Hudson
1
See <https://build.geoserver.org/job/geoserver-java11-qa/29/display/redirect?page=changes>
Changes:
[cmhodgson] code formatting and sharding config for MapML
[cmhodgson] Added MapML to nightly build config
[...truncated 887.80 KB...]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target/classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-geofence-server ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-geofence-server ---
[debug] Using AOSP style
[INFO] Processed 19 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-geofence-server >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-geofence-server ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-sec-cas >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-sec-cas ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-sec-cas >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-sec-cas ---
[INFO] Fork Value is true
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-geofence-server <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-geofence-server ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-geofence-server >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-geofence-server ---
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-sec-cas <<<
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-sec-cas ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-sec-cas ---
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-geofence-server <<<
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-geofence-server ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-geofence-server ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.226 s]
[INFO] Core Platform Module ............................... SUCCESS [ 37.311 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 33.212 s]
[INFO] Main Module ........................................ SUCCESS [02:21 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.407 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 15.188 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 22.340 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.380 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 19.052 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.619 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.092 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 40.435 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:34 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:52 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.382 s]
[INFO] gs-rest ............................................ SUCCESS [ 28.651 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 47.527 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 45.325 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.391 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.444 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 14.949 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.469 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.450 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 33.896 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.884 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.263 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 18.594 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.189 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 35.707 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 20.581 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.258 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.715 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.282 s]
[INFO] Printing Module .................................... SUCCESS [ 12.600 s]
[INFO] GeoServer Web Application .......................... FAILURE [ 1.477 s]
[INFO] Community Space .................................... SUCCESS [ 0.261 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.187 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 15.351 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 4.131 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.392 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.652 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.448 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.534 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.413 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.352 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 17.633 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 13.820 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.245 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.196 s]
[INFO] OGR CORE ........................................... SUCCESS [ 11.161 s]
[INFO] OGR WFS ............................................ SUCCESS [ 13.379 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.200 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 54.793 s]
[INFO] OGR WPS ............................................ SUCCESS [ 14.467 s]
[INFO] Excel Output Format ................................ SUCCESS [ 19.070 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.747 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 10.327 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.084 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.132 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.236 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.512 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 14.144 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 9.801 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.321 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 30.894 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.347 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 18.122 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.258 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 11.215 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 18.536 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 18.554 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.182 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.295 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 18.257 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.591 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 37.037 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.211 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.259 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 16.291 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 12.064 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.197 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.980 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.628 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 14.903 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.396 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.852 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 25.548 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 16.142 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 24.867 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 12.370 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 13.946 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 30.877 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 20.849 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 12.021 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.092 s]
[INFO] REST SLD service ................................... SUCCESS [ 22.197 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 30.794 s]
[INFO] GeoFence Server .................................... SUCCESS [ 23.892 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:01 min (Wall Clock)
[INFO] Finished at: 2019-03-26T19:39:14+00:00
[INFO] Final Memory: 573M/1871M
[ERROR] Failed to execute goal on project gs-web-app: Could not resolve dependencies for project org.geoserver.web:gs-web-app:jar:2.16-SNAPSHOT: Could not find artifact org.geoserver.community:gs-mapml:jar:2.16-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-app
Not sending mail to unregistered user cmhodgson@anonymised.com
Hudson
2
See <https://build.geoserver.org/job/geoserver-java11-qa/30/display/redirect?page=changes>
Changes:
[github] Add docs for continuous
[...truncated 1.05 MB...]
[ERROR] location: class org.geoserver.geofence.web.GeofenceAdminRulesModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[49,34\] cannot find symbol
[ERROR] symbol: class ShortAdminRule
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[52,25\] cannot find symbol
[ERROR] symbol: class Property
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[52,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[55,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[55,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[58,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[58,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[61,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[61,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[64,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[64,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[66,20\] cannot find symbol
[ERROR] symbol: class AdminRuleAdminService
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[70,15\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[70,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[78,56\] cannot find symbol
[ERROR] symbol: class SortParam
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[78,15\] cannot find symbol
[ERROR] symbol: class Comparator
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[78,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[83,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[89,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[89,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[89,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[94,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[94,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[98,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[119,24\] cannot find symbol
[ERROR] symbol: class Collection
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[119,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[126,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[130,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[139,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[143,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[152,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[152,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[159,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[177,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[184,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java>:\[184,62\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/LiveCasData.java>:\[6,1\] cannot access org.geoserver.security.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geotools/jdbc/gt-jdbc-postgis/22-SNAPSHOT/gt-jdbc-postgis-22-SNAPSHOT.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[21,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[21,51\] cannot find symbol
[ERROR] symbol: class GeoServerMockTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[23,22\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.security.cas.CasFilterConfigValidatorTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[25,5\] cannot find symbol
[ERROR] symbol: class CasFilterConfigValidator
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[33,56\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[42,23\] cannot find symbol
[ERROR] symbol: class CasAuthenticationFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[42,68\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[91,8\] cannot access org.geoserver.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[91,44\] cannot find symbol
[ERROR] symbol: class AbstractAuthenticationProviderTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[93,12\] cannot find symbol
[ERROR] symbol: class URL
[ERROR] location: class org.geoserver.security.cas.CasAuthenticationTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[95,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[97,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[99,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[101,12\] cannot find symbol
[ERROR] symbol: class HttpsServer
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[192,15\] cannot find symbol
[ERROR] symbol: class SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[197,28\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[210,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[227,45\] cannot find symbol
[ERROR] symbol: class HttpURLConnection
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFormAuthenticationHelper.java>:\[26,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFormAuthenticationHelper.java>:\[26,50\] cannot find symbol
[ERROR] symbol: class CasAuthenticationHelper
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[605,15\] cannot find symbol
[ERROR] symbol: class Assertion
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[1062,13\] cannot find symbol
[ERROR] symbol: class MockHttpServletRequest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[1063,13\] cannot find symbol
[ERROR] symbol: class MockHttpServletResponse
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[1064,13\] cannot find symbol
[ERROR] symbol: class MockFilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFormAuthenticationHelper.java>:\[33,40\] cannot find symbol
[ERROR] location: class org.geoserver.security.cas.CasFormAuthenticationHelper
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFormAuthenticationHelper.java>:\[39,38\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[103,55\] cannot find symbol
[ERROR] symbol: class HttpHandler
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[105,28\] cannot find symbol
[ERROR] symbol: class HttpExchange
[ERROR] location: class org.geoserver.security.cas.CasAuthenticationTest.HttpsProxyCallBackHandler
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[105,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[138,50\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[151,28\] cannot find symbol
[ERROR] location: class org.geoserver.security.cas.CasAuthenticationTest.SingleSignOutHandler
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[151,52\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal on project gs-web-app: Could not resolve dependencies for project org.geoserver.web:gs-web-app:jar:2.16-SNAPSHOT: Could not find artifact org.geoserver.community:gs-mapml:jar:2.16-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-csw: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/maven-status/maven-compiler-plugin/testCompile/default-testCompile/createdFiles.lst> (Too many open files) -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java>:\[29,8\] error while writing org.geoserver.importer.web.PostGISPanel: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/classes/org/geoserver/importer/web/PostGISPanel.class>: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-inspire
Not sending mail to unregistered user noreply@anonymised.com
Hudson
3
See <https://build.geoserver.org/job/geoserver-java11-qa/31/display/redirect?page=changes>
Changes:
[nuno.oliveira] Add schema.cache.dir system property usage to user manual (#3412)
[...truncated 887.17 KB...]
[INFO]
[INFO]
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.077 s]
[INFO] Core Platform Module ............................... SUCCESS [ 37.070 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 32.768 s]
[INFO] Main Module ........................................ SUCCESS [02:25 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.459 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 18.831 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 25.557 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 25.406 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 20.510 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 36.083 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 37.606 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 41.878 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:14 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 22.916 s]
[INFO] gs-rest ............................................ SUCCESS [ 27.624 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 46.360 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:00 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.408 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.705 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 15.304 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.433 s]
[INFO] Core UI Module ..................................... SUCCESS [01:25 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 38.758 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 28.849 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 16.864 s]
[INFO] Demos Module ....................................... SUCCESS [ 37.346 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.971 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.462 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 22.479 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 13.133 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.065 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.772 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.315 s]
[INFO] Printing Module .................................... SUCCESS [ 16.325 s]
[INFO] GeoServer Web Application .......................... FAILURE [ 0.128 s]
[INFO] Community Space .................................... SUCCESS [ 0.199 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.194 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 9.057 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 4.250 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 19.559 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.415 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.538 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.317 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.596 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.412 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 25.782 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 13.199 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.416 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.168 s]
[INFO] OGR CORE ........................................... SUCCESS [ 11.657 s]
[INFO] OGR WFS ............................................ SUCCESS [ 14.329 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.191 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 45.353 s]
[INFO] OGR WPS ............................................ SUCCESS [ 8.278 s]
[INFO] Excel Output Format ................................ SUCCESS [ 19.614 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.296 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 10.918 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.185 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 23.205 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.624 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 15.553 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 15.264 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 11.490 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.350 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 28.805 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.114 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 12.655 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.161 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 7.000 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.874 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 19.448 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.166 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.310 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 23.437 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.522 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 21.010 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.652 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.151 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 19.781 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.604 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.155 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 13.002 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.044 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 20.595 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.392 s]
[INFO] Importer Core Module ............................... SUCCESS [ 27.615 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 14.589 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 9.292 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 18.940 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.889 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.449 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 20.819 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.128 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 12.986 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.283 s]
[INFO] REST SLD service ................................... SUCCESS [ 22.569 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 17.750 s]
[INFO] GeoFence Server .................................... SUCCESS [ 15.500 s]
[INFO] Total time: 17:24 min (Wall Clock)
[INFO] Finished at: 2019-03-27T14:38:39+00:00
[INFO] Final Memory: 582M/1791M
[ERROR] Failed to execute goal on project gs-web-app: Could not resolve dependencies for project org.geoserver.web:gs-web-app:jar:2.16-SNAPSHOT: Failure to find org.geoserver.community:gs-mapml:jar:2.16-SNAPSHOT in https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user nuno.oliveira@anonymised.com
Hudson
4
See <https://build.geoserver.org/job/geoserver-java11-qa/32/display/redirect?page=changes>
Changes:
[cmhodgson] Added MapML sharding and more documentation.
[...truncated 965.14 KB...]
[INFO] WMS UI Module ...................................... SUCCESS [ 12.828 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 20.345 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.059 s]
[INFO] Demos Module ....................................... SUCCESS [ 10.779 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 11.073 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.169 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 16.005 s]
[INFO] Security UI JDBC Module ............................ FAILURE [ 0.569 s]
[INFO] Security UI LDAP Module ............................ FAILURE [ 0.439 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.910 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.204 s]
[INFO] Printing Module .................................... SUCCESS [ 9.098 s]
[INFO] Community Space .................................... SUCCESS [ 0.118 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.097 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 7.494 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 2.832 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.933 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.324 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.400 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.024 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.078 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.057 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.890 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 9.612 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.785 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.091 s]
[INFO] OGR CORE ........................................... SUCCESS [ 6.433 s]
[INFO] OGR WFS ............................................ SUCCESS [ 7.514 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.100 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 56.497 s]
[INFO] OGR WPS ............................................ SUCCESS [ 8.745 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.345 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.176 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 6.115 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.078 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.886 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.516 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 15.977 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 7.581 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 6.367 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.150 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.977 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.172 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.890 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.158 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.649 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.681 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 10.005 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 7.710 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.167 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 13.497 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.751 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 18.363 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.720 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.094 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.303 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.063 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.222 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.645 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.287 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.462 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.191 s]
[INFO] Importer Core Module ............................... SUCCESS [ 22.380 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 13.217 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 8.109 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.586 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.362 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 6.571 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 17.155 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.859 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.839 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.102 s]
[INFO] REST SLD service ................................... SUCCESS [ 13.742 s]
[INFO] GeoFence security integration ...................... FAILURE [ 0.428 s]
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Total time: 11:29 min (Wall Clock)
[INFO] Finished at: 2019-03-29T05:17:42+00:00
[INFO] Final Memory: 532M/1719M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-jdbc: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanelInfo.java>:\[6,1\] cannot access org.geoserver.security.web.jdbc
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/com/google/code/findbugs/jsr305/2.0.3/jsr305-2.0.3.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>:\[20,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>:\[20,43\] cannot find symbol
[ERROR] symbol: class RoleServicePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>:\[20,60\] cannot find symbol
[ERROR] symbol: class JDBCRoleServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>:\[22,33\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.security.web.jdbc.JDBCRoleServicePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>:\[22,44\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>:\[22,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanelInfo.java>:\[17,8\] cannot access org.geoserver.security.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanelInfo.java>:\[18,17\] cannot find symbol
[ERROR] symbol: class AuthenticationProviderPanelInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanelInfo.java>:\[19,17\] cannot find symbol
[ERROR] symbol: class JDBCConnectAuthProviderConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>:\[31,8\] cannot access org.geoserver.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>:\[32,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>:\[32,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>:\[35,5\] cannot find symbol
[ERROR] symbol: class FeedbackPanel
[ERROR] location: class org.geoserver.security.web.jdbc.JDBCAuthProviderPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>:\[38,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>:\[38,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>:\[37,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>:\[38,17\] cannot find symbol
[ERROR] symbol: class FormComponentPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>:\[37,44\] cannot find symbol
[ERROR] symbol: class JDBCSecurityServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>:\[42,12\] cannot find symbol
[ERROR] location: class org.geoserver.security.web.jdbc.JDBCConnectionPanel<T>
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>:\[44,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>:\[46,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>:\[105,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanelInfo.java>:\[17,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanelInfo.java>:\[18,17\] cannot find symbol
[ERROR] symbol: class UserGroupServicePanelInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanelInfo.java>:\[18,43\] cannot find symbol
[ERROR] symbol: class JDBCUserGroupServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[8,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[8,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[8,42\] import requires canonical name for <any>.markup.html.form.CheckBox
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[9,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[9,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[9,42\] import requires canonical name for <any>.form.TextField
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[10,25\] cannot access org.apache.wicket.model
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[10,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[11,30\] cannot access org.geoserver.security.jdbc
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[11,35\] package org.geoserver.security.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[12,35\] cannot access org.geoserver.security.jdbc.config
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[12,42\] package org.geoserver.security.jdbc.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[13,34\] cannot access org.geoserver.security.web.usergroup
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[13,44\] package org.geoserver.security.web.usergroup does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[20,48\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[20,70\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[22,49\] cannot find symbol
[ERROR] location: class org.geoserver.security.web.jdbc.JDBCUserGroupServicePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>:\[22,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[8,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[8,12\] cannot access java.sql
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[8,16\] import requires canonical name for <any>.Driver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[9,16\] cannot find symbol
[ERROR] symbol: class DriverManager
[ERROR] location: package java.sql
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[10,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[13,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[13,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[14,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[15,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[22,39\] cannot find symbol
[ERROR] symbol: class DropDownChoice
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[28,55\] cannot find symbol
[ERROR] location: class org.geoserver.security.web.jdbc.JDBCDriverChoice
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>:\[51,45\] cannot find symbol
[ERROR] symbol: class ChoiceRenderer
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-ldap: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceAuthenticationProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceAuthenticationProvider.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceAuthenticationProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/GeoFenceController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/GeoFenceController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/GeoFenceController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/GeoFenceXStreamPersisterInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/GeoFenceXStreamPersisterInitializer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/GeoFenceXStreamPersisterInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/CacheController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/CacheController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/CacheController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceAuthenticationProviderConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceAuthenticationProviderConfig.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceAuthenticationProviderConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/MultiPolygonAdapter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/MultiPolygonAdapter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/MultiPolygonAdapter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/cache/CacheConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/cache/CacheConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/cache/CacheConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/cache/CachedRuleReader.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/cache/CachedRuleReader.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/cache/CachedRuleReader.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfigurationController.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfigurationController.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfigurationController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilterConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilterConfig.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilterConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/authentication/GeoFenceAuthProviderPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/authentication/GeoFenceAuthProviderPanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/authentication/GeoFenceAuthProviderPanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbAdminRule.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbAdminRule.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbAdminRule.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/authentication/GeoFenceAuthProviderPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/authentication/GeoFenceAuthProviderPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/authentication/GeoFenceAuthProviderPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfigurationManager.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfigurationManager.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfigurationManager.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRuleList.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRuleList.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRuleList.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRule.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRule.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRule.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/GeofencePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/GeofencePage.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/web/GeofencePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilterProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilterProvider.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/filter/GeoFenceAuthFilterProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceSecurityProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceSecurityProvider.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geoserver/authentication/auth/GeoFenceSecurityProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbAdminRuleList.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbAdminRuleList.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbAdminRuleList.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFencePropertyPlaceholderConfigurer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFencePropertyPlaceholderConfigurer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFencePropertyPlaceholderConfigurer.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-jdbc
Not sending mail to unregistered user cmhodgson@anonymised.com
Hudson
5
See <https://build.geoserver.org/job/geoserver-java11-qa/33/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-9172] Using legacy style with no format indication fails on master
[...truncated 2.38 MB...]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-app-schema-test: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeIntervalWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeIntervalWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeIntervalWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsWithJoiningTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsWithJoiningTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsWithJoiningTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/WfsOnlineTestMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/WfsOnlineTestMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/WfsOnlineTestMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WaterMLTimeSeriesWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WaterMLTimeSeriesWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WaterMLTimeSeriesWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupCoverageMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupCoverageMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupCoverageMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataPostgisSetup.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataPostgisSetup.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataPostgisSetup.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTestData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTestData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTestData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkGeometryTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkGeometryTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkGeometryTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MockConnectionLifecycleListener.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MockConnectionLifecycleListener.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MockConnectionLifecycleListener.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsGetMapTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsGetMapTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsGetMapTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LocalResolveFeatureChainingByRefTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LocalResolveFeatureChainingByRefTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LocalResolveFeatureChainingByRefTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/GetPropertyValueTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/GetPropertyValueTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/GetPropertyValueTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOracleTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOracleTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOracleTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaWmsReferenceMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaWmsReferenceMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaWmsReferenceMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBoxFilterTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBoxFilterTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBoxFilterTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/TimeSeriesInlineMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/TimeSeriesInlineMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/TimeSeriesInlineMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IsolatedNamespacesWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IsolatedNamespacesWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IsolatedNamespacesWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicatePropertiesMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicatePropertiesMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicatePropertiesMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LocalResolveTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LocalResolveTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LocalResolveTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PropertyEncodingOrderMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PropertyEncodingOrderMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PropertyEncodingOrderMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/AbstractMapPreviewPageTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/AbstractMapPreviewPageTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/AbstractMapPreviewPageTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceExceptionMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceExceptionMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceExceptionMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NormalizedMultiValuesTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NormalizedMultiValuesTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NormalizedMultiValuesTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XYGeomTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XYGeomTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XYGeomTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceExceptionTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceExceptionTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceExceptionTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32Test.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32Test.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32Test.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupCoverageWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupCoverageWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupCoverageWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DefaultIdTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DefaultIdTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DefaultIdTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml30MockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml30MockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml30MockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CoordinatesFormattingTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CoordinatesFormattingTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CoordinatesFormattingTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CSVOutputFormatTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CSVOutputFormatTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CSVOutputFormatTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Observation_2_0_WfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Observation_2_0_WfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Observation_2_0_WfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOracleWithJoiningTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOracleWithJoiningTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOracleWithJoiningTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicateTypeMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicateTypeMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicateTypeMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractDataReferenceWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractDataReferenceWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractDataReferenceWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineOracleTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineOracleTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineOracleTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeIntervalMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeIntervalMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml32BoreholeIntervalMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedGeometryFilterEncodingTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedGeometryFilterEncodingTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedGeometryFilterEncodingTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkGeometryMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkGeometryMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkGeometryMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsPostgisWithJoiningTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsPostgisWithJoiningTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsPostgisWithJoiningTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/GeoJsonOutputFormatWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/GeoJsonOutputFormatWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/GeoJsonOutputFormatWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdNotEncodedTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdNotEncodedTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdNotEncodedTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsOnlineTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsOnlineTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsOnlineTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicatePropertiesWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicatePropertiesWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicatePropertiesWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MultivaluedXlinkHrefTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MultivaluedXlinkHrefTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MultivaluedXlinkHrefTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/WfsOnlineTestPostgisSetup.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/WfsOnlineTestPostgisSetup.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/WfsOnlineTestPostgisSetup.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/StationsMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/StationsMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/StationsMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/StationsAppSchemaTestSupport.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/StationsAppSchemaTestSupport.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/StationsAppSchemaTestSupport.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecondaryNamespaceMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOnlineTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOnlineTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOnlineTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ReprojectionAxisFlipTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ReprojectionAxisFlipTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ReprojectionAxisFlipTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaTestOracleSetup.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaTestOracleSetup.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaTestOracleSetup.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismInlineMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismInlineMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismInlineMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsGetLegendGraphicTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsGetLegendGraphicTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsGetLegendGraphicTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBoxMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBoxMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBoxMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingSharedConnectionTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingSharedConnectionTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingSharedConnectionTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SameNameDiffNamespaceTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SameNameDiffNamespaceTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SameNameDiffNamespaceTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32ResolveMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32ResolveMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32ResolveMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataOracleSetup.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataOracleSetup.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataOracleSetup.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32MockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32MockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureGML32MockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespaceTestData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespaceTestData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespaceTestData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsPostgisTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsPostgisTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsPostgisTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/TimeSeriesWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/TimeSeriesWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/TimeSeriesWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicateTypeTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicateTypeTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DuplicateTypeTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/InvalidColumnTestData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/InvalidColumnTestData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/InvalidColumnTestData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespacesWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespacesWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespacesWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PropertyEncodingOrderTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PropertyEncodingOrderTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PropertyEncodingOrderTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SortByTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SortByTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SortByTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XlinkMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DefaultIdMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DefaultIdMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/DefaultIdMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsOracleTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsOracleTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWmsOracleTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTestMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTestMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTestMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBox3DTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBox3DTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/BBox3DTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml30WfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml30WfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Gsml30WfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsPostgisTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsPostgisTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsPostgisTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ConnectionUsageMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ConnectionUsageMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ConnectionUsageMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XPathPredicateTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XPathPredicateTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/XPathPredicateTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/Gml32LinksTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/Gml32LinksTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/Gml32LinksTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SubstitutionGroupMockData.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/WfsOnlineTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MeasureTypeBindingTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MeasureTypeBindingTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/MeasureTypeBindingTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecuredFeatureChainingTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecuredFeatureChainingTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SecuredFeatureChainingTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsSupportMockData.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsSupportMockData.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WmsSupportMockData.java>: Too many open files
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-web-wcs: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target> -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-netcdf-out: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/target/maven-status/maven-compiler-plugin/testCompile/default-testCompile/createdFiles.lst> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-core: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java>:\[20,8\] error while writing org.geoserver.importer.ImporterUtils: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/core/target/classes/org/geoserver/importer/ImporterUtils.class>: Too many open files
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-csw-core: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target> -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-jdbc: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCRoleServicePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCConnectionPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCAuthProviderPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCUserGroupServicePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/src/main/java/org/geoserver/security/web/jdbc/JDBCDriverChoice.java>: Too many open files
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-install-plugin:2.4:install (default-install) on project gs-security: Failed to install artifact org.geoserver.extension:gs-security:pom:2.16-SNAPSHOT: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-security/2.16-SNAPSHOT/gs-security-2.16-SNAPSHOT.pom> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-geofence: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/target/classes/org/geoserver/geofence/web/authentication/GeoFenceAuthProviderPanel.html> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-web-wcs2_0-eo: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wcs2_0-eo/web/target/classes/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.html> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-ldap: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[5,1\] cannot access org.geoserver.web.security.ldap
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/codehaus/mojo/animal-sniffer-annotations/1.17/animal-sniffer-annotations-1.17.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[18,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[18,48\] cannot find symbol
[ERROR] symbol: class UserGroupServicePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[18,70\] cannot find symbol
[ERROR] symbol: class LDAPUserGroupServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[42,38\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.web.security.ldap.LDAPUserGroupServicePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[42,49\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[42,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[21,43\] cannot find symbol
[ERROR] symbol: class WebMarkupContainer
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[25,40\] cannot find symbol
[ERROR] location: class org.geoserver.web.security.ldap.LDAPUserGroupServicePanel.LDAPAuthenticationPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>:\[20,8\] cannot access org.geoserver.web.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>:\[20,43\] cannot find symbol
[ERROR] symbol: class RoleServicePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>:\[20,60\] cannot find symbol
[ERROR] symbol: class LDAPRoleServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>:\[46,44\] cannot find symbol
[ERROR] location: class org.geoserver.web.security.ldap.LDAPRoleServicePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>:\[46,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanel.java>:\[24,43\] cannot find symbol
[ERROR] symbol: class FormComponentPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanelInfo.java>:\[12,8\] cannot access org.geoserver.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanelInfo.java>:\[13,17\] cannot find symbol
[ERROR] symbol: class RoleServicePanelInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPRoleServicePanelInfo.java>:\[13,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanelInfo.java>:\[17,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanelInfo.java>:\[18,17\] cannot find symbol
[ERROR] symbol: class AuthenticationProviderPanelInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanelInfo.java>:\[18,49\] cannot find symbol
[ERROR] symbol: class LDAPSecurityServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[38,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[38,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[38,72\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[42,45\] cannot find symbol
[ERROR] location: class org.geoserver.web.security.ldap.LDAPAuthProviderPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[42,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[88,47\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[88,66\] cannot find symbol
[ERROR] symbol: class HashMap
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[138,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPAuthProviderPanel.java>:\[138,62\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-ogr-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: Too many open files
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: Too many open files
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-wps-cluster-hazelcast: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/target> -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: Too many open files
[ERROR] -> [Help 3]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginResolutionException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-inspire
Not sending mail to unregistered user cmhodgson@anonymised.com
Not sending mail to unregistered user nuno.oliveira@anonymised.com
Not sending mail to unregistered user noreply@anonymised.com
Hudson
6
