[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #864
See <https://build.geoserver.org/job/geoserver-java11-qa/864/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] [GEOS-8982] GetCapabilities on a single layer fails if a style is
[nuno.oliveira] [GEOS-9248] Allow setting Entity Expansion limit on WFS XML Readers.
[...truncated 183.01 KB...]
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-wcs2_0 ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wcs2_0 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs2_0 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-wcs2_0 ---
     [java] [debug] Using AOSP style
[INFO] Processed 86 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-wcs2_0 >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-wcs2_0 ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-restconfig-wcs <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-restconfig-wcs ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-restconfig-wcs ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-restconfig-wcs ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wcs/target/gs-restconfig-wcs-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wcs/2.17-SNAPSHOT/gs-restconfig-wcs-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wcs/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wcs/2.17-SNAPSHOT/gs-restconfig-wcs-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wcs/target/gs-restconfig-wcs-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wcs/2.17-SNAPSHOT/gs-restconfig-wcs-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wcs/target/gs-restconfig-wcs-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wcs/2.17-SNAPSHOT/gs-restconfig-wcs-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/restconfig-wcs/target/gs-restconfig-wcs-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-restconfig-wcs/2.17-SNAPSHOT/gs-restconfig-wcs-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping gs-restconfig-wfs
[INFO]
[INFO] Skipping gs-restconfig-wms
[INFO]
[INFO] -------------------< org.geoserver.web:gs-web-rest >--------------------
[INFO] Building REST UI Module 2.17-SNAPSHOT [22/36]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-rest ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-rest ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-rest ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-rest ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/classes&gt;
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-wcs2_0 <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-wcs2_0 ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-wcs2_0 >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-wcs2_0 ---
[INFO] Fork Value is true
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/src/main/java/org/geoserver/web/RESTSettingsPanel.java&gt;: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/src/main/java/org/geoserver/web/RESTSettingsPanel.java&gt; uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/src/main/java/org/geoserver/web/RESTSettingsPanel.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-rest ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-rest ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-rest ---
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-rest ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-rest <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-rest ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-web-rest >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-web-rest ---
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-web-rest <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-web-rest ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-web-rest ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-rest/2.17-SNAPSHOT/gs-web-rest-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-rest/2.17-SNAPSHOT/gs-web-rest-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-rest/2.17-SNAPSHOT/gs-web-rest-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-rest/2.17-SNAPSHOT/gs-web-rest-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/web/rest/target/gs-web-rest-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/web/gs-web-rest/2.17-SNAPSHOT/gs-web-rest-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-wcs2_0 <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-wcs2_0 ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-wcs2_0 ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wcs2_0 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wcs2_0/2.17-SNAPSHOT/gs-wcs2_0-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wcs2_0/2.17-SNAPSHOT/gs-wcs2_0-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wcs2_0/2.17-SNAPSHOT/gs-wcs2_0-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wcs2_0/2.17-SNAPSHOT/gs-wcs2_0-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wcs2_0/target/gs-wcs2_0-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/gs-wcs2_0/2.17-SNAPSHOT/gs-wcs2_0-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.347 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.368 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.207 s]
[INFO] Main Module ........................................ SUCCESS [01:10 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.085 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 5.998 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 8.344 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 10.358 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 8.068 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.314 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.581 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 16.859 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 1.553 s]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 10.455 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [ 19.519 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 7.046 s]
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.153 s]
[INFO] Core UI Module ..................................... SUCCESS [ 34.773 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.068 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SUCCESS [ 4.847 s]
[INFO] Community Space .................................... SUCCESS [ 0.087 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.080 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:02 min (Wall Clock)
[INFO] Finished at: 2019-09-10T13:39:11Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wfs: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/WfsXmlReader.java&gt;:\[72,15\] cannot find symbol
[ERROR] symbol: method setEntityExpansionLimit(java.lang.Integer)
[ERROR] location: variable parser of type org.geotools.xsd.Parser
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WfsXmlReader.java&gt;:\[59,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/wfs/src/main/java/org/geoserver/wfs/xml/v2_0/WfsXmlReader.java&gt;:\[47,15\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11-qa/865/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] [GEOS-8356] WMS GetFeatureInfo formats text/plain, GeoJSON don't handle
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.032 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.206 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.609 s]
[INFO] Main Module ........................................ SUCCESS [01:17 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.213 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 10.383 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 10.385 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.830 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 13.667 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.920 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.686 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 20.163 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 2.379 s]
[INFO] gs-rest ............................................ SUCCESS [ 17.966 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 24.358 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.123 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.163 s]
[INFO] Core UI Module ..................................... SUCCESS [ 48.870 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.134 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.167 s]
[INFO] Community Space .................................... SUCCESS [ 0.094 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.072 s]
[INFO] Total time: 03:44 min (Wall Clock)
[INFO] Finished at: 2019-09-10T13:54:53Z
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11-qa/866/display/redirect&gt;
