See <https://build.geoserver.org/job/geoserver-java11-qa/255/display/redirect?page=changes>
Changes:
[niels] GEOS-9164 csw: offline test failure
[Torben Barsballe] Don't fail if the tag we are releasing doesn't exist yet
[Torben Barsballe] Don't hardcode SF Key, assume it will be in SSH agent
[...truncated 904.75 KB...]
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-wms ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data/22-SNAPSHOT/maven-metadata.xml (986 B at 25 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data/22-SNAPSHOT/gt-sample-data-22-20190629.094850-128.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data/22-SNAPSHOT/gt-sample-data-22-20190629.094850-128.pom (2.8 kB at 236 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data/22-SNAPSHOT/gt-sample-data-22-20190629.094850-128.jar
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wms ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] Skipping GWC UI Module
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data/22-SNAPSHOT/gt-sample-data-22-20190629.094850-128.jar (4.0 MB at 42 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-demo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-demo ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-demo ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-demo ---
[INFO] Copying 29 resources
[INFO] Copying 11 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-demo ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 18 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/src/main/java/org/geoserver/web/demo/PreviewLayerModel.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/src/main/java/org/geoserver/web/demo/PreviewLayerModel.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-demo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-demo ---
[INFO] Compiling 6 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-demo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-demo ---
[debug] Using AOSP style
[INFO] Processed 24 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-demo >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-demo ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-demo <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-demo ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-demo >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-demo ---
[INFO] Fork Value is true
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-demo <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-demo ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-demo ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-demo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --------------------< org.geoserver.web:gs-web-wcs >--------------------
[INFO] Building WCS UI Module 2.16-SNAPSHOT [28/36]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wcs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wcs ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs ---
[INFO] Copying 14 resources
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-wcs ---
[INFO] Compiling 10 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/publish/WCSLayerConfig.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/publish/WCSLayerConfig.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-wcs ---
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/test-classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java>: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java> uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-wcs ---
[INFO] Processed 13 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-wcs >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-wcs ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-wcs <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-wcs >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-wcs ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-wcs <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 27.470 s]
[INFO] Core Platform Module ............................... SUCCESS [ 42.789 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 25.433 s]
[INFO] Main Module ........................................ SUCCESS [01:48 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.248 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 7.525 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 9.257 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.653 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 9.565 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.590 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.931 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 22.015 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 44.670 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:22 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 15.193 s]
[INFO] gs-rest ............................................ FAILURE [ 2.411 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.149 s]
[INFO] Core UI Module ..................................... SUCCESS [ 48.068 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 15.455 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 7.568 s]
[INFO] Demos Module ....................................... SUCCESS [ 11.329 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.449 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.103 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 21.200 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 8.110 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 8.810 s]
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.066 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.052 s]
[INFO] BUILD FAILURE
[INFO] Total time: 06:36 min (Wall Clock)
[INFO] Finished at: 2019-06-29T09:58:45Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-rest: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed. ArrayIndexOutOfBoundsException: Index 11 out of bounds for length 10 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-rest
Not sending mail to unregistered user niels@anonymised.com
