See <https://build.geoserver.org/job/geoserver-java11-qa/54/display/redirect?page=changes>
Changes:
[Gabriel Roldan] Fix gwc tile layer load performance regression at startup
[...truncated 2.55 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java;> <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: Too many open files
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-geofence: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence/target> -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java>:\[259,20\] error while writing org.geoserver.wps.hz.HazelcastStatusStore.FilterPredicate: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/target/classes/org/geoserver/wps/hz/HazelcastStatusStore$FilterPredicate.class>: Too many open files
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[7,1\] cannot access org.geoserver.security.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/eclipse/xsd/org.eclipse.xsd/2.12.0/org.eclipse.xsd-2.12.0.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[16,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[16,47\] cannot find symbol
[ERROR] symbol: class FilterConfigException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[20,37\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.security.cas.CasFilterConfigException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[20,53\] cannot find symbol
[ERROR] symbol: class Object
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[24,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[24,53\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[24,69\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[28,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[29,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[30,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[32,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[33,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>:\[15,8\] cannot access org.geoserver.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>:\[15,52\] cannot find symbol
[ERROR] symbol: class PreAuthenticatedUserNameFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[28,17\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[30,15\] cannot find symbol
[ERROR] symbol: class URL
[ERROR] location: class org.geoserver.security.cas.CasAuthenticationHelper
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[34,15\] cannot find symbol
[ERROR] symbol: class HttpCookie
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[41,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[51,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[67,35\] cannot find symbol
[ERROR] symbol: class HttpURLConnection
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[67,66\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[78,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[78,15\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[95,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[95,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[95,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[108,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[108,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[108,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[115,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[115,70\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[116,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[132,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[136,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[145,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[163,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[177,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[192,47\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[202,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[202,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[238,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[238,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java>:\[238,61\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[28,8\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[28,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[28,67\] cannot find symbol
[ERROR] symbol: class BeanNameAware
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[31,5\] cannot find symbol
[ERROR] symbol: class ProxyGrantingTicketStorage
[ERROR] location: class org.geoserver.security.cas.ProxyGrantingTicketCallbackFilter
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[33,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[47,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[47,56\] cannot find symbol
[ERROR] symbol: class ServletException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[54,26\] cannot find symbol
[ERROR] symbol: class ServletRequest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[54,50\] cannot find symbol
[ERROR] symbol: class ServletResponse
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[54,76\] cannot find symbol
[ERROR] symbol: class FilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[55,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java>:\[55,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[9,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[9,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[9,15\] import requires canonical name for <any>.IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[10,12\] cannot access java.net
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[11,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[11,17\] cannot access java.util.logging
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[11,25\] import requires canonical name for <any>.Level
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[12,8\] cannot access javax
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[12,13\] cannot access javax.servlet
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[12,21\] import requires canonical name for <any>.FilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[13,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[14,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[15,21\] package javax.servlet does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[16,21\] cannot access javax.servlet.http
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[16,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[17,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[18,26\] package javax.servlet.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[19,21\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[19,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[20,30\] cannot find symbol
[ERROR] symbol: class LogoutFilterChain
[ERROR] location: package org.geoserver.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[21,30\] cannot access org.geoserver.security.config
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[21,37\] package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[22,30\] cannot access org.geoserver.security.filter
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[22,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[23,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[24,11\] cannot access org.jasig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[24,17\] cannot access org.jasig.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[24,42\] import requires canonical name for <any>.client.configuration.ConfigurationKeys
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[25,21\] cannot access org.jasig.cas.client
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[25,28\] cannot access org.jasig.cas.client.proxy
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[25,34\] import requires canonical name for <any>.ProxyGrantingTicketStorage
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[26,28\] cannot access org.jasig.cas.client.session
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[26,36\] package org.jasig.cas.client.session does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[27,28\] cannot access org.jasig.cas.client.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[27,33\] package org.jasig.cas.client.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[28,28\] cannot access org.jasig.cas.client.validation
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[28,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[29,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[30,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,11\] cannot access org.springframework
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,27\] cannot access org.springframework.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[31,40\] import requires canonical name for <any>.cas.ServiceProperties
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[32,36\] cannot access org.springframework.security.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[32,40\] cannot access org.springframework.security.cas.web
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-dxf-wps: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/target> -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
