[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #368
See <https://build.geoserver.org/job/geoserver-java11-qa/368/display/redirect&gt;
[...truncated 1015.86 KB...]
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-httpclient/commons-httpclient/3.1/commons-httpclient-3.1.jar (305 kB at 2.4 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jaitools/jt-utils/1.5.0/jt-utils-1.5.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-dbcp/commons-dbcp/1.4/commons-dbcp-1.4.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-dbcp/commons-dbcp/1.4/commons-dbcp-1.4.jar (161 kB at 1.2 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xpp3/xpp3_min/1.1.4c/xpp3_min-1.1.4c.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jaitools/jt-utils/1.5.0/jt-utils-1.5.0.jar (202 kB at 1.5 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/systems/uom/systems-common-java8/0.7.2/systems-common-java8-0.7.2.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xpp3/xpp3_min/1.1.4c/xpp3_min-1.1.4c.jar (25 kB at 185 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/tec/uom/uom-se/1.0.8/uom-se-1.0.8.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/log4j/log4j/1.2.17/log4j-1.2.17.jar (490 kB at 3.6 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/measure/unit-api/1.0/unit-api-1.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/systems/uom/systems-common-java8/0.7.2/systems-common-java8-0.7.2.jar (23 kB at 170 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/tec/uom/lib/uom-lib-common/1.0.2/uom-lib-common-1.0.2.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/measure/unit-api/1.0/unit-api-1.0.jar (28 kB at 201 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/si/uom/si-quantity/0.7.1/si-quantity-0.7.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/tec/uom/lib/uom-lib-common/1.0.2/uom-lib-common-1.0.2.jar (15 kB at 107 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/si/uom/si-units-java8/0.7.1/si-units-java8-0.7.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/si/uom/si-quantity/0.7.1/si-quantity-0.7.1.jar (8.3 kB at 59 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/hsqldb/hsqldb/2.4.1/hsqldb-2.4.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/freemarker/freemarker/2.3.18/freemarker-2.3.18.jar (924 kB at 6.5 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/conversantmedia/disruptor/1.2.13/disruptor-1.2.13.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/si/uom/si-units-java8/0.7.1/si-units-java8-0.7.1.jar (16 kB at 113 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-aop/5.1.1.RELEASE/spring-aop-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/tec/uom/uom-se/1.0.8/uom-se-1.0.8.jar (222 kB at 1.6 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-jdbc/5.1.1.RELEASE/spring-jdbc-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/conversantmedia/disruptor/1.2.13/disruptor-1.2.13.jar (134 kB at 902 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/thoughtworks/xstream/xstream/1.4.10/xstream-1.4.10.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-jdbc/5.1.1.RELEASE/spring-jdbc-5.1.1.RELEASE.jar (402 kB at 2.6 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xmlpull/xmlpull/1.1.3.1/xmlpull-1.1.3.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-aop/5.1.1.RELEASE/spring-aop-5.1.1.RELEASE.jar (369 kB at 2.4 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/google/guava/guava/27.0-jre/guava-27.0-jre.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xmlpull/xmlpull/1.1.3.1/xmlpull-1.1.3.1.jar (7.2 kB at 46 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/google/guava/failureaccess/1.0/failureaccess-1.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/google/guava/failureaccess/1.0/failureaccess-1.0.jar (3.7 kB at 23 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/google/guava/listenablefuture/9999.0-empty-to-avoid-conflict-with-guava/listenablefuture-9999.0-empty-to-avoid-conflict-with-guava.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/thoughtworks/xstream/xstream/1.4.10/xstream-1.4.10.jar (590 kB at 3.7 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/checkerframework/checker-qual/2.5.2/checker-qual-2.5.2.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/google/guava/listenablefuture/9999.0-empty-to-avoid-conflict-with-guava/listenablefuture-9999.0-empty-to-avoid-conflict-with-guava.jar (2.2 kB at 14 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/google/errorprone/error_prone_annotations/2.2.0/error_prone_annotations-2.2.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/google/errorprone/error_prone_annotations/2.2.0/error_prone_annotations-2.2.0.jar (14 kB at 84 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/google/j2objc/j2objc-annotations/1.1/j2objc-annotations-1.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/google/j2objc/j2objc-annotations/1.1/j2objc-annotations-1.1.jar (8.8 kB at 53 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/mojo/animal-sniffer-annotations/1.17/animal-sniffer-annotations-1.17.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/checkerframework/checker-qual/2.5.2/checker-qual-2.5.2.jar (193 kB at 1.2 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/google/code/findbugs/jsr305/2.0.3/jsr305-2.0.3.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/mojo/animal-sniffer-annotations/1.17/animal-sniffer-annotations-1.17.jar (3.4 kB at 21 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/github/oshi/oshi-core/3.13.3/oshi-core-3.13.3.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/google/code/findbugs/jsr305/2.0.3/jsr305-2.0.3.jar (33 kB at 195 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/net/java/dev/jna/jna/5.3.1/jna-5.3.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/hsqldb/hsqldb/2.4.1/hsqldb-2.4.1.jar (1.6 MB at 8.7 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/net/java/dev/jna/jna-platform/5.3.1/jna-platform-5.3.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/github/oshi/oshi-core/3.13.3/oshi-core-3.13.3.jar (404 kB at 2.2 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jaitools/jt-vectorbinarize/1.5.0/jt-vectorbinarize-1.5.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jaitools/jt-vectorbinarize/1.5.0/jt-vectorbinarize-1.5.0.jar (11 kB at 58 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/net/sf/ehcache/ehcache/2.10.3/ehcache-2.10.3.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/net/java/dev/jna/jna/5.3.1/jna-5.3.1.jar (1.5 MB at 7.5 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/xml/bind/jaxb-api/2.4.0-b180830.0359/jaxb-api-2.4.0-b180830.0359.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/xml/bind/jaxb-api/2.4.0-b180830.0359/jaxb-api-2.4.0-b180830.0359.jar (128 kB at 622 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/glassfish/jaxb/jaxb-runtime/2.4.0-b180830.0438/jaxb-runtime-2.4.0-b180830.0438.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/google/guava/guava/27.0-jre/guava-27.0-jre.jar (2.7 MB at 12 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/glassfish/jaxb/txw2/2.4.0-b180830.0438/txw2-2.4.0-b180830.0438.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/glassfish/jaxb/jaxb-runtime/2.4.0-b180830.0438/jaxb-runtime-2.4.0-b180830.0438.jar (1.1 MB at 4.8 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/sun/istack/istack-commons-runtime/3.0.7/istack-commons-runtime-3.0.7.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/glassfish/jaxb/txw2/2.4.0-b180830.0438/txw2-2.4.0-b180830.0438.jar (70 kB at 304 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jvnet/staxex/stax-ex/1.8/stax-ex-1.8.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/sun/istack/istack-commons-runtime/3.0.7/istack-commons-runtime-3.0.7.jar (26 kB at 110 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/sun/xml/fastinfoset/FastInfoset/1.2.15/FastInfoset-1.2.15.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jvnet/staxex/stax-ex/1.8/stax-ex-1.8.jar (36 kB at 154 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/activation/javax.activation-api/1.2.0/javax.activation-api-1.2.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/net/java/dev/jna/jna-platform/5.3.1/jna-platform-5.3.1.jar (2.6 MB at 11 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/activation/javax.activation-api/1.2.0/javax.activation-api-1.2.0.jar (57 kB at 230 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jasypt/jasypt/1.9.2/jasypt-1.9.2.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/security/spring-security-config/5.1.5.RELEASE/spring-security-config-5.1.5.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/sun/xml/fastinfoset/FastInfoset/1.2.15/FastInfoset-1.2.15.jar (312 kB at 1.3 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jasypt/jasypt-springsecurity3/1.9.2/jasypt-springsecurity3-1.9.2.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jasypt/jasypt/1.9.2/jasypt-1.9.2.jar (129 kB at 513 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jasypt/jasypt-springsecurity3/1.9.2/jasypt-springsecurity3-1.9.2.jar (20 kB at 81 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/stax/stax-api/1.0.1/stax-api-1.0.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/stax/stax-api/1.0.1/stax-api-1.0.1.jar (27 kB at 104 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-core/7.6.0/wicket-core-7.6.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.jar (57 kB at 222 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/commons/commons-collections4/4.1/commons-collections4-4.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/security/spring-security-config/5.1.5.RELEASE/spring-security-config-5.1.5.RELEASE.jar (779 kB at 2.9 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-util/7.6.0/wicket-util-7.6.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-util/7.6.0/wicket-util-7.6.0.jar (379 kB at 1.4 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-request/7.6.0/wicket-request-7.6.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/commons/commons-collections4/4.1/commons-collections4-4.1.jar (751 kB at 2.7 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-extensions/7.6.0/wicket-extensions-7.6.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-request/7.6.0/wicket-request-7.6.0.jar (88 kB at 314 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-select2/7.6.0/wicketstuff-select2-7.6.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-select2/7.6.0/wicketstuff-select2-7.6.0.jar (185 kB at 639 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/de/agilecoders/wicket/webjars/wicket-webjars/0.5.3/wicket-webjars-0.5.3.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/de/agilecoders/wicket/webjars/wicket-webjars/0.5.3/wicket-webjars-0.5.3.jar (43 kB at 147 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/postgresql/postgresql/42.2.5/postgresql-42.2.5.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-core/7.6.0/wicket-core-7.6.0.jar (2.4 MB at 7.8 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/github/svenmeier/wicket-dnd/wicket-dnd/0.7.3/wicket-dnd-0.7.3.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/github/svenmeier/wicket-dnd/wicket-dnd/0.7.3/wicket-dnd-0.7.3.jar (39 kB at 128 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/xerial/sqlite-jdbc/3.27.2.1/sqlite-jdbc-3.27.2.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/postgresql/postgresql/42.2.5/postgresql-42.2.5.jar (826 kB at 2.6 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-datetime/7.6.0/wicket-datetime-7.6.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-extensions/7.6.0/wicket-extensions-7.6.0.jar (1.3 MB at 4.0 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/joda-time/joda-time/2.8.1/joda-time-2.8.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/wicket/wicket-datetime/7.6.0/wicket-datetime-7.6.0.jar (239 kB at 746 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-test/5.1.1.RELEASE/spring-test-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/joda-time/joda-time/2.8.1/joda-time-2.8.1.jar (622 kB at 1.9 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/easymock/easymock/3.6/easymock-3.6.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-test/5.1.1.RELEASE/spring-test-5.1.1.RELEASE.jar (619 kB at 1.8 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/objenesis/objenesis/2.6/objenesis-2.6.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/objenesis/objenesis/2.6/objenesis-2.6.jar (56 kB at 160 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xmlunit/xmlunit/1.3/xmlunit-1.3.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/easymock/easymock/3.6/easymock-3.6.jar (558 kB at 1.6 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-beans/5.1.1.RELEASE/spring-beans-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xmlunit/xmlunit/1.3/xmlunit-1.3.jar (97 kB at 261 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-core/5.1.1.RELEASE/spring-core-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-beans/5.1.1.RELEASE/spring-beans-5.1.1.RELEASE.jar (671 kB at 1.8 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-jcl/5.1.1.RELEASE/spring-jcl-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/net/sf/ehcache/ehcache/2.10.3/ehcache-2.10.3.jar (8.9 MB at 23 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-context/5.1.1.RELEASE/spring-context-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-jcl/5.1.1.RELEASE/spring-jcl-5.1.1.RELEASE.jar (24 kB at 62 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-expression/5.1.1.RELEASE/spring-expression-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-expression/5.1.1.RELEASE/spring-expression-5.1.1.RELEASE.jar (280 kB at 713 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-webmvc/5.1.1.RELEASE/spring-webmvc-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-core/5.1.1.RELEASE/spring-core-5.1.1.RELEASE.jar (1.3 MB at 3.0 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/springframework/spring-web/5.1.1.RELEASE/spring-web-5.1.1.RELEASE.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-context/5.1.1.RELEASE/spring-context-5.1.1.RELEASE.jar (1.1 MB at 2.5 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/ejml/ejml-ddense/0.34/ejml-ddense-0.34.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-webmvc/5.1.1.RELEASE/spring-webmvc-5.1.1.RELEASE.jar (798 kB at 1.8 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/ejml/ejml-core/0.34/ejml-core-0.34.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/xerial/sqlite-jdbc/3.27.2.1/sqlite-jdbc-3.27.2.1.jar (6.0 MB at 13 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-pool/commons-pool/1.5.4/commons-pool-1.5.4.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/ejml/ejml-core/0.34/ejml-core-0.34.jar (167 kB at 359 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/javaee-api/7.0/javaee-api-7.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/ejml/ejml-ddense/0.34/ejml-ddense-0.34.jar (320 kB at 677 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/sun/mail/javax.mail/1.5.0/javax.mail-1.5.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/springframework/spring-web/5.1.1.RELEASE/spring-web-5.1.1.RELEASE.jar (1.4 MB at 2.8 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/axis/axis/1.4/axis-1.4.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-pool/commons-pool/1.5.4/commons-pool-1.5.4.jar (96 kB at 200 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/net/sf/geographiclib/GeographicLib-Java/1.49/GeographicLib-Java-1.49.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/net/sf/geographiclib/GeographicLib-Java/1.49/GeographicLib-Java-1.49.jar (37 kB at 73 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/sun/mail/javax.mail/1.5.0/javax.mail-1.5.0.jar (522 kB at 1.0 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/locationtech/jts/jts-core/1.16.1/jts-core-1.16.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/jdom/jdom2/2.0.6/jdom2-2.0.6.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/jdom/jdom2/2.0.6/jdom2-2.0.6.jar (305 kB at 582 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/commons/commons-text/1.4/commons-text-1.4.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/javaee-api/7.0/javaee-api-7.0.jar (1.9 MB at 3.7 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/directory/server/apacheds-all/2.0.0-M24/apacheds-all-2.0.0-M24.jar (20 MB at 39 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/core/jackson-core/2.9.9/jackson-core-2.9.9.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/4.12/junit-4.12.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/axis/axis/1.4/axis-1.4.jar (1.6 MB at 3.0 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/hamcrest/hamcrest-core/1.3/hamcrest-core-1.3.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/locationtech/jts/jts-core/1.16.1/jts-core-1.16.1.jar (854 kB at 1.6 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/hamcrest/hamcrest-core/1.3/hamcrest-core-1.3.jar (45 kB at 85 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/commons/commons-text/1.4/commons-text-1.4.jar (184 kB at 346 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/4.12/junit-4.12.jar (315 kB at 592 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/core/jackson-core/2.9.9/jackson-core-2.9.9.jar (326 kB at 610 kB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-ldap ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-ldap ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/main/java&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-ldap ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-ldap ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-ldap ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-ldap ---
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 37.039 s]
[INFO] Core Platform Module ............................... SUCCESS [ 42.127 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 27.577 s]
[INFO] Main Module ........................................ SUCCESS [01:57 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.094 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 6.339 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 8.780 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 14.792 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.834 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.951 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.280 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 17.057 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 37.742 s]
[INFO] Web Map Service Module ............................. FAILURE [01:19 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 10.391 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [ 20.920 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 6.583 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 9.491 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.211 s]
[INFO] Core UI Module ..................................... SUCCESS [ 51.427 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 6.225 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.068 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 15.435 s]
[INFO] Security UI JDBC Module ............................ FAILURE [ 2.680 s]
[INFO] Security UI LDAP Module ............................ FAILURE [ 12.767 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.102 s]
[INFO] Community Space .................................... SUCCESS [ 0.071 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.062 s]
[INFO] BUILD FAILURE
[INFO] Total time: 06:42 min (Wall Clock)
[INFO] Finished at: 2019-08-16T09:43:09Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-install-plugin:2.4:install (default-install) on project gs-wms: Failed to install artifact org.geoserver:gs-wms:pom:2.16-SNAPSHOT: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wms/pom.xml&gt; (No such file or directory) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd (pmd) on project gs-web-sec-jdbc: Execution pmd of goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:pmd failed: org.apache.maven.reporting.MavenReportException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/target/pmd.xml&gt; (No such file or directory) -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-ldap: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/pom.xml&gt; isn't a file. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-java11-qa/369/display/redirect&gt;
