[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #61
See <https://build.geoserver.org/job/geoserver-java11-qa/61/display/redirect&gt;
[...truncated 1.53 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;:\[30,38\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] location: class org.geoserver.csw.web.CSWLayerConfig
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;:\[30,45\] cannot find symbol
[ERROR] symbol: class LayerInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;:\[71,55\] cannot find symbol
[ERROR] symbol: class CSWInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;:\[71,13\] cannot find symbol
[ERROR] symbol: class DirectDownloadSettings
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/bdb/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst&gt; (Too many open files) -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;:\[6,1\] cannot access org.geoserver.importer.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/apache/xml/xml-commons-resolver/1.2/xml-commons-resolver-1.2.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[19,1\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[19,33\] cannot find symbol
[ERROR] symbol: class Panel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[18,2\] cannot find symbol
[ERROR] symbol: class SuppressWarnings
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[21,5\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.importer.web.NewWorkspacePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[23,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[36,60\] cannot find symbol
[ERROR] symbol: class IValidator
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[36,71\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[39,30\] cannot find symbol
[ERROR] symbol: class IValidatable
[ERROR] location: class org.geoserver.importer.web.NewWorkspacePanel.WorkspaceDoesNotExistValidator
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[39,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[19,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[19,41\] cannot find symbol
[ERROR] symbol: class GeoServerTablePanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[19,61\] cannot find symbol
[ERROR] symbol: class ImportContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[21,12\] cannot find symbol
[ERROR] symbol: class PrettyTime
[ERROR] location: class org.geoserver.importer.web.ImportContextTable
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[15,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[15,44\] cannot find symbol
[ERROR] symbol: class GeoServerDataProvider
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[15,66\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[32,60\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[32,78\] cannot find symbol
[ERROR] symbol: class Property
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[32,15\] cannot find symbol
[ERROR] symbol: class Component
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[16,19\] cannot find symbol
[ERROR] location: class org.geoserver.importer.web.ImportContextProvider
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[16,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[17,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[17,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[18,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[18,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[19,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[19,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[32,15\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[32,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[32,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[37,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[37,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[42,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[42,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[42,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;:\[16,1\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;:\[16,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[8,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[8,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[8,42\] import requires canonical name for <any>.markup.html.form.TextField
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[9,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[9,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[9,43\] import requires canonical name for <any>.panel.Panel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[10,25\] cannot access org.apache.wicket.model
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[10,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[18,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[8,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[9,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[9,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[10,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[11,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[11,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[12,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[13,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[15,44\] cannot find symbol
[ERROR] symbol: class Radio
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[19,38\] cannot find symbol
[ERROR] symbol: class AjaxRequestTarget
[ERROR] location: class org.geoserver.importer.web.AjaxRadio<T>
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[21,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[40,13\] cannot find symbol
[ERROR] symbol: class RadioGroup
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[8,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[9,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[10,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[11,30\] cannot access org.apache.wicket.ajax.markup
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geotools/gt-jdbc/22-SNAPSHOT/gt-jdbc-22-SNAPSHOT.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[11,37\] cannot access org.apache.wicket.ajax.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[11,42\] import requires canonical name for <any>.AjaxLink
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[12,37\] package org.apache.wicket.markup.html does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[13,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[14,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[15,37\] cannot access org.apache.wicket.markup.html.panel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[15,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[16,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[17,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[25,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[29,5\] cannot find symbol
[ERROR] symbol: class WebMarkupContainer
[ERROR] location: class org.geoserver.importer.web.AdvancedDbParamPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[30,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[69,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[8,18\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[8,32\] import requires canonical name for <any>.jdbc.JDBCDataStoreFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[9,27\] cannot access org.geotools.jdbc
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[9,32\] import requires canonical name for <any>.JDBCDataStoreFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[10,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[11,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[12,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[12,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[13,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[13,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[15,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[15,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[15,15\] import requires canonical name for <any>.Serializable
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[16,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[18,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[19,20\] cannot access org.geotools.data
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[19,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[20,25\] cannot access org.geotools.data.sqlserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[20,35\] package org.geotools.data.sqlserver does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[21,35\] package org.geotools.data.sqlserver does not exist
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-sec-cas: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/target/classes/GeoServerApplication_ja.properties&gt; (Too many open files) -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (configClean) on project gs-web-app: Execution configClean of goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run failed: A required class was missing while executing org.apache.maven.plugins:maven-antrun-plugin:1.7:run: org/apache/tools/ant/BuildException
[ERROR] -----------------------------------------------------
[ERROR] realm = plugin>org.apache.maven.plugins:maven-antrun-plugin:1.7
[ERROR] strategy = org.codehaus.plexus.classworlds.strategy.SelfFirstStrategy
[ERROR] urls[0] = <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/apache/maven/plugins/maven-antrun-plugin/1.7/maven-antrun-plugin-1.7.jar&gt;
[ERROR] urls[1] = <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/codehaus/plexus/plexus-interpolation/1.1/plexus-interpolation-1.1.jar&gt;
[ERROR] urls[2] = <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/junit/junit/3.8.1/junit-3.8.1.jar&gt;
[ERROR] urls[3] = <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/codehaus/plexus/plexus-utils/2.0.5/plexus-utils-2.0.5.jar&gt;
[ERROR] urls[4] = <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/apache/ant/ant/1.8.2/ant-1.8.2.jar&gt;
[ERROR] urls[5] = <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/apache/ant/ant-launcher/1.8.2/ant-launcher-1.8.2.jar&gt;
[ERROR] Number of foreign imports: 1
[ERROR] import: Entry[import from realm ClassRealm[project>org.geoserver:geoserver:2.16-SNAPSHOT, parent: ClassRealm[maven.api, parent: null]]]
[ERROR]
[ERROR] -----------------------------------------------------: org.apache.tools.ant.BuildException
[ERROR] -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-geofence-server: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target&gt; -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/PluginContainerException
[ERROR]
[ERROR] mvn <goals> -rf :gs-dxf-wps
See <https://build.geoserver.org/job/geoserver-java11-qa/62/display/redirect&gt;
[...truncated 2.01 MB...]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-csw-core: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst&gt; (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;:\[5,1\] cannot access org.geoserver.wps.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/it/geosolutions/jaiext/vectorbin/jt-vectorbin/1.1.9/jt-vectorbin-1.1.9.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[12,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[12,36\] cannot find symbol
[ERROR] symbol: class AbstractAutoCompleteRenderer
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[12,65\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[15,13\] cannot find symbol
[ERROR] symbol: class StringBuilder
[ERROR] location: class org.geoserver.wps.web.RolesRenderer
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[17,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[22,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[22,48\] cannot find symbol
[ERROR] symbol: class Response
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[22,67\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[27,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[27,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[26,8\] cannot access org.geoserver.wps
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[26,35\] cannot find symbol
[ERROR] symbol: class BaseServiceAdminPage
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[26,56\] cannot find symbol
[ERROR] symbol: class WPSInfo
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[32,25\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.WPSAdminPage
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[36,25\] cannot find symbol
[ERROR] symbol: class PageParameters
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[40,15\] cannot find symbol
[ERROR] symbol: class Class
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[40,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[49,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[49,45\] cannot find symbol
[ERROR] symbol: class Form
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[105,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[110,38\] cannot find symbol
[ERROR] symbol: class AbstractFormValidator
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[114,17\] cannot find symbol
[ERROR] symbol: class FormComponent
[ERROR] location: class org.geoserver.wps.web.WPSAdminPage.TotalTimeValidator
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[115,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[118,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[118,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[124,16\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[129,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[33,1\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[33,39\] cannot find symbol
[ERROR] symbol: class Serializable
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[43,5\] cannot find symbol
[ERROR] symbol: class Name
[ERROR] location: class org.geoserver.wps.web.InputParameterValues
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[47,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[139,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[49,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[34,12\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[71,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[98,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[126,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[126,10\] cannot find symbol
[ERROR] symbol: class ProcessParameterIO
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[130,5\] cannot find symbol
[ERROR] symbol: class ProcessFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[134,5\] cannot find symbol
[ERROR] symbol: class Parameter
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[144,9\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.InputParameterValues.ParameterValue
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[146,64\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[168,16\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[172,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[8,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[11,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[11,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[11,30\] import requires canonical name for <any>.ajax.AjaxRequestTarget
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[12,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[12,30\] cannot access org.apache.wicket.ajax.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[12,35\] import requires canonical name for <any>.AjaxFormComponentUpdatingBehavior
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[13,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[13,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[13,42\] import requires canonical name for <any>.form.DropDownChoice
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[14,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[14,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[15,37\] cannot access org.apache.wicket.markup.html.panel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[15,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[16,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[17,25\] cannot access org.apache.wicket.model
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[17,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[18,21\] cannot access org.geoserver.catalog
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[18,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[19,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[20,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[22,21\] cannot access org.geoserver.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[22,25\] package org.geoserver.web does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[24,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[24,20\] cannot access org.geotools.geometry
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[24,33\] import requires canonical name for <any>.jts.ReferencedEnvelope
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[32,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[34,13\] cannot find symbol
[ERROR] symbol: class DropDownChoice
[ERROR] location: class org.geoserver.wps.web.BoundingBoxInputPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[36,5\] cannot find symbol
[ERROR] symbol: class PropertyModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[10,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[11,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[12,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[19,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[21,33\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.EnumPanel
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[21,58\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[11,25\] package org.geoserver.web does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[12,25\] cannot access org.geoserver.wps.ppio
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[12,30\] package org.geoserver.wps.ppio does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[13,30\] package org.geoserver.wps.ppio does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[14,25\] cannot access org.geoserver.wps.process
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[14,33\] package org.geoserver.wps.process does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[15,20\] cannot access org.geotools.data
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[15,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[16,20\] cannot access org.geotools.process
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[16,28\] package org.geotools.process does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[17,11\] cannot access org.opengis
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[17,19\] cannot access org.opengis.feature
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[17,32\] import requires canonical name for <any>.type.Name
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[26,5\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.OutputParameter
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[34,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[62,10\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[67,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[71,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;:\[12,17\] cannot access java.util.logging
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;&gt; <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: Too many open files
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-geofence-server: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/target&gt; -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
See <https://build.geoserver.org/job/geoserver-java11-qa/63/display/redirect&gt;
[...truncated 314.57 KB...]
(source unavailable)
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/demo/CoverageNamesModel.java&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/demo/CoverageNamesModel.java&gt; uses or overrides a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/demo/CoverageNamesModel.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/demo/WCSRequestBuilderPanel.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/main/java/org/geoserver/wcs/web/demo/WCSRequestBuilderPanel.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-wcs ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/test-classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt;:\[6,1\] cannot access org.geoserver.wcs.web.data
  <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/it/geosolutions/jaiext/errordiffusion/jt-errordiffusion/1.1.9/jt-errordiffusion-1.1.9.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/WCSAdminPageTest.java&gt;:\[6,1\] cannot access org.geoserver.wcs.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[21,17\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[21,66\] cannot find symbol
  symbol: class GeoServerWicketTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[23,22\] cannot find symbol
  symbol: class Catalog
  location: class org.geoserver.wcs.web.GeoServerWicketCoverageTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[24,22\] cannot find symbol
  symbol: class XpathEngine
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[27,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[28,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[29,19\] cannot find symbol
  symbol: class QName
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[30,19\] cannot find symbol
  symbol: class QName
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[31,19\] cannot find symbol
  symbol: class QName
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[32,19\] cannot find symbol
  symbol: class QName
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[33,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[36,28\] cannot find symbol
  symbol: class SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[36,60\] cannot find symbol
  symbol: class Exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[66,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/GeoServerWicketCoverageTestSupport.java&gt;:\[66,67\] cannot find symbol
[INFO] 17 errors
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.766 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.013 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.679 s]
[INFO] Main Module ........................................ SUCCESS [01:32 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.215 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 9.711 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 17.294 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 10.688 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 13.188 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 17.730 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.424 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 23.663 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:03 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.870 s]
[INFO] gs-rest ............................................ SUCCESS [ 19.273 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 28.625 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 31.946 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 8.133 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 8.070 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.149 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.254 s]
[INFO] Core UI Module ..................................... SUCCESS [ 53.224 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 19.109 s]
[INFO] GWC UI Module ...................................... FAILURE [ 4.289 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.909 s]
[INFO] Demos Module ....................................... SUCCESS [ 15.061 s]
[INFO] WCS UI Module ...................................... FAILURE [ 2.071 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.257 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 24.254 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 9.116 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 9.283 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.432 s]
[INFO] Community Space .................................... SUCCESS [ 0.250 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.217 s]
[INFO] BUILD FAILURE
[INFO] Total time: 06:43 min (Wall Clock)
[INFO] Finished at: 2019-05-02T08:29:15+00:00
[INFO] Final Memory: 510M/1359M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-gwc: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/maven-status/maven-compiler-plugin/testCompile/default-testCompile/createdFiles.lst&gt; (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-wcs: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/it/geosolutions/jaiext/errordiffusion/jt-errordiffusion/1.1.9/jt-errordiffusion-1.1.9.jar&gt;: Too many open files
[ERROR] symbol: class GeoServerWicketTestSupport
[ERROR] symbol: class Catalog
[ERROR] location: class org.geoserver.wcs.web.GeoServerWicketCoverageTestSupport
[ERROR] symbol: class XpathEngine
[ERROR] symbol: class QName
[ERROR] symbol: class SystemTestData
[ERROR] symbol: class Exception
[ERROR] -> [Help 2]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
See <https://build.geoserver.org/job/geoserver-java11-qa/64/display/redirect?page=changes&gt;
Changes:
[maurobartolomeoli] [GEOS-9193] made getTemplate method in HTMLFeatureInfoOutputFormat
[...truncated 316.59 KB...]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-gwc ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-gwc >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-gwc ---
[INFO] Fork Value is true
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt; uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/src/test/java/org/geoserver/wcs/web/data/WCSLayerConfigTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-wcs ---
     [java] [debug] Using AOSP style
[INFO] Processed 13 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-wcs >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-wcs ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-wcs <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-wcs >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-wcs ---
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-wcs <<<
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-wcs ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/wcs/target/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-wcs/2.16-SNAPSHOT/gs-web-wcs-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-gwc <<<
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-gwc ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-gwc ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/gwc/target/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-gwc/2.16-SNAPSHOT/gs-web-gwc-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Building GeoServer Web Application 2.16-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-app ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configClean) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
   [delete] Deleting directory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-app ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-app ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-app ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/main/java&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-app ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;: Some input files use or override a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/gs-web-app-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/gs-web-app-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/gs-web-app-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/main/webapp/data&gt;
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [434 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-app ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/src/main/java’> does not exist, ignoring.
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-app >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-app ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-app <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-app ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-app >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-app ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-app <<<
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/geoserver.war&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/gs-web-app-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/gs-web-app-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/app/target/geoserver.war&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT.war&gt;
[INFO]
[INFO] Core Platform Module ............................... SUCCESS [ 21.430 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.454 s]
[INFO] Main Module ........................................ SUCCESS [02:06 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.392 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 14.590 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 23.513 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.581 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 21.104 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 27.027 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.787 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.048 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:54 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.450 s]
[INFO] gs-rest ............................................ SUCCESS [ 32.648 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 50.308 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 52.967 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.110 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.835 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 15.449 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.238 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.727 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 33.965 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.307 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.500 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 19.595 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.440 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 39.586 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 14.359 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.266 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.857 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.740 s]
[INFO] Community Space .................................... SUCCESS [ 0.122 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.147 s]
[INFO] BUILD SUCCESS
[INFO] Total time: 10:18 min (Wall Clock)
[INFO] Finished at: 2019-05-02T10:46:33+00:00
[INFO] Final Memory: 388M/1310M
[java11] $ mvn -f extension/pom.xml -Prelease -B clean install -DconfigDirectory=../../../data -T2 -fae -Dmaven.repo.local=m2 -Dqa -Dfmt.action=check -DskipTests
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-readable POM <https://build.geoserver.org/job/geoserver-java11-qa/ws/extension/pom.xml&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/extension/pom.xml&gt; (No such file or directory) @
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project (<https://build.geoserver.org/job/geoserver-java11-qa/ws/extension/pom.xml)> has 1 error
[ERROR] Non-readable POM <https://build.geoserver.org/job/geoserver-java11-qa/ws/extension/pom.xml&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/extension/pom.xml&gt; (No such file or directory)
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
Not sending mail to unregistered user maurobartolomeoli@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11-qa/65/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] fix relative java.io.tmpdir reference
[Jody Garnett] Update based on windows installer wrapper.conf
[...truncated 316.60 KB...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Processed 69 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-gwc >>>
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-gwc ---
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-gwc <<<
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [350 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.634 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.999 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.473 s]
[INFO] Main Module ........................................ SUCCESS [02:07 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.476 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 14.527 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 24.934 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 17.300 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 16.892 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.952 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.369 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 44.670 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:37 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:01 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.210 s]
[INFO] gs-rest ............................................ SUCCESS [ 32.419 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 49.291 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 49.317 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.902 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.629 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 14.111 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.252 s]
[INFO] Core UI Module ..................................... SUCCESS [01:24 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.564 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 32.276 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.168 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.725 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 20.339 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.444 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 40.223 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 14.531 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.813 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.441 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.105 s]
[INFO] Community Space .................................... SUCCESS [ 0.135 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.119 s]
[INFO] Total time: 10:25 min (Wall Clock)
[INFO] Finished at: 2019-05-02T15:46:38+00:00
[INFO] Final Memory: 422M/1427M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11-qa/66/display/redirect&gt;
