See <https://build.geoserver.org/job/geoserver-java11-qa/861/display/redirect?page=changes>
Changes:
[Andrea Aime] Style post and put are failing if charset is not set in the HTTP request
Started by an SCM change
Running as SYSTEM
Building remotely on FleetCloud i-03845d1a4f73f38ac (linux-fleet)Unpacking https://github.com/AdoptOpenJDK/openjdk11-binaries/releases/download/jdk-11.0.3%2B7/OpenJDK11U-jdk_x64_linux_hotspot_11.0.3_7.tar.gz to /tmp/jenkins-bd42368c/tools/hudson.model.JDK/OpenJDK_11.0.3 on FleetCloud i-03845d1a4f73f38ac
in workspace <https://build.geoserver.org/job/geoserver-java11-qa/ws/>
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <https://build.geoserver.org/job/geoserver-java11-qa/ws/> # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 4b46a93af10e3d0c414650166eea2717cdf8eba8 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 4b46a93af10e3d0c414650166eea2717cdf8eba8
Commit message: "Merge pull request #3750 from aaime/styles_charset"
> git rev-list --no-walk b3e7e17423d560afafb84534726e6e119c1fd464 # timeout=10
[java11] $ mvn -f src/pom.xml -B clean install -DconfigDirectory=../../../data -T2 -fae -Dmaven.repo.local=m2 -Dqa -Dfmt.action=check -DskipTests
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.google.inject.internal.cglib.core.$ReflectUtils$1 (file:/usr/share/maven/lib/guice.jar) to method java.lang.ClassLoader.defineClass(java.lang.String,byte,int,int,java.security.ProtectionDomain)
WARNING: Please consider reporting this to the maintainers of com.google.inject.internal.cglib.core.$ReflectUtils$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
[INFO] Scanning for projects...
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-webdav/1.0-beta-2/wagon-webdav-1.0-beta-2.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-webdav/1.0-beta-2/wagon-webdav-1.0-beta-2.pom (1.5 kB at 7.7 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-providers/1.0-beta-2/wagon-providers-1.0-beta-2.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-providers/1.0-beta-2/wagon-providers-1.0-beta-2.pom (1.8 kB at 254 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon/1.0-beta-2/wagon-1.0-beta-2.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon/1.0-beta-2/wagon-1.0-beta-2.pom (5.9 kB at 654 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-parent/4/maven-parent-4.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-parent/4/maven-parent-4.pom (10.0 kB at 1.1 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/apache/3/apache-3.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/apache/3/apache-3.pom (3.4 kB at 572 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/slide/slide-webdavlib/2.1/slide-webdavlib-2.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/slide/slide-webdavlib/2.1/slide-webdavlib-2.1.pom (648 B at 93 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-httpclient/commons-httpclient/2.0.2/commons-httpclient-2.0.2.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-httpclient/commons-httpclient/2.0.2/commons-httpclient-2.0.2.pom (7.1 kB at 708 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-logging/commons-logging/1.0.3/commons-logging-1.0.3.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-logging/commons-logging/1.0.3/commons-logging-1.0.3.pom (866 B at 144 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/jdom/jdom/1.0/jdom-1.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/jdom/jdom/1.0/jdom-1.0.pom (1.2 kB at 195 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/de/zeigermann/xml/xml-im-exporter/1.1/xml-im-exporter-1.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/de/zeigermann/xml/xml-im-exporter/1.1/xml-im-exporter-1.1.pom (248 B at 50 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-logging/commons-logging/1.0.4/commons-logging-1.0.4.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-logging/commons-logging/1.0.4/commons-logging-1.0.4.pom (5.3 kB at 439 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-provider-api/1.0-beta-2/wagon-provider-api-1.0-beta-2.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-provider-api/1.0-beta-2/wagon-provider-api-1.0-beta-2.pom (680 B at 170 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.0.4/plexus-utils-1.0.4.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.0.4/plexus-utils-1.0.4.pom (6.9 kB at 1.1 MB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-webdav/1.0-beta-2/wagon-webdav-1.0-beta-2.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/slide/slide-webdavlib/2.1/slide-webdavlib-2.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-httpclient/commons-httpclient/2.0.2/commons-httpclient-2.0.2.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/jdom/jdom/1.0/jdom-1.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/de/zeigermann/xml/xml-im-exporter/1.1/xml-im-exporter-1.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-webdav/1.0-beta-2/wagon-webdav-1.0-beta-2.jar (17 kB at 384 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-logging/commons-logging/1.0.4/commons-logging-1.0.4.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/de/zeigermann/xml/xml-im-exporter/1.1/xml-im-exporter-1.1.jar (24 kB at 424 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-logging/commons-logging/1.0.4/commons-logging-1.0.4.jar (38 kB at 667 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.0.4/plexus-utils-1.0.4.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-provider-api/1.0-beta-2/wagon-provider-api-1.0-beta-2.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/jdom/jdom/1.0/jdom-1.0.jar (153 kB at 2.1 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/wagon/wagon-provider-api/1.0-beta-2/wagon-provider-api-1.0-beta-2.jar (46 kB at 558 kB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/slide/slide-webdavlib/2.1/slide-webdavlib-2.1.jar (173 kB at 1.9 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.0.4/plexus-utils-1.0.4.jar (164 kB at 1.8 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-httpclient/commons-httpclient/2.0.2/commons-httpclient-2.0.2.jar (225 kB at 2.2 MB/s)
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/platform> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/main> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/security> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs1_0> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs1_1> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wfs> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wms> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/kml> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/ows> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/gwc> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/rest> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wcs> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wfs> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wms> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/community> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] Child module <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension> of <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml> does not exist @
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.geoserver:geoserver:2.17-SNAPSHOT (<https://build.geoserver.org/job/geoserver-java11-qa/ws/src/pom.xml)> has 20 errors
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
