[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #406
See <https://build.geoserver.org/job/geoserver-java11-qa/406/display/redirect&gt;
[...truncated 891.44 KB...]
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-demo ---
[INFO] Copying 29 resources
[INFO] Copying 11 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-demo ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 18 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/src/main/java/org/geoserver/web/demo/SRSDescriptionPage.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/src/main/java/org/geoserver/web/demo/SRSDescriptionPage.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-demo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-demo ---
[INFO] Compiling 6 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-demo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-demo ---
[debug] Using AOSP style
[INFO] Processed 24 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-demo >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-demo ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-demo <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-demo ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-demo >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-demo ---
[INFO] Fork Value is true
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-wms <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-wms ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-wms ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wms ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wms/target/gs-web-wms-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wms/2.16-SNAPSHOT/gs-web-wms-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --------------------< org.geoserver.web:gs-web-gwc >--------------------
[INFO] Building GWC UI Module 2.16-SNAPSHOT [32/36]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-gwc ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-gwc ---
[INFO] Copying 19 resources
[INFO] Copying 37 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-gwc ---
[INFO] Compiling 51 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/src/main/java/org/geoserver/gwc/web/gridset/AbstractGridSetPage.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/src/main/java/org/geoserver/gwc/web/gridset/AbstractGridSetPage.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-gwc ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-gwc ---
[INFO] Compiling 18 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-gwc ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-demo <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-demo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-demo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-demo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/demo/target/gs-web-demo-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-demo/2.16-SNAPSHOT/gs-web-demo-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping WCS UI Module
[INFO] Processed 69 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-gwc >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-gwc ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-gwc <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-gwc ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-gwc >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-gwc ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-gwc <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-gwc ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 51.271 s]
[INFO] Core Platform Module ............................... SUCCESS [ 45.622 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 26.416 s]
[INFO] Main Module ........................................ SUCCESS [01:49 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.133 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 9.249 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 14.181 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.400 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 9.346 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.734 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 5.892 s]
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SUCCESS [ 47.578 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:29 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.559 s]
[INFO] gs-rest ............................................ SUCCESS [ 13.920 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 31.912 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 25.342 s]
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 8.434 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.965 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.149 s]
[INFO] Core UI Module ..................................... SUCCESS [ 50.085 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 19.167 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 19.701 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.669 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.862 s]
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.078 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 21.213 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 10.860 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 9.052 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.058 s]
[INFO] Community Space .................................... SUCCESS [ 0.118 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.099 s]
[INFO] BUILD FAILURE
[INFO] Total time: 08:00 min (Wall Clock)
[INFO] Finished at: 2019-08-18T18:20:10Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-wcs1_1: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs1_1/src/test/java/org/geoserver/wcs/GetCoverageTest.java&gt;:\[332,32\] cannot access org.geotools.data.DataSourceException
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geotools/gt-main/22-SNAPSHOT/gt-main-22-SNAPSHOT.jar(/org/geotools/data/DataSourceException.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid literal/length code
[ERROR] Please remove or make sure it appears in the correct subdirectory of the classpath.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs1_1
See <https://build.geoserver.org/job/geoserver-java11-qa/407/display/redirect&gt;
