See <https://build.geoserver.org/job/geoserver-java11-qa/270/display/redirect?page=changes>
Changes:
[milkymike45] GEOS-9236 --GeoTIFF sources configured with GeoServer 2.14.x might not
[...truncated 701.85 KB...]
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-velocity/1.1.2/plexus-velocity-1.1.2.jar (8.0 kB at 210 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/velocity/velocity-dep/1.4/velocity-dep-1.4.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/edu/ucla/cs/compilers/jtb/1.3.2/jtb-1.3.2.jar (337 kB at 8.4 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/doxia/doxia-decoration-model/1.0-alpha-7/doxia-decoration-model-1.0-alpha-7.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/plexus/plexus-utils/1.0.2/plexus-utils-1.0.2.jar (160 kB at 3.9 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-logging/commons-logging-api/1.0.4/commons-logging-api-1.0.4.jar (26 kB at 596 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/doxia/doxia-decoration-model/1.0-alpha-7/doxia-decoration-model-1.0-alpha-7.jar (38 kB at 848 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/velocity/velocity/1.4/velocity-1.4.jar (361 kB at 7.5 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/velocity/velocity-dep/1.4/velocity-dep-1.4.jar (518 kB at 10 MB/s)
[INFO]
[INFO] --------------------< org.geoserver:gs-restconfig >---------------------
[INFO] Building gs-restconfig 2.16-SNAPSHOT [17/36]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-geojson/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/22-SNAPSHOT/maven-metadata.xml (982 B at 43 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/directory/server/apacheds-all/2.0.0-M24/apacheds-all-2.0.0-M24.jar (20 MB at 29 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-sec-ldap ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sec-ldap ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-sec-ldap ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sec-ldap ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/security/ldap/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/security/ldap/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-sec-ldap ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-ldap ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/security/ldap/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/security/ldap/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-sec-ldap ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-ldap ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-ldap ---
[INFO]
[INFO] Skipping Security UI Modules
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demos Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping WCS UI Module
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/22-SNAPSHOT/gt-geojson-22-20190702.111012-132.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/22-SNAPSHOT/gt-geojson-22-20190702.111012-132.pom (3.4 kB at 286 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.pom (1.1 kB at 542 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/22-SNAPSHOT/gt-geojson-22-20190702.111012-132.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/22-SNAPSHOT/gt-geojson-22-20190702.111012-132.jar (64 kB at 4.6 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/googlecode/json-simple/json-simple/1.1/json-simple-1.1.jar (16 kB at 5.3 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-restconfig ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-restconfig ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-restconfig ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-restconfig ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-restconfig ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-restconfig ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-restconfig ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-restconfig ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-restconfig ---
[INFO]
[INFO]
[INFO] Skipping gs-restconfig-wcs
[INFO] Skipping gs-restconfig-wfs
[INFO]
[INFO]
[INFO] Skipping REST UI Module
[INFO] Skipping gs-restconfig-wms
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 33.326 s]
[INFO] Core Platform Module ............................... SUCCESS [ 49.081 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 26.135 s]
[INFO] Main Module ........................................ SUCCESS [02:08 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.113 s]
[INFO] GeoServer Security Tests Module .................... FAILURE [ 0.056 s]
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... FAILURE [ 6.262 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 8.951 s]
[INFO] Web Coverage Service 1.0 Module .................... FAILURE [ 0.454 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 0.431 s]
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... FAILURE [ 40.408 s]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 11.430 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... FAILURE [ 1.296 s]
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.129 s]
[INFO] Core UI Module ..................................... FAILURE [ 14.825 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.097 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.051 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:41 min (Wall Clock)
[INFO] Finished at: 2019-07-02T12:41:12Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.3:run (process-resources) on project gs-web-core: An Ant BuildException has occured: Basedir <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/core> does not exist -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-security-tests: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/security/security-tests/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-wfs: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml>: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml'\.> -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs1_0: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs1_0/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.codehaus.mojo:javacc-maven-plugin:2.3:jjtree (jjtree) on project gs-wcs1_1: Execution jjtree of goal org.codehaus.mojo:javacc-maven-plugin:2.3:jjtree failed: basedir <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> does not exist -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sec-ldap: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/security/ldap/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-restconfig: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig/pom.xml> isn't a file. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
Not sending mail to unregistered user milkymike45@anonymised.com
