[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #777
See <https://build.geoserver.org/job/geoserver-java11-qa/777/display/redirect&gt;
[...truncated 1.96 MB...]
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/DescribeRecord.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/DescribeRecord.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[20,39\] cannot access org.geoserver.platform.resource.Resource
  bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/resource/Resource.class)&gt;
    unable to access file: java.util.zip.ZipException: invalid block type
    Please remove or make sure it appears in the correct subdirectory of the classpath.
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[21,39\] cannot access org.geoserver.platform.resource.Resources
  bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/resource/Resources.class)&gt;
    unable to access file: java.util.zip.ZipException: invalid distance too far back
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[23,26\] cannot access org.geoserver.util.IOUtils
  bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/util/IOUtils.class)&gt;
    unable to access file: java.util.zip.ZipException: invalid stored block lengths
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/DefaultWebCatalogService.java&gt;:\[25,30\] cannot access org.geoserver.platform.GeoServerExtensions
  bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/GeoServerExtensions.class)&gt;
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[81,39\] cannot access org.geoserver.platform.FileWatcher
  bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/FileWatcher.class)&gt;
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[177,9\] cannot find symbol
  symbol: class Resource
  location: class org.geoserver.csw.store.internal.InternalCatalogStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[177,30\] cannot access org.geoserver.platform.resource.ResourceStore
  bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/resource/ResourceStore.class)&gt;
    unable to access file: java.util.zip.ZipException: invalid code lengths set
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[181,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[186,22\] cannot find symbol
  symbol: variable Resources
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java&gt;:\[187,21\] cannot find symbol
  symbol: variable IOUtils
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/DefaultWebCatalogService.java&gt;:\[61,17\] cannot find symbol
  symbol: variable GeoServerExtensions
  location: class org.geoserver.csw.DefaultWebCatalogService
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/DefaultWebCatalogService.java&gt;:\[80,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/DefaultWebCatalogService.java&gt;:\[88,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/DefaultWebCatalogService.java&gt;:\[136,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRecordsKvpRequestReader.java&gt;:\[194,17\] cannot find symbol
  location: class org.geoserver.csw.kvp.GetRecordsKvpRequestReader
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/CatalogStoreFeatureIterator.java&gt;:\[239,29\] cannot find symbol
  location: class org.geoserver.csw.store.internal.CatalogStoreFeatureIterator
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/FeatureCustomizer.java&gt;:\[51,21\] cannot find symbol
  location: class org.geoserver.csw.store.internal.FeatureCustomizer
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/DescribeRecordResponse.java&gt;:\[71,17\] cannot find symbol
  location: class org.geoserver.csw.response.DescribeRecordResponse
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/ZipOutputFormat.java&gt;:\[45,24\] cannot find symbol
  location: class org.geoserver.csw.response.ZipOutputFormat
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/ZipOutputFormat.java&gt;:\[64,13\] cannot find symbol
[INFO] 20 errors
[INFO]
[INFO] Skipping CSW UI Module
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-importer-web ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-importer-web ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer Extensions 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 6.636 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.153 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 13.058 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.783 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.254 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.582 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.662 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.861 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.404 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.733 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.438 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.975 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.773 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.048 s]
[INFO] OGR CORE ........................................... SUCCESS [ 5.479 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.297 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.048 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 30.178 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.430 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.567 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.331 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.004 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.117 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.740 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.369 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 11.712 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 6.278 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 6.013 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.111 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.619 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.110 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 11.410 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.085 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.013 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 9.100 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 9.597 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.460 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.077 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.496 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 6.332 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 1.856 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.050 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.453 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.195 s]
[INFO] Printing Module .................................... SUCCESS [ 23.887 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.059 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.432 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.204 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.480 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.519 s]
[INFO] Importer Core Module ............................... SUCCESS [ 19.538 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 13.793 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.186 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.274 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.883 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 12.027 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 12.914 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 23.047 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.599 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 9.584 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.545 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 15.871 s]
[INFO] GeoFence Server .................................... SUCCESS [ 34.722 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 12.231 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:35 min (Wall Clock)
[INFO] Finished at: 2019-09-06T20:51:44Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-csw-core: Compilation failure: Compilation failure:
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/resource/Resource.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid block type
[ERROR] Please remove or make sure it appears in the correct subdirectory of the classpath.
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/resource/Resources.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid distance too far back
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/util/IOUtils.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid stored block lengths
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/GeoServerExtensions.class)&gt;
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/FileWatcher.class)&gt;
[ERROR] symbol: class Resource
[ERROR] location: class org.geoserver.csw.store.internal.InternalCatalogStore
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/resource/ResourceStore.class)&gt;
[ERROR] unable to access file: java.util.zip.ZipException: invalid code lengths set
[ERROR] symbol: variable Resources
[ERROR] symbol: variable IOUtils
[ERROR] symbol: variable GeoServerExtensions
[ERROR] location: class org.geoserver.csw.DefaultWebCatalogService
[ERROR] location: class org.geoserver.csw.kvp.GetRecordsKvpRequestReader
[ERROR] location: class org.geoserver.csw.store.internal.CatalogStoreFeatureIterator
[ERROR] location: class org.geoserver.csw.store.internal.FeatureCustomizer
[ERROR] location: class org.geoserver.csw.response.DescribeRecordResponse
[ERROR] location: class org.geoserver.csw.response.ZipOutputFormat
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-core
See <https://build.geoserver.org/job/geoserver-java11-qa/778/display/redirect&gt;
[...truncated 22.47 KB...]
  at java.base/java.lang.Thread.run(Thread.java:834)
jenkins.util.io.CompositeIOException: Unable to remove directory <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/restconfig&gt; with directory contents: [<https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/restconfig/target\]>
  at jenkins.util.io.PathRemover.removeOrMakeRemovableThenRemove(PathRemover.java:246)
  at jenkins.util.io.PathRemover.tryRemoveFile(PathRemover.java:201)
  at jenkins.util.io.PathRemover.tryRemoveRecursive(PathRemover.java:212)
  at jenkins.util.io.PathRemover.tryRemoveDirectoryContents(PathRemover.java:222)
  at jenkins.util.io.PathRemover.tryRemoveRecursive(PathRemover.java:211)
  at jenkins.util.io.PathRemover.forceRemoveDirectoryContents(PathRemover.java:83)
  at hudson.Util.deleteContentsRecursive(Util.java:259)
  at hudson.Util.deleteContentsRecursive(Util.java:248)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:596)
  at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
  at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
  at hudson.remoting.UserRequest.perform(UserRequest.java:212)
  at hudson.remoting.UserRequest.perform(UserRequest.java:54)
  at hudson.remoting.Request$2.run(Request.java:369)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
  at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
  at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
  at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
java.nio.file.DirectoryNotEmptyException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/restconfig&gt;
  at java.base/sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:243)
  at java.base/sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:110)
  at java.base/java.nio.file.Files.deleteIfExists(Files.java:1180)
  at jenkins.util.io.PathRemover.removeOrMakeRemovableThenRemove(PathRemover.java:233)
  at jenkins.util.io.PathRemover.removeOrMakeRemovableThenRemove(PathRemover.java:237)
jenkins.util.io.CompositeIOException: Unable to remove directory <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src&gt; with directory contents: [<https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/restconfig\]>
java.nio.file.DirectoryNotEmptyException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src&gt;
jenkins.util.io.CompositeIOException: Unable to remove directory <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver&gt; with directory contents: [<https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src\]>
java.nio.file.DirectoryNotEmptyException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver&gt;
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Failed to delete workspace
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:599)
  at java.util.concurrent.FutureTask.run(FutureTask.java:264)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
  at java.lang.Thread.run(Thread.java:834)
  Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-0ec88a8ae3905852c
    at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
    at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
    at hudson.remoting.Channel.call(Channel.java:957)
    at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
    at sun.reflect.GeneratedMethodAccessor184.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
    at com.sun.proxy.$Proxy83.execute(Unknown Source)
    at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1152)
    at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1192)
    at hudson.scm.SCM.checkout(SCM.java:504)
    at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
    at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
    at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
    at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
    at hudson.model.Run.execute(Run.java:1818)
    at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
    at hudson.model.ResourceController.execute(ResourceController.java:97)
    at hudson.model.Executor.run(Executor.java:429)
Caused by: jenkins.util.io.CompositeIOException: Unable to delete '<https://build.geoserver.org/job/geoserver-java11-qa/ws/'.> Tried 3 times (of a maximum of 3) waiting 0.1 sec between attempts.
  at jenkins.util.io.PathRemover.forceRemoveDirectoryContents(PathRemover.java:86)
  ... 10 more
See <https://build.geoserver.org/job/geoserver-java11-qa/779/display/redirect&gt;
