[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #292
See <https://build.geoserver.org/job/geoserver-java11-qa/292/display/redirect&gt;
[...truncated 1.53 MB...]
  symbol: variable IOUtils
[INFO] 12 errors
[INFO] -------------------------------------------------------------
[INFO] Reactor Summary for GeoServer Extensions 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 6.959 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.180 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 8.463 s]
[INFO] Sample DataAccess Integration Test ................. FAILURE [ 0.666 s]
[INFO] ArcSDE DataStore Extension ......................... FAILURE [ 12.411 s]
[INFO] H2 DataStore Extension ............................. FAILURE [ 10.356 s]
[INFO] SQL Server DataStore Extension ..................... FAILURE [ 1.159 s]
[INFO] Oracle DataStore Extension ......................... FAILURE [ 0.383 s]
[INFO] MySQL DataStore Extension .......................... FAILURE [ 1.112 s]
[INFO] DB2 DataStore Extension ............................ FAILURE [ 0.376 s]
[INFO] ImageMap Output Format ............................. FAILURE [ 1.895 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... FAILURE [ 3.136 s]
[INFO] JP2K Coverage Extension ............................ FAILURE [ 0.336 s]
[INFO] OGR parent ......................................... FAILURE [ 0.031 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... FAILURE [ 0.036 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ FAILURE [ 5.504 s]
[INFO] Chart external graphics support .................... FAILURE [ 2.010 s]
[INFO] Feature Generalization Extension ................... FAILURE [ 0.921 s]
[INFO] Image Mosaic JDBC Extension ........................ FAILURE [ 2.848 s]
[INFO] OWS request flow controller ........................ FAILURE [ 4.393 s]
[INFO] GeoServer Layer Querying filter functions .......... FAILURE [ 2.642 s]
[INFO] Teradata DataStore Extension ....................... FAILURE [ 2.071 s]
[INFO] GeoServer Monitor Extensions ....................... FAILURE [ 0.160 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... FAILURE [ 0.098 s]
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... FAILURE [ 1.071 s]
[INFO] GeoServer INSPIRE Extensions ....................... FAILURE [ 3.796 s]
[INFO] GeoServer CSS Styling .............................. FAILURE [ 3.751 s]
[INFO] Catalog Services for the Web parent ................ FAILURE [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. FAILURE [ 0.027 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... FAILURE [ 19.249 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... FAILURE [ 0.025 s]
[INFO] GeoServer libjpeg-turbo Module ..................... FAILURE [ 1.858 s]
[INFO] GeoServer Data Importer ............................ FAILURE [ 5.086 s]
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... FAILURE [ 15.221 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 3.757 s]
[INFO] Vector Tiles ....................................... FAILURE [ 6.219 s]
[INFO] Ysld GeoServer Plugin .............................. FAILURE [ 1.439 s]
[INFO] MongoDB Data Store ................................. FAILURE [ 0.491 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... FAILURE [ 1.099 s]
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... FAILURE [ 1.778 s]
[INFO] BUILD FAILURE
[INFO] Total time: 01:14 min (Wall Clock)
[INFO] Finished at: 2019-07-12T11:30:08Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-h2: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-sqlserver: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-oracle: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-arcsde: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-db2: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-mysql: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-imagemap: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[16,25\] cannot find symbol
[ERROR] symbol: class DefaultQuery
[ERROR] location: package org.geotools.data
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[128,37\] cannot find symbol
[ERROR] symbol: method getRules()
[ERROR] location: variable style of type org.geotools.styling.FeatureTypeStyle
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[137,26\] cannot find symbol
[ERROR] symbol: method hasElseFilter()
[ERROR] location: variable r of type org.geotools.styling.Rule
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[188,53\] cannot find symbol
[ERROR] symbol: method getFeatureTypeStyles()
[ERROR] location: variable style of type org.geotools.styling.Style
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[198,54\] cannot find symbol
[ERROR] symbol: method getFeatureTypeName()
[ERROR] location: variable featureTypeStyle of type org.geotools.styling.FeatureTypeStyle
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[199,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[205,29\] cannot find symbol
[ERROR] symbol: method setRules(org.geotools.styling.Rule)
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[334,29\] cannot find symbol
[ERROR] location: class org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/HTMLImageMapWriter.java&gt;:\[215,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/HTMLImageMapWriter.java&gt;:\[232,21\] cannot find symbol
[ERROR] location: variable rule of type org.geotools.styling.Rule
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/HTMLImageMapWriter.java&gt;:\[271,25\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-jp2k: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-ogr: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-wps: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-gdal: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-charts: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-feature-pregeneralized: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/feature-pregeneralized/src/main/java/org/geoserver/data/gen/DSFinderRepository.java&gt;:\[38,24\] cannot find symbol
[ERROR] symbol: method url(java.lang.String)
[ERROR] location: variable loader of type org.geoserver.platform.GeoServerResourceLoader
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/feature-pregeneralized/src/main/java/org/geoserver/data/gen/info/GeneralizationInfosProviderImpl.java&gt;:\[35,28\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-excel: Compilation failure
[ERROR] warnings found and -Werror specified
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-imagemosaic-jdbc: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-querylayer: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-control-flow: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-monitor: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-security: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-xslt: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/xslt/src/main/java/org/geoserver/wfs/xslt/config/TransformRepository.java&gt;: warnings found and -Werror specified
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-teradata: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-inspire: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-csw: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-dxf: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-css: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/css/src/main/java/org/geoserver/community/css/web/CssHandler.java&gt;: warnings found and -Werror specified
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-wcs2_0-eo: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-libjpeg-turbo: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-importer: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&gt;: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml&#39;\.&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-printing: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/printing/src/main/java/org/geoserver/printing/PrintingServletWrappingController.java&gt;:\[11,31\] cannot find symbol
[ERROR] symbol: class IOUtils
[ERROR] location: package org.geoserver.data.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/printing/src/main/java/org/geoserver/printing/PrintingServletWrappingController.java&gt;:\[42,17\] cannot find symbol
[ERROR] symbol: variable IOUtils
[ERROR] location: class org.geoserver.printing.PrintingServletWrappingController
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-grib: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-netcdf: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-ysld: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ysld/src/main/java/org/geoserver/ysld/YsldHandler.java&gt;: warnings found and -Werror specified
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-mongodb: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/pmd-ruleset.xml’.> -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/config/GeoFenceConfigurationManager.java&gt;: warnings found and -Werror specified
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java&gt;:\[302,33\] cannot find symbol
[ERROR] symbol: method getPrefixedName()
[ERROR] location: variable resource of type org.geoserver.catalog.ResourceInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java&gt;:\[375,47\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-authkey: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/authkey/pom.xml&gt; isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-vectortiles: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/vectortiles/src/main/java/org/geotools/renderer/lite/VectorMapRenderUtils.java&gt;:\[442,62\] cannot find symbol
[ERROR] location: variable fts of type org.geotools.styling.FeatureTypeStyle
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/vectortiles/src/main/java/org/geotools/renderer/lite/VectorMapRenderUtils.java&gt;:\[444,57\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-sample-data-access-test: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/sample-data-access-test/src/test/java/org/geoserver/test/SampleDataAccessMockData.java&gt;:\[20,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/sample-data-access-test/src/test/java/org/geoserver/test/SampleDataAccessMockData.java&gt;:\[64,16\] cannot find symbol
[ERROR] location: class org.geoserver.test.SampleDataAccessMockData
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/sample-data-access-test/src/test/java/org/geoserver/test/SampleDataAccessMockData.java&gt;:\[123,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/sample-data-access-test/src/test/java/org/geoserver/test/SampleDataAccessMockData.java&gt;:\[170,9\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-app-schema-test: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java&gt;:\[29,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaTestOracleSetup.java&gt;:\[17,28\] cannot find symbol
[ERROR] symbol: class IllegalAttributeException
[ERROR] location: package org.geotools.feature
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/AppSchemaTestOracleSetup.java&gt;:\[133,20\] cannot find symbol
[ERROR] location: class org.geoserver.test.onlineTest.setup.AppSchemaTestOracleSetup
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/RestconfigWfsTest.java&gt;:\[32,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java&gt;:\[159,20\] cannot find symbol
[ERROR] location: class org.geoserver.test.AbstractAppSchemaMockData
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java&gt;:\[323,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java&gt;:\[356,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java&gt;:\[577,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOnlineTest.java&gt;:\[1992,84\] cannot find symbol
[ERROR] symbol: method getPattern()
[ERROR] location: class org.geotools.filter.LikeFilterImpl
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/RestconfigWfsTest.java&gt;:\[69,27\] cannot find symbol
[ERROR] symbol: method unregisterAll()
[ERROR] location: class org.geotools.data.complex.DataAccessRegistry
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/RestconfigWfsTest.java&gt;:\[230,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.RestconfigWfsTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/RestconfigWfsTest.java&gt;:\[259,9\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-h2
See <https://build.geoserver.org/job/geoserver-java11-qa/293/display/redirect&gt;
