 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.340 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.421 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.653 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.456 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.736 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.464 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.780 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.206 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.859 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.754 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.049 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.542 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.728 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.050 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 24.319 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.103 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.581 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.950 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.129 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.111 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.039 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 6.783 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 10.334 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 5.680 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 5.166 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.159 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 13.840 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.084 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.887 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.060 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 4.642 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 8.205 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 8.676 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 7.976 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.071 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.674 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.299 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 2.211 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.049 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.871 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.577 s]
[INFO] Printing Module .................................... SUCCESS [ 22.965 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.048 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.056 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 4.695 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.969 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.477 s]
[INFO] Importer Core Module ............................... SUCCESS [ 16.752 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 9.677 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 6.734 s]
[INFO] Importer Web UI Module ............................. FAILURE [ 10.422 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.457 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 8.185 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 10.961 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 15.729 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.764 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 6.580 s]
[INFO] REST SLD service ................................... SUCCESS [ 12.193 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 10.797 s]
[INFO] GeoFence Server .................................... SUCCESS [ 24.145 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 8.796 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:47 min (Wall Clock)
[INFO] Finished at: 2019-09-20T10:47:30Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-csw-core: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-importer-web: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml>: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml'\.> -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-core
