[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #422
See <https://build.geoserver.org/job/geoserver-java11-qa/422/display/redirect&gt;
[...truncated 988.06 KB...]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-sec-jdbc ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-ldap ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-ldap ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/test-classes&gt;
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-sec-jdbc <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-sec-jdbc ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-sec-jdbc >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-sec-jdbc ---
[INFO] Fork Value is true
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-ldap ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-ldap ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-ldap ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec-ldap ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-ldap ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-ldap ---
     [java] [debug] Using AOSP style
[INFO] Processed 9 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-sec-ldap >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-sec-ldap ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-sec-ldap <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-sec-ldap ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-sec-ldap >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-sec-ldap ---
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-sec-jdbc <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-sec-jdbc ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-sec-jdbc ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec-jdbc ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/target/gs-web-sec-jdbc-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-jdbc/2.16-SNAPSHOT/gs-web-sec-jdbc-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-jdbc/2.16-SNAPSHOT/gs-web-sec-jdbc-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/target/gs-web-sec-jdbc-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-jdbc/2.16-SNAPSHOT/gs-web-sec-jdbc-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/target/gs-web-sec-jdbc-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-jdbc/2.16-SNAPSHOT/gs-web-sec-jdbc-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/jdbc/target/gs-web-sec-jdbc-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-jdbc/2.16-SNAPSHOT/gs-web-sec-jdbc-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] --------------------< org.geoserver.web:gs-web-wcs >--------------------
[INFO] Building WCS UI Module 2.16-SNAPSHOT [34/36]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wcs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wcs ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-wcs ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs ---
[INFO] Copying 14 resources
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-wcs ---
[INFO] Compiling 10 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/classes&gt;
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-sec-ldap <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec-ldap ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/publish/WCSLayerConfig.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/publish/WCSLayerConfig.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-wcs ---
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt; uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-wcs ---
[INFO] Processed 13 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-wcs >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-wcs ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-wcs <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-wcs >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-wcs ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-wcs <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 30.958 s]
[INFO] Core Platform Module ............................... SUCCESS [ 40.607 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 25.863 s]
[INFO] Main Module ........................................ SUCCESS [02:16 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.134 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 8.508 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 9.062 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.020 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 8.183 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.344 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.063 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 19.949 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 37.958 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:07 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 15.751 s]
[INFO] gs-rest ............................................ SUCCESS [ 11.769 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 4.166 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 18.666 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 5.681 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 6.163 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 6.125 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.144 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.721 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 13.494 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 7.740 s]
[INFO] Demos Module ....................................... SUCCESS [ 11.760 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 7.104 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.072 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 18.440 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 6.367 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 6.475 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.578 s]
[INFO] Community Space .................................... SUCCESS [ 0.068 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.059 s]
[INFO] BUILD FAILURE
[INFO] Total time: 07:08 min (Wall Clock)
[INFO] Finished at: 2019-08-19T15:43:33Z
[ERROR] Failed to execute goal on project gs-gwc: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.16-SNAPSHOT: Could not transfer artifact stax:stax:jar:1.2.0 from/to central (https://repo.maven.apache.org/maven2): Connection reset -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-java11-qa/423/display/redirect?page=changes&gt;
