See <https://build.geoserver.org/job/geoserver-java11-qa/426/display/redirect>
[...truncated 1.87 MB...]
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-csw-core ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-csw-core ---
[INFO] Copying gt-main-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gt-main-22-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gwc-core-1.16-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-csw-core ---
[java] [debug] Using AOSP style
[INFO] Processed 85 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-csw-core >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-csw-core ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-importer-web ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-importer-web ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-csw-core <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-csw-core ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-csw-core >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-csw-core ---
[INFO] Fork Value is true
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-csw-core <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-csw-core ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-csw-core ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-csw-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.16-SNAPSHOT/gs-csw-core-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.16-SNAPSHOT/gs-csw-core-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.16-SNAPSHOT/gs-csw-core-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.16-SNAPSHOT/gs-csw-core-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.16-SNAPSHOT/gs-csw-core-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --------------------< org.geoserver.csw:gs-web-csw >--------------------
[INFO] Building CSW UI Module 2.16-SNAPSHOT [64/65]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-csw ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-web-csw ---
[INFO] Copying gt-main-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gt-main-22-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gwc-core-1.16-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-csw >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-csw ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-csw ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-csw >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-csw ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for GeoServer Extensions 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 7.628 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.259 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 19.546 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.998 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.537 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.328 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.775 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.783 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.679 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.644 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.407 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.084 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.670 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.064 s]
[INFO] OGR CORE ........................................... SUCCESS [ 6.441 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.196 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.062 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 36.715 s]
[INFO] OGR WPS ............................................ SUCCESS [ 7.024 s]
[INFO] Excel Output Format ................................ SUCCESS [ 10.039 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.549 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.949 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.624 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.072 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.988 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 13.781 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 7.462 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 6.542 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.119 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 20.943 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.100 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 13.103 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.076 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 7.123 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 9.724 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 10.354 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.235 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.060 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.771 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.220 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 14.563 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.478 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.826 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.831 s]
[INFO] Printing Module .................................... SUCCESS [ 9.125 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.065 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.067 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.021 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.935 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.570 s]
[INFO] Importer Core Module ............................... SUCCESS [ 20.959 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 12.263 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 8.792 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 14.932 s]
[INFO] GRIB Coverage Format ............................... FAILURE [ 6.969 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.487 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 18.005 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 8.238 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 8.897 s]
[INFO] REST SLD service ................................... SUCCESS [ 17.914 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 15.519 s]
[INFO] GeoFence Server .................................... SUCCESS [ 37.419 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 11.618 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:55 min (Wall Clock)
[INFO] Finished at: 2019-08-19T22:52:40Z
[ERROR] Failed to execute goal on project gs-grib: Could not resolve dependencies for project org.geoserver.extension:gs-grib:jar:2.16-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-grib:jar:22-SNAPSHOT -> org.geotools:gt-netcdf:jar:22-SNAPSHOT -> edu.ucar:netcdf4:jar:4.6.11 -> net.java.dev.jna:jna:jar:4.2.2: Failed to read artifact descriptor for net.java.dev.jna:jna:jar:4.2.2: Failure to transfer net.java.dev.jna:jna:pom:4.2.2 from https://repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced. Original error: Could not transfer artifact net.java.dev.jna:jna:pom:4.2.2 from/to central (https://repo.maven.apache.org/maven2\): <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/net/java/dev/jna/jna/4.2.2/jna-4.2.2.pom.part> (No such file or directory) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-grib
