See <https://build.geoserver.org/job/geoserver-java11-qa/283/display/redirect?page=changes>
Changes:
[Andrea Aime] Follow up to the EPSG v9.6 upgrade
[...truncated 186.49 KB...]
[INFO] Processed 500 files (0 non-complying).
[INFO] Processed 600 files (0 non-complying).
[INFO] Processed 700 files (0 non-complying).
[INFO] Processed 800 files (0 non-complying).
[INFO] Processed 815 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-main >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-main ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[WARNING] There are 37 PMD processing errors:
[WARNING] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/geoserver/util/ISO8601Formatter.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/geoserver/util/ISO8601Formatter.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/geoserver/util/XCQL.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/geoserver/util/XCQL.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverCustomWKTFactory.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverCustomWKTFactory.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverGridShiftLocator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverGridShiftLocator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverOverridingWKTFactory.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverOverridingWKTFactory.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/ConfigurationException.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/ConfigurationException.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/CoverageInfoLabelComparator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/CoverageInfoLabelComparator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/FeatureTypeInfoTitleComparator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/FeatureTypeInfoTitleComparator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureLocking.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureLocking.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureSource.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureSource.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureStore.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerFeatureStore.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerServletContextInitializer.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/GeoServerServletContextInitializer.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/Log4JFormatter.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/Log4JFormatter.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/QueryCapabilitiesDecorator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/QueryCapabilitiesDecorator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/GMLSchemaTranslator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/GMLSchemaTranslator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceElement.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceElement.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceTranslator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceTranslator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceTranslatorFactory.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceTranslatorFactory.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/WriterHelper.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/WriterHelper.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/XMLSchemaTranslator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/global/xml/XMLSchemaTranslator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/BufferStrategy.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/BufferStrategy.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/FileHiderServlet.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/FileHiderServlet.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/FileStrategy.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/FileStrategy.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/FreefsLog.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/FreefsLog.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/PartialBufferStrategy2.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/PartialBufferStrategy2.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/ServiceStrategyFactory.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/ServiceStrategyFactory.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/SpeedStrategy.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/servlets/SpeedStrategy.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/DataStoreUtils.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/DataStoreUtils.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/EntityResolverToLSResourceResolver.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/EntityResolverToLSResourceResolver.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/GETMAPValidator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/GETMAPValidator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/PartialBufferedOutputStream2.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/PartialBufferedOutputStream2.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/Requests.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/Requests.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/ResponseUtils.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/ResponseUtils.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/SLDValidator.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/SLDValidator.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/requests/DispatcherHandler.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/requests/DispatcherHandler.java>
<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/requests/FilterHandlerImpl.java>: NoSuchFileException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/src/main/java/org/vfny/geoserver/util/requests/FilterHandlerImpl.java>
[INFO]
[INFO]
[INFO] Skipping GeoServer Security Modules
[INFO] Skipping Web Coverage Service Module
[INFO]
[INFO] Skipping Web Feature Service Module
[INFO]
[INFO] Skipping gs-rest
[INFO]
[INFO] Skipping Core UI Module
[INFO]
[INFO] Skipping GeoServer Security Tests Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
[INFO]
[INFO] Skipping gs-restconfig
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO]
[INFO] Skipping Security UI Modules
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demos Module
[INFO]
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO] Skipping gs-restconfig-wcs
[INFO]
[INFO] Skipping gs-restconfig-wfs
[INFO]
[INFO] Skipping gs-restconfig-wms
[INFO]
[INFO]
[INFO] Skipping REST UI Module
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.240 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.190 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.732 s]
[INFO] Main Module ........................................ FAILURE [ 46.552 s]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.135 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.084 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.069 s]
[INFO] BUILD FAILURE
[INFO] Total time: 01:33 min (Wall Clock)
[INFO] Finished at: 2019-07-09T09:37:44Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-main: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main/target/pmd.xml> (No such file or directory) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
