See <https://build.geoserver.org/job/geoserver-java11-qa/446/display/redirect>
[...truncated 1.86 MB...]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-wcs2_0-eo ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-wcs2_0-eo ---
[INFO] Fork Value is true
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-dxf-wps <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-dxf-wps ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-dxf-wps ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/dxf/wps/pom.xml to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --------------< org.geoserver.importer:gs-importer-rest >---------------
[INFO] Building Importer REST Api Module-ng 2.16-SNAPSHOT [60/65]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet.ext.fileupload/1.0.8/org.restlet.ext.fileupload-1.0.8.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet.ext.fileupload/1.0.8/org.restlet.ext.fileupload-1.0.8.pom (1.0 kB at 27 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet/1.0.8/org.restlet-1.0.8.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet/1.0.8/org.restlet-1.0.8.pom (667 B at 32 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet.ext.fileupload/1.0.8/org.restlet.ext.fileupload-1.0.8.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet/1.0.8/org.restlet-1.0.8.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet/1.0.8/org.restlet-1.0.8.jar (175 kB at 5.2 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/restlet/org.restlet.ext.fileupload/1.0.8/org.restlet.ext.fileupload-1.0.8.jar (2.6 kB at 57 kB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-importer-rest ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-rest ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-importer-rest ---
[INFO] Highest basedir set to: /tmp/jenkins-f21f8778/workspace/java11/src
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-importer-rest ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 19 source files to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/classes
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java: Some input files use unchecked or unsafe operations.
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-rest ---
[INFO] Compiling 12 source files to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/test-classes
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT.jar
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/wcs2_0-eo/web/pom.xml to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT.pom
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-tests.jar
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-sources.jar
[INFO] Installing /tmp/jenkins-f21f8778/workspace/java11/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar to /tmp/jenkins-f21f8778/workspace/java11/m2/org/geoserver/extension/gs-web-wcs2_0-eo/2.16-SNAPSHOT/gs-web-wcs2_0-eo-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.importer:gs-importer-bdb >---------------
[INFO] Building Importer Berkley DB Persistence Module 2.16-SNAPSHOT [61/65]
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/sleepycat/je/4.1.10/je-4.1.10.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/com/sleepycat/je/4.1.10/je-4.1.10.pom (1.9 kB at 70 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.pom (7.4 kB at 1.2 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/sleepycat/je/4.1.10/je-4.1.10.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/com/sleepycat/je/4.1.10/je-4.1.10.jar (2.2 MB at 41 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/ning/compress-lzf/0.9.1/compress-lzf-0.9.1.jar (33 kB at 6.6 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-importer-bdb ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-bdb ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-importer-bdb ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-bdb ---
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-importer-bdb ---
[INFO] Compiling 4 source files to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/classes
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportTransformTest.java: Some input files use unchecked or unsafe operations.
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportTransformTest.java: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-rest ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-importer-rest ---
[INFO] Copying gt-main-22-SNAPSHOT.jar to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/dependency/gt-main-22-SNAPSHOT.jar
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/rest/target/dependency/gwc-core-1.16-SNAPSHOT.jar
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java: Some input files use unchecked or unsafe operations.
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-bdb ---
[INFO] skip non existing resourceDirectory /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/src/test/resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-bdb ---
[INFO] Compiling 4 source files to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/test-classes
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-importer-rest >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-importer-rest ---
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBindingTest.java: Some input files use unchecked or unsafe operations.
[INFO] /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/src/test/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBindingTest.java: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-bdb ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-importer-bdb ---
[INFO] Copying gt-main-22-SNAPSHOT.jar to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/dependency/gt-main-22-SNAPSHOT.jar
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to /tmp/jenkins-f21f8778/workspace/java11/src/extension/importer/bdb/target/dependency/gwc-core-1.16-SNAPSHOT.jar
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-bdb ---
[java] [debug] Using AOSP style
[INFO] Processed 8 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-bdb >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-bdb ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-bdb <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-bdb ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-importer-bdb >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-importer-bdb ---
FATAL: command execution failed
java.io.EOFException
at java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2681)
at java.io.ObjectInputStream$BlockDataInputStream.readShort(ObjectInputStream.java:3156)
at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:862)
at java.io.ObjectInputStream.<init>(ObjectInputStream.java:358)
at hudson.remoting.ObjectInputStreamEx.<init>(ObjectInputStreamEx.java:49)
at hudson.remoting.Command.readFrom(Command.java:140)
at hudson.remoting.Command.readFrom(Command.java:126)
at hudson.remoting.AbstractSynchronousByteArrayCommandTransport.read(AbstractSynchronousByteArrayCommandTransport.java:36)
at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:63)
Caused: java.io.IOException: Unexpected termination of the channel
at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:77)
Caused: java.io.IOException: Backing channel 'i-0dbd61f15a87d0e45' is disconnected.
at hudson.remoting.RemoteInvocationHandler.channelOrFail(RemoteInvocationHandler.java:214)
at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
at com.sun.proxy.$Proxy82.isAlive(Unknown Source)
at hudson.Launcher$RemoteLauncher$ProcImpl.isAlive(Launcher.java:1150)
at hudson.Launcher$RemoteLauncher$ProcImpl.join(Launcher.java:1142)
at hudson.Launcher$ProcStarter.join(Launcher.java:470)
at hudson.tasks.Maven.perform(Maven.java:368)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:741)
at hudson.model.Build$BuildExecution.build(Build.java:206)
at hudson.model.Build$BuildExecution.doRun(Build.java:163)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:504)
at hudson.model.Run.execute(Run.java:1818)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
ERROR: FleetCloud i-0dbd61f15a87d0e45 is offline; cannot locate OpenJDK 11.0.3
