See <https://build.geoserver.org/job/geoserver-java11-qa/35/display/redirect?page=changes>
Changes:
[cmhodgson] Added MapML support for WFS GetFeature and WMS GetFeatureInfo
[...truncated 2.72 MB...]
[ERROR] location: class org.geoserver.wps.ogr.OgrXMLPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>:\[29,13\] cannot find symbol
[ERROR] symbol: class Operation
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>:\[36,13\] cannot find symbol
[ERROR] symbol: class Ogr2OgrOutputFormat
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>:\[37,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>:\[49,38\] cannot find symbol
[ERROR] symbol: class OutputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>:\[57,12\] cannot find symbol
[ERROR] symbol: class PPIODirection
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>:\[67,38\] cannot find symbol
[ERROR] symbol: class ContentHandler
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>:\[81,26\] cannot find symbol
[ERROR] symbol: class InputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[18,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/si/uom/si-units-java8/0.7.1/si-units-java8-0.7.1.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[18,36\] cannot find symbol
[ERROR] symbol: class BinaryPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[20,13\] cannot find symbol
[ERROR] location: class org.geoserver.wps.ogr.OgrBinaryPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[22,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[29,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[30,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[38,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[51,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>:\[56,26\] cannot find symbol
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure: Compilation failure:
[ERROR] error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/com/hazelcast/hazelcast/3.11.1/hazelcast-3.11.1.jar;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/com/hazelcast/hazelcast/3.11.1/hazelcast-3.11.1.jar> (Too many open files)
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java>:\[5,1\] cannot access org.geoserver.wps.hz
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/it/geosolutions/imageio-ext/imageio-ext-arcgrid/1.3.0/imageio-ext-arcgrid-1.3.0.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[30,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[30,41\] cannot find symbol
[ERROR] symbol: class DisposableBean
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[31,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.wps.hz.HazelcastLoader
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[34,25\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[37,13\] cannot find symbol
[ERROR] symbol: class HazelcastInstance
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[45,28\] cannot find symbol
[ERROR] symbol: class ResourceStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[45,56\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[67,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[77,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[86,40\] cannot find symbol
[ERROR] symbol: class Config
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java>:\[118,34\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[69,8\] cannot access org.geoserver.wps
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[69,42\] cannot find symbol
[ERROR] symbol: class FilterVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[119,25\] cannot find symbol
[ERROR] symbol: class ExcludeFilter
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[124,25\] cannot find symbol
[ERROR] symbol: class IncludeFilter
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[130,25\] cannot find symbol
[ERROR] symbol: class And
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[139,25\] cannot find symbol
[ERROR] symbol: class Id
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[148,25\] cannot find symbol
[ERROR] symbol: class Not
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[153,25\] cannot find symbol
[ERROR] symbol: class Or
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[162,25\] cannot find symbol
[ERROR] symbol: class PropertyIsBetween
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[169,36\] cannot find symbol
[ERROR] symbol: class Expression
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[183,25\] cannot find symbol
[ERROR] symbol: class PropertyIsEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[189,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNotEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[195,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[203,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[211,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[219,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[227,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLike
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[238,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNull
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[244,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNil
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[250,25\] cannot find symbol
[ERROR] symbol: class BBOX
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[255,25\] cannot find symbol
[ERROR] symbol: class Beyond
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[260,25\] cannot find symbol
[ERROR] symbol: class Contains
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[265,25\] cannot find symbol
[ERROR] symbol: class Crosses
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[270,25\] cannot find symbol
[ERROR] symbol: class Disjoint
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[275,25\] cannot find symbol
[ERROR] symbol: class DWithin
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[280,25\] cannot find symbol
[ERROR] symbol: class Equals
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[285,25\] cannot find symbol
[ERROR] symbol: class Intersects
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[290,25\] cannot find symbol
[ERROR] symbol: class Overlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[295,25\] cannot find symbol
[ERROR] symbol: class Touches
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[300,25\] cannot find symbol
[ERROR] symbol: class Within
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[305,25\] cannot find symbol
[ERROR] symbol: class After
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[313,25\] cannot find symbol
[ERROR] symbol: class AnyInteracts
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[318,25\] cannot find symbol
[ERROR] symbol: class Before
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[326,25\] cannot find symbol
[ERROR] symbol: class Begins
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[331,25\] cannot find symbol
[ERROR] symbol: class BegunBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[336,25\] cannot find symbol
[ERROR] symbol: class During
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[341,25\] cannot find symbol
[ERROR] symbol: class EndedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[346,25\] cannot find symbol
[ERROR] symbol: class Ends
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[351,25\] cannot find symbol
[ERROR] symbol: class Meets
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[356,25\] cannot find symbol
[ERROR] symbol: class MetBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[361,25\] cannot find symbol
[ERROR] symbol: class OverlappedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[366,25\] cannot find symbol
[ERROR] symbol: class TContains
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[371,25\] cannot find symbol
[ERROR] symbol: class TEquals
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[377,25\] cannot find symbol
[ERROR] symbol: class TOverlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[78,35\] cannot find symbol
[ERROR] symbol: class BinaryComparisonOperator
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria.PropertyComparable
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[95,35\] cannot find symbol
[ERROR] symbol: class BinaryTemporalOperator
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: Too many open files
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java>: Too many open files
[ERROR] -> [Help 3]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginResolutionException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-ysld
Not sending mail to unregistered user cmhodgson@anonymised.com
