See <https://build.geoserver.org/job/geoserver-java11-qa/7/display/redirect?page=changes>
Changes:
[Andrea Aime] Remove usage of deprecated DefaultQuery
[...truncated 1.59 MB...]
[INFO] WMS UI Module ...................................... SUCCESS [ 22.779 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 20.593 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 20.324 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.474 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 10.939 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.651 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 36.489 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 11.694 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 10.483 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.653 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.254 s]
[INFO] Printing Module .................................... SUCCESS [ 19.893 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.237 s]
[INFO] Community Space .................................... SUCCESS [ 0.285 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.247 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 7.642 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 3.000 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 24.286 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.567 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.029 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.887 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.412 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.367 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 13.692 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 13.218 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.517 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.180 s]
[INFO] OGR CORE ........................................... SUCCESS [ 12.375 s]
[INFO] OGR WFS ............................................ SUCCESS [ 19.375 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.172 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 47.944 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.722 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.220 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.388 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 8.903 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.114 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 19.144 s]
[INFO] Web process status sharing with Hazelcast .......... FAILURE [ 2.020 s]
[INFO] Web Processing Service GUI ......................... FAILURE [ 2.664 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 15.325 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 14.649 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.239 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 18.243 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.163 s]
[INFO] GeoServer CAS Security Module ...................... FAILURE [ 1.274 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.098 s]
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 18.203 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 11.003 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 6.790 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.334 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 13.515 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.978 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 15.564 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.328 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.210 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.417 s]
[INFO] DXF WPS PPIO ....................................... FAILURE [ 0.668 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.198 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.284 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.077 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.751 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.215 s]
[INFO] Importer Core Module ............................... SUCCESS [ 22.104 s]
[INFO] Importer REST Api Module-ng ........................ FAILURE [ 2.819 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 8.248 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.242 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.829 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 10.923 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 16.543 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 14.665 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.810 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.933 s]
[INFO] REST SLD service ................................... SUCCESS [ 20.253 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 17.017 s]
[INFO] GeoFence Server .................................... FAILURE [ 4.269 s]
[INFO] BUILD FAILURE
[INFO] Total time: 15:50 min (Wall Clock)
[INFO] Finished at: 2019-03-10T09:47:40+00:00
[INFO] Final Memory: 594M/1839M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-wps-cluster-hazelcast: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/wps-cluster-hazelcast/target/maven-status/maven-compiler-plugin/testCompile/default-testCompile/createdFiles.lst> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/dxf/wps/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>:\[24,8\] error while writing org.geoserver.wps.web.RangePanel: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/wps/web-wps/target/classes/org/geoserver/wps/web/RangePanel.class>: Too many open files
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.5:clean (default-clean) on project gs-sec-cas: Failed to clean project: Failed to delete <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/security/cas/target> -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[7,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[8,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[9,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[7,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[8,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[9,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[632,9\] cannot access org.hamcrest.Matcher
[ERROR] class file for org.hamcrest.Matcher not found
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[633,44\] cannot find symbol
[ERROR] symbol: method is(org.springframework.http.HttpStatus)
[ERROR] location: class org.geoserver.geofence.rest.RulesRestControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[635,42\] cannot find symbol
[ERROR] symbol: method notNullValue()
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[636,60\] cannot find symbol
[ERROR] symbol: method is(int)
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[638,42\] cannot find symbol
[ERROR] symbol: method nullValue()
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[657,27\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[658,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[659,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[661,63\] cannot find symbol
[ERROR] symbol: method is(java.lang.String)
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[680,27\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[681,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[682,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java>:\[684,63\] cannot find symbol
[ERROR] symbol: method is(long)
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[258,28\] cannot find symbol
[ERROR] location: class org.geoserver.geofence.rest.AdminRulesRestControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[259,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[261,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[262,60\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[264,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[281,27\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[282,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[283,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[285,63\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[302,27\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[303,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[304,45\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java>:\[306,63\] cannot find symbol
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportTaskControllerTest.java>:\[34,20\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[7,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[8,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[61,20\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportTaskControllerTest.java>:\[622,9\] cannot access org.hamcrest.Matcher
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[107,41\] cannot find symbol
[ERROR] location: class org.geoserver.importer.rest.ImporterIntegrationTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[108,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[109,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[166,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[167,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[168,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[325,17\] cannot find symbol
[ERROR] symbol: variable CoreMatchers
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[386,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[387,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[388,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[447,32\] cannot find symbol
[ERROR] symbol: method is(boolean)
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[479,41\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[480,42\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[481,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[539,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImporterIntegrationTest.java>:\[561,32\] cannot find symbol
[ERROR] -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-cluster-hazelcast
