[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #806
See <https://build.geoserver.org/job/geoserver-java11-qa/806/display/redirect&gt;
[...truncated 1.96 MB...]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-importer-web ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-importer-web ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/test/java/org/geoserver/csw/store/internal/ResourceAccessManagerCSWTest.java&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/test/java/org/geoserver/csw/store/internal/ResourceAccessManagerCSWTest.java&gt; uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/test/java/org/geoserver/csw/store/internal/ResourceAccessManagerCSWTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-csw-core ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-csw-core ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gwc-core-1.17-SNAPSHOT.jar&gt;
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gt-main-23-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-csw-core ---
[debug] Using AOSP style
[INFO] Processed 85 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-csw-core >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-csw-core ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-csw-core <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-csw-core ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-csw-core >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-csw-core ---
[INFO] Fork Value is true
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-csw-core <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-csw-core ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-csw-core ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-csw-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --------------------< org.geoserver.csw:gs-web-csw >--------------------
[INFO] Building CSW UI Module 2.17-SNAPSHOT [65/65]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-csw ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-web-csw ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gwc-core-1.17-SNAPSHOT.jar&gt;
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gt-main-23-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-csw >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-csw ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-csw ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-csw >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-csw ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer Extensions 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 6.322 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.163 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 17.828 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.569 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.519 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.552 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.484 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.874 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.457 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.715 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.401 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.053 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.766 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.050 s]
[INFO] OGR CORE ........................................... SUCCESS [ 5.109 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.630 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.052 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 26.898 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.806 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.956 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.557 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.358 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.139 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.827 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.211 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 8.686 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 6.155 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 6.139 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.123 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.546 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.088 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 12.396 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.095 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 4.328 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 9.470 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 8.671 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.253 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.074 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.463 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.016 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 11.543 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.564 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.048 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.597 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.285 s]
[INFO] Printing Module .................................... SUCCESS [ 22.939 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.052 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.462 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 5.146 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.517 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.352 s]
[INFO] Importer Core Module ............................... SUCCESS [ 18.193 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 10.089 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 7.425 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.328 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.844 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 9.729 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 12.453 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 15.889 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.405 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 7.276 s]
[INFO] REST SLD service ................................... SUCCESS [ 12.728 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 12.521 s]
[INFO] GeoFence Server .................................... FAILURE [ 27.001 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 10.080 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:18 min (Wall Clock)
[INFO] Finished at: 2019-09-08T00:36:35Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-geofence-server: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed: Index 1 out of bounds for length 0 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
See <https://build.geoserver.org/job/geoserver-java11-qa/807/display/redirect&gt;
