See <https://build.geoserver.org/job/geoserver-java11-qa/3/display/redirect?page=changes>
Changes:
[fgdrf] integrates latest Korean Translations
[giovanni.scardapanegeo-solutions.it] Update doc - Generating SLD raster styles with QGIS
[...truncated 1.82 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/DataReferenceWfsOracleTest.java>:\[6,1\] cannot access org.geoserver.test.onlineTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/apache/xmlgraphics/batik-transcoder/1.10/batik-transcoder-1.10.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/web/AbstractMapPreviewPageTest.java>:\[6,1\] cannot access org.geoserver.test.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractDataReferenceWfsTest.java>:\[6,1\] cannot access org.geoserver.test.onlineTest.support
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTest.java>:\[17,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[75,17\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[75,60\] cannot find symbol
[ERROR] symbol: class GeoServerSystemTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTestMockData.java>:\[14,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[9,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[9,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[9,15\] import requires canonical name for <any>.BufferedReader
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[17,12\] cannot access java.net
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[19,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[26,21\] cannot access org.geoserver.data
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[26,26\] package org.geoserver.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[27,26\] cannot access org.geoserver.data.test
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[27,31\] package org.geoserver.data.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[28,31\] package org.geoserver.data.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[29,26\] cannot access org.geoserver.data.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[29,31\] package org.geoserver.data.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[33,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[33,20\] cannot access org.geotools.data
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[33,33\] import requires canonical name for <any>.complex.AppSchemaDataAccessTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[34,20\] cannot access org.geotools.xml
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[34,24\] cannot access org.geotools.xml.resolver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[34,33\] import requires canonical name for <any>.SchemaCatalog
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[35,11\] cannot access org.locationtech
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[35,24\] cannot access org.locationtech.jts
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[35,33\] import requires canonical name for <any>.geom.Envelope
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[42,57\] cannot find symbol
[ERROR] symbol: class SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespaceTestData.java>:\[10,31\] package org.geoserver.data.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NamespaceTestData.java>:\[17,44\] cannot find symbol
[ERROR] symbol: class TestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[115,26\] cannot find symbol
[ERROR] symbol: class Envelope
[ERROR] location: class org.geoserver.test.AbstractAppSchemaMockData
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[145,13\] cannot find symbol
[ERROR] symbol: class SchemaCatalog
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaMockData.java>:\[211,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[88,19\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] location: class org.geoserver.test.AbstractAppSchemaTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[107,13\] cannot find symbol
[ERROR] symbol: class XpathEngine
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[110,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[135,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[149,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[169,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[186,15\] cannot find symbol
[ERROR] symbol: class InputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[194,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[210,15\] cannot find symbol
[ERROR] symbol: class Document
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[227,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[245,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[261,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[277,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[293,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[308,55\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[308,15\] cannot find symbol
[ERROR] symbol: class NodeList
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[324,74\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[335,62\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[347,67\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[359,70\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[369,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[381,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[381,51\] cannot find symbol
[ERROR] symbol: class OutputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[399,42\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[399,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[489,52\] cannot find symbol
[ERROR] symbol: class BufferedImage
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[489,73\] cannot find symbol
[ERROR] symbol: class Color
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[503,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[503,77\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[539,43\] cannot find symbol
[ERROR] symbol: class FeatureCollection
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[570,55\] cannot find symbol
[ERROR] symbol: class FeatureTypeMapping
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[587,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[587,15\] cannot find symbol
[ERROR] symbol: class NestedFilterToSQL
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[617,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[617,57\] cannot find symbol
[ERROR] symbol: class TransformerException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>:\[9,18\] cannot access org.junit
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>:\[9,24\] import requires canonical name for <any>.Assert
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>:\[11,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>:\[12,11\] cannot access org.w3c
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>:\[12,15\] cannot access org.w3c.dom
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/Reprojection3DTest.java>:\[12,19\] import requires canonical name for <any>.Document
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsWithJoiningTest.java>:\[9,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionWfsWithJoiningTest.java>:\[11,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/IdFunctionMockData.java>:\[9,31\] package org.geoserver.data.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WaterMLTimeSeriesWfsTest.java>:\[9,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WaterMLTimeSeriesWfsTest.java>:\[11,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/WaterMLTimeSeriesMockData.java>:\[9,31\] package org.geoserver.data.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataPostgisSetup.java>:\[13,25\] cannot access org.geotools.data.postgis
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataPostgisSetup.java>:\[13,33\] package org.geotools.data.postgis does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataPostgisSetup.java>:\[14,20\] cannot access org.geotools.jdbc
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/setup/ReferenceDataPostgisSetup.java>:\[14,25\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[14,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[14,18\] cannot access org.apache.log4j
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[14,24\] import requires canonical name for <any>.Logger
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[15,25\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[16,25\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[17,20\] cannot access org.geotools.referencing
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[17,32\] package org.geotools.referencing does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[18,11\] cannot access org.opengis
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[18,19\] cannot access org.opengis.feature
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[18,32\] import requires canonical name for <any>.type.GeometryType
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[19,19\] cannot access org.opengis.referencing
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[19,31\] package org.opengis.referencing does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[20,31\] cannot access org.opengis.referencing.crs
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/DataPacking.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFDimensionsManager.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFLayerSettingsContainer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCRSWriter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanelInfo.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFExtensionPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
Not sending mail to unregistered user giovanni.scardapanegeo-solutions.it
Not sending mail to unregistered user fgdrf@anonymised.com
