[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #665
See <https://build.geoserver.org/job/geoserver-java11-qa/665/display/redirect&gt;
[...truncated 1.90 MB...]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --------------------< org.geoserver.csw:gs-web-csw >--------------------
[INFO] Building CSW UI Module 2.17-SNAPSHOT [61/65]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-csw ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-web-csw ---
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gt-main-23-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gwc-core-1.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[debug] Using AOSP style
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-csw >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-csw ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-csw ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-csw >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-csw ---
[INFO] Fork Value is true
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-csw ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer Extensions 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 10.473 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.340 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 17.682 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.595 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.670 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.647 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.689 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.678 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.661 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.621 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.246 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.171 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.742 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.192 s]
[INFO] OGR CORE ........................................... SUCCESS [ 6.000 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.512 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.222 s]
[INFO] Web Processing Service Module ...................... FAILURE [ 2.598 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.698 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.553 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.953 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.542 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.843 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 6.722 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 5.905 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.103 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.031 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.092 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 11.435 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.073 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.126 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 9.069 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 9.315 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.494 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.064 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.864 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 6.593 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 13.733 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.610 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.056 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.212 s]
[INFO] Printing Module .................................... SUCCESS [ 35.699 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.038 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.248 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.156 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.831 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.691 s]
[INFO] Importer Core Module ............................... SUCCESS [ 19.772 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 11.459 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 7.803 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.051 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 22.384 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 8.906 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 13.726 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 22.533 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.058 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 8.867 s]
[INFO] REST SLD service ................................... SUCCESS [ 15.559 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 15.155 s]
[INFO] GeoFence Server .................................... SUCCESS [ 35.498 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 11.440 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:28 min (Wall Clock)
[INFO] Finished at: 2019-09-01T00:48:16Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-core: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/DescribeProcess.java&gt;:\[40,29\] cannot access org.geoserver.wfs.xml.XSProfile
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/xml/XSProfile.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid distance too far back
[ERROR] Please remove or make sure it appears in the correct subdirectory of the classpath.
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/DescribeProcess.java&gt;:\[68,5\] cannot find symbol
[ERROR] symbol: class XSProfile
[ERROR] location: class org.geoserver.wps.DescribeProcess
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/xml/WPSConfiguration.java&gt;:\[14,25\] cannot access org.geoserver.wfs.CatalogNamespaceSupport
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/CatalogNamespaceSupport.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid code lengths set
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/xml/WPSConfiguration.java&gt;:\[15,36\] cannot access org.geoserver.wfs.xml.v1_0_0.GetFeatureTypeBinding
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/xml/v1_0_0/GetFeatureTypeBinding.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid block type
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[11,25\] cannot access org.geoserver.wfs.WebFeatureService
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/WebFeatureService.class)&gt;
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[12,29\] cannot access org.geoserver.wfs.kvp.GetFeatureKvpRequestReader
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/kvp/GetFeatureKvpRequestReader.class)&gt;
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[13,33\] cannot access org.geoserver.wfs.request.FeatureCollectionResponse
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/request/FeatureCollectionResponse.class)&gt;
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/ShapeZipPPIO.java&gt;:\[24,34\] cannot access org.geoserver.wfs.response.ShapeZipOutputFormat
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/response/ShapeZipOutputFormat.class)&gt;
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/DescribeProcess.java&gt;:\[97,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/WFSPPIO.java&gt;:\[223,49\] cannot access org.geoserver.wfs.xml.v1_0_0.WFS
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/xml/v1_0_0/WFS.class)&gt;
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/WFSPPIO.java&gt;:\[246,49\] cannot access org.geoserver.wfs.xml.v1_1_0.WFS
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/xml/v1_1_0/WFS.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: too many length or distance symbols
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/xml/WPSConfiguration.java&gt;:\[63,61\] cannot find symbol
[ERROR] symbol: class GetFeatureTypeBinding
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/xml/WPSConfiguration.java&gt;:\[66,29\] cannot find symbol
[ERROR] symbol: class CatalogNamespaceSupport
[ERROR] location: class org.geoserver.wps.xml.WPSConfiguration
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[36,9\] cannot find symbol
[ERROR] symbol: class WebFeatureService
[ERROR] location: class org.geoserver.wps.executor.InternalWFSInputProvider
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[36,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[42,13\] cannot find symbol
[ERROR] symbol: class GetFeatureKvpRequestReader
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[43,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/InternalWFSInputProvider.java&gt;:\[47,9\] cannot find symbol
[ERROR] symbol: class FeatureCollectionResponse
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/kvp/ExecuteKvpRequestReader.java&gt;:\[249,54\] cannot access org.geoserver.wfs.kvp.BBoxKvpParser
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wfs/2.17-SNAPSHOT/gs-wfs-2.17-SNAPSHOT.jar(/org/geoserver/wfs/kvp/BBoxKvpParser.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid stored block lengths
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/ShapeZipPPIO.java&gt;:\[59,9\] cannot find symbol
[ERROR] symbol: class ShapeZipOutputFormat
[ERROR] location: class org.geoserver.wps.ppio.ShapeZipPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/ShapeZipPPIO.java&gt;:\[59,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/ShapeZipPPIO.java&gt;:\[66,25\] cannot find symbol
[ERROR] symbol: variable ShapeZipOutputFormat
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <https://build.geoserver.org/job/geoserver-java11-qa/666/display/redirect&gt;
