See <https://build.geoserver.org/job/geoserver-java11-qa/495/display/redirect>
[...truncated 385.21 KB...]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 52.048 s (Wall Clock)
[INFO] Finished at: 2019-08-23T16:52:20Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-platform: Compilation failure: Compilation failure:
[ERROR] error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/javax/media/jai_imageio/1.1/jai_imageio-1.1.jar;> zip file is empty
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileSystemWatcher.java>:\[6,1\] cannot access org.geoserver.platform.resource
[ERROR] zip END header not found
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/util/ErrorHandler.java>:\[6,1\] cannot access org.geoserver.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/OWS20Exception.java>:\[6,1\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/util/GeoServerPropertyFactoryBean.java>:\[7,1\] cannot access org.geoserver.platform.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/exception/GeoServerExceptions.java>:\[6,1\] cannot access org.geoserver.platform.exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceStore.java>:\[50,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceStore.java>:\[72,18\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: interface org.geoserver.platform.resource.ResourceStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[25,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceStore.java>:\[84,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceStore.java>:\[93,18\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceStore.java>:\[93,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotificationDispatcher.java>:\[13,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[8,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[8,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[8,15\] import requires canonical name for <any>.File
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[10,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[117,13\] cannot find symbol
[ERROR] symbol: class File
[ERROR] location: class org.geoserver.platform.resource.ResourceNotification
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[117,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[117,58\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/ResourceNotification.java>:\[117,78\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[96,5\] cannot find symbol
[ERROR] symbol: class InputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[103,5\] cannot find symbol
[ERROR] symbol: class OutputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[113,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[123,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[165,5\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[197,41\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/resource/Resource.java>:\[210,55\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[10,17\] cannot find symbol
[ERROR] symbol: class Arrays
[ERROR] location: package java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[14,17\] cannot access java.util.concurrent
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[15,17\] cannot access java.util.logging
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[17,8\] cannot access javax
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[17,13\] cannot access javax.servlet
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[17,21\] import requires canonical name for <any>.ServletContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[19,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[19,20\] cannot access org.geotools.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[19,25\] import requires canonical name for <any>.SoftValueHashMap
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[20,25\] package org.geotools.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[21,25\] cannot access org.geotools.util.factory
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[21,33\] package org.geotools.util.factory does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[22,25\] cannot access org.geotools.util.logging
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[22,33\] package org.geotools.util.logging does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[23,11\] cannot access org.springframework
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[23,27\] cannot access org.springframework.beans
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[23,33\] import requires canonical name for <any>.BeansException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[24,27\] cannot access org.springframework.context
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[24,35\] package org.springframework.context does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[25,35\] package org.springframework.context does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[26,35\] package org.springframework.context does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[27,35\] package org.springframework.context does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[28,35\] cannot access org.springframework.context.event
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[28,41\] package org.springframework.context.event does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[29,27\] cannot access org.springframework.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[29,31\] cannot access org.springframework.web.context
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[29,39\] import requires canonical name for <any>.WebApplicationContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[46,45\] cannot find symbol
[ERROR] symbol: class ApplicationContextAware
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[46,70\] cannot find symbol
[ERROR] symbol: class ApplicationListener
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[56,12\] cannot find symbol
[ERROR] symbol: class SoftValueHashMap
[ERROR] location: class org.geoserver.platform.GeoServerExtensions
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[76,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[85,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[98,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[98,74\] cannot find symbol
[ERROR] symbol: class BeansException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[115,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[176,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[209,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[257,50\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[293,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[335,36\] cannot find symbol
[ERROR] symbol: class ApplicationEvent
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[343,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[378,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java>:\[402,59\] cannot find symbol
[ERROR] symbol: class ServletContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[9,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[10,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[11,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[12,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[13,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[14,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[15,21\] cannot access javax.servlet.http
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[15,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[16,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[27,48\] cannot find symbol
[ERROR] symbol: class Filter
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[31,26\] cannot find symbol
[ERROR] symbol: class ServletRequest
[ERROR] location: class org.geoserver.platform.AdvancedDispatchFilter
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[31,50\] cannot find symbol
[ERROR] symbol: class ServletResponse
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[31,76\] cannot find symbol
[ERROR] symbol: class FilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[32,33\] cannot find symbol
[ERROR] symbol: class ServletException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[40,22\] cannot find symbol
[ERROR] symbol: class FilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[40,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[42,54\] cannot find symbol
[ERROR] symbol: class HttpServletRequestWrapper
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/AdvancedDispatchFilter.java>:\[46,44\] cannot find symbol
[ERROR] location: class org.geoserver.platform.AdvancedDispatchFilter.AdvancedDispatchHttpRequest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/Service.java>:\[9,25\] package org.geotools.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/Service.java>:\[33,11\] cannot find symbol
[ERROR] symbol: class Version
[ERROR] location: class org.geoserver.platform.Service
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/Service.java>:\[48,47\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/Service.java>:\[62,58\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/Service.java>:\[85,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/ContextLoadedEvent.java>:\[8,35\] package org.springframework.context does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/ContextLoadedEvent.java>:\[9,41\] package org.springframework.context.event does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/ContextLoadedEvent.java>:\[17,41\] cannot find symbol
[ERROR] symbol: class ApplicationContextEvent
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/ContextLoadedEvent.java>:\[19,31\] cannot find symbol
[ERROR] location: class org.geoserver.platform.ContextLoadedEvent
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/Operation.java>:\[8,17\] cannot access java.lang.reflect
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/util/VersionPropertyEditor.java>:\[8,12\] cannot access java.beans
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform/src/main/java/org/geoserver/platform/util/VersionPropertyEditor.java>:\[9,25\] package org.geotools.util does not exist
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
