See <https://build.geoserver.org/job/geoserver-java11-qa/821/display/redirect>
[...truncated 1.96 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-csw-core ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gwc-core-1.17-SNAPSHOT.jar>
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gt-main-23-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-csw-core ---
[debug] Using AOSP style
[INFO] Processed 85 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-csw-core >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-csw-core ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-csw-core <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-csw-core ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-csw-core >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-csw-core ---
[INFO] Fork Value is true
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-csw-core <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-csw-core ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-csw-core ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-csw-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-csw-core/2.17-SNAPSHOT/gs-csw-core-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --------------------< org.geoserver.csw:gs-web-csw >--------------------
[INFO] Building CSW UI Module 2.17-SNAPSHOT [65/65]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-csw ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-web-csw ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gwc-core-1.17-SNAPSHOT.jar>
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/dependency/gt-main-23-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-csw >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-csw ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-csw ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-csw >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-csw ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-csw <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for GeoServer Extensions 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 5.074 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.136 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 16.449 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.983 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.378 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.796 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.454 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.853 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.395 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.781 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.907 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.058 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.776 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.057 s]
[INFO] OGR CORE ........................................... SUCCESS [ 5.039 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.987 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.055 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 26.494 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.416 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.125 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.571 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 6.154 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.135 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 6.970 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.232 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 11.552 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 5.173 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 6.394 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.077 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.238 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.172 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 11.824 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.061 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 4.872 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.724 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 12.672 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.347 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.065 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.298 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.371 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 11.810 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 4.983 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.051 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.855 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.764 s]
[INFO] Printing Module .................................... SUCCESS [ 22.032 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.049 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.618 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 4.841 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.773 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.180 s]
[INFO] Importer Core Module ............................... SUCCESS [ 16.844 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 9.919 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 7.718 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.597 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 13.605 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 9.110 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 3.350 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 14.549 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.291 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 6.728 s]
[INFO] REST SLD service ................................... SUCCESS [ 14.110 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 15.719 s]
[INFO] GeoFence Server .................................... SUCCESS [ 34.660 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 13.467 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:22 min (Wall Clock)
[INFO] Finished at: 2019-09-08T15:47:17Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/test/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanelTest.java>:\[13,31\] cannot access org.geoserver.web.admin.GlobalSettingsPage
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-core/2.17-SNAPSHOT/gs-web-core-2.17-SNAPSHOT.jar(/org/geoserver/web/admin/GlobalSettingsPage.class)>
[ERROR] unable to access file: java.util.zip.ZipException: invalid stored block lengths
[ERROR] Please remove or make sure it appears in the correct subdirectory of the classpath.
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/test/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanelTest.java>:\[20,53\] cannot access org.geoserver.web.GeoServerApplication
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-core/2.17-SNAPSHOT/gs-web-core-2.17-SNAPSHOT.jar(/org/geoserver/web/GeoServerApplication.class)>
[ERROR] unable to access file: java.util.zip.ZipException: invalid code lengths set
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/test/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanelTest.java>:\[25,30\] cannot find symbol
[ERROR] symbol: class GlobalSettingsPage
[ERROR] location: class org.geoserver.web.netcdf.NetCDFOutSettingsPanelTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/test/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanelTest.java>:\[26,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/test/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanelTest.java>:\[30,15\] cannot access org.geoserver.web.data.settings.SettingsPluginPanel
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-core/2.17-SNAPSHOT/gs-web-core-2.17-SNAPSHOT.jar(/org/geoserver/web/data/settings/SettingsPluginPanel.class)>
[ERROR] unable to access file: java.util.zip.ZipException: invalid distance too far back
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/test/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanelTest.java>:\[68,40\] cannot access org.geoserver.web.publish.PublishedEditTabPanel
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-core/2.17-SNAPSHOT/gs-web-core-2.17-SNAPSHOT.jar(/org/geoserver/web/publish/PublishedEditTabPanel.class)>
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/netcdf-out/src/test/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanelTest.java>:\[72,63\] incompatible types: java.lang.Class<org.geoserver.web.netcdf.layer.NetCDFOutTabPanel> cannot be converted to java.lang.Class<? extends org.apache.wicket.Component>
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
