See <https://build.geoserver.org/job/geoserver-java11-qa/341/display/redirect>
[...truncated 585.13 KB...]
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-main <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-main ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-main >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-main ---
[INFO] Fork Value is true
[java] The following classes needed for analysis were missing:
[java] org.geoserver.security.MasterPasswordProvider
[java] org.geoserver.security.validation.RoleServiceValidationWrapper
[java] org.geoserver.config.DefaultGeoServerLoader
[java] org.geoserver.security.filter.AbstractFilterProvider
[java] org.geoserver.security.xml.XMLUserGroupStore
[java] org.geoserver.security.rememberme.RememberMeServicesFactoryBean$RememberMeServicesProxy
[java] org.geoserver.security.filter.GeoServerRememberMeAuthenticationProvider
[java] org.geoserver.config.util.XStreamPersister$StoreInfoConverter
[java] org.geoserver.security.DisabledResourceFilter
[java] org.geoserver.catalog.impl.LocalWorkspaceCatalog$NameDequalifyingProxy$1
[java] org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter
[java] org.geoserver.security.impl.GeoServerUserDao
[java] org.vfny.geoserver.global.Log4JFormatter
[java] org.geoserver.security.xml.XMLSecurityConfigException
[java] org.geoserver.catalog.impl.AttributeTypeInfoImpl
[java] org.geoserver.threadlocals.LocalPublishedThreadLocalTransfer
[java] org.geoserver.catalog.CoverageViewHandler$1
[java] org.geoserver.filters.LoggingFilter
[java] org.geoserver.security.validation.UserGroupStoreValidationWrapper
[java] org.geoserver.security.impl.SecureTreeNode$1
[java] org.geoserver.GeoserverInitStartupListener
[java] org.geoserver.catalog.CascadeRemovalReporter
[java] org.geoserver.ows.kvp.CQLFilterKvpParser
[java] org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter
[java] org.geoserver.security.decorators.DefaultSecureCatalogFactory
[java] org.geoserver.config.LegacyGeoServerLoader
[java] Missing classes: 4
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-main <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-main ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-main ---
[INFO]
[INFO]
[INFO] Skipping GeoServer Security Modules
[INFO] Skipping Web Coverage Service Module
[INFO]
[INFO] Skipping Web Feature Service Module
[INFO]
[INFO] Skipping gs-rest
[INFO]
[INFO] Skipping Core UI Module
[INFO]
[INFO] Skipping GeoServer Security Tests Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping gs-restconfig
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demos Module
[INFO]
[INFO] Skipping gs-restconfig-wcs
[INFO]
[INFO] Skipping gs-restconfig-wfs
[INFO]
[INFO] Skipping gs-restconfig-wms
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping WCS UI Module
[INFO] Skipping Security UI Modules
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 38.805 s]
[INFO] Core Platform Module ............................... SUCCESS [ 43.502 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 26.242 s]
[INFO] Main Module ........................................ FAILURE [01:54 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.167 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.059 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.084 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:45 min (Wall Clock)
[INFO] Finished at: 2019-08-13T16:40:10Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-checkstyle-plugin:3.0.0:check (default) on project gs-main: Failed during checkstyle execution: Unable to find configuration file at location: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml>: Could not find resource '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/../build/qa/checkstyle.xml'\.> -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
