See <https://build.geoserver.org/job/geoserver-java11-qa/838/display/redirect?page=changes>
Changes:
[niels] GEOS-8948 CSW-ISO: support Feature Catalogues
[niels] GEOS-8948 CSW-ISO: support Feature Catalogues (fixes)
Started by an SCM change
Running as SYSTEM
Building remotely on FleetCloud i-029678a488613cf89 (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-java11-qa/ws/>
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 54512cbe8e4e4130f3d551db6e3c8cd8af58ebdc (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 54512cbe8e4e4130f3d551db6e3c8cd8af58ebdc
Commit message: "Merge pull request #3710 from NielsCharlier/csw"
> git rev-list --no-walk 9c93f6ff5b87970898182e750abb0ca55f63b0b8 # timeout=10
[java11] $ mvn -f src/pom.xml -B clean install -DconfigDirectory=../../../data -T2 -fae -Dmaven.repo.local=m2 -Dqa -Dfmt.action=check -DskipTests
POM file src/pom.xml specified with the -f/--file command line argument does not exist
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.google.inject.internal.cglib.core.$ReflectUtils$1 (file:/usr/share/maven/lib/guice.jar) to method java.lang.ClassLoader.defineClass(java.lang.String,byte,int,int,java.security.ProtectionDomain)
WARNING: Please consider reporting this to the maintainers of com.google.inject.internal.cglib.core.$ReflectUtils$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-readable POM <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml>: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> (No such file or directory) @
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project (<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml)> has 1 error
[ERROR] Non-readable POM <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml>: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> (No such file or directory)
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
Not sending mail to unregistered user niels@anonymised.com
