[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #506
See <https://build.geoserver.org/job/geoserver-java11-qa/506/display/redirect&gt;
[...truncated 1002.56 KB...]
[INFO] Processed 8 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-sec-ldap >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-sec-ldap ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-sec-ldap <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-sec-ldap ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-sec-ldap >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-sec-ldap ---
[INFO] Fork Value is true
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/src/main/java/org/geoserver/gwc/web/gridset/AbstractGridSetPage.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/src/main/java/org/geoserver/gwc/web/gridset/AbstractGridSetPage.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-gwc ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-gwc ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 18 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-gwc ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-gwc ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-gwc ---
     [java] [debug] Using AOSP style
[INFO] Processed 69 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-gwc >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-gwc ---
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-sec-ldap <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-sec-ldap ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec-ldap ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-sec-ldap/2.16-SNAPSHOT/gs-web-sec-ldap-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --------------------< org.geoserver.web:gs-web-wcs >--------------------
[INFO] Building WCS UI Module 2.16-SNAPSHOT [35/36]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wcs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wcs ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-wcs ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs ---
[INFO] Copying 14 resources
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-wcs ---
[INFO] Compiling 10 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/classes&gt;
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-gwc <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-gwc ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-gwc >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-gwc ---
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/demo/WCSRequestBuilder.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/demo/WCSRequestBuilder.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-wcs ---
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt; uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-wcs ---
[INFO] Processed 13 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-wcs >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-wcs ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-wcs <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-wcs >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-wcs ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-wcs <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-gwc <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-gwc ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 33.218 s]
[INFO] Core Platform Module ............................... SUCCESS [ 43.945 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 27.160 s]
[INFO] Main Module ........................................ SUCCESS [02:08 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.117 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 12.297 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 11.038 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.218 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 9.956 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 18.676 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.240 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 23.749 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 49.475 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:16 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 7.064 s]
[INFO] gs-rest ............................................ SUCCESS [ 14.167 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 31.946 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 24.219 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 8.518 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 6.933 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.866 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.228 s]
[INFO] Core UI Module ..................................... SUCCESS [01:02 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 18.647 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 19.949 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.706 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.796 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 11.276 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.092 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 21.926 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 8.430 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 9.026 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.209 s]
[INFO] Community Space .................................... SUCCESS [ 0.095 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.084 s]
[INFO] BUILD FAILURE
[INFO] Total time: 08:15 min (Wall Clock)
[INFO] Finished at: 2019-08-24T06:44:49Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-kml: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed. ArrayIndexOutOfBoundsException: Index 11 out of bounds for length 10 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-kml
See <https://build.geoserver.org/job/geoserver-java11-qa/507/display/redirect&gt;
