[Geoserver-devel] Build failed in Jenkins: geoserver-java11-qa #877
See <https://build.geoserver.org/job/geoserver-java11-qa/877/display/redirect&gt;
[...truncated 38.46 KB...]
  at java.base/java.lang.Thread.run(Thread.java:834)
jenkins.util.io.CompositeIOException: Unable to remove directory <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/wfs&gt; with directory contents: [<https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/wfs/target\]>
  at jenkins.util.io.PathRemover.removeOrMakeRemovableThenRemove(PathRemover.java:246)
  at jenkins.util.io.PathRemover.tryRemoveFile(PathRemover.java:201)
  at jenkins.util.io.PathRemover.tryRemoveRecursive(PathRemover.java:212)
  at jenkins.util.io.PathRemover.tryRemoveDirectoryContents(PathRemover.java:222)
  at jenkins.util.io.PathRemover.tryRemoveRecursive(PathRemover.java:211)
  at jenkins.util.io.PathRemover.forceRemoveDirectoryContents(PathRemover.java:83)
  at hudson.Util.deleteContentsRecursive(Util.java:259)
  at hudson.Util.deleteContentsRecursive(Util.java:248)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:596)
  at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
  at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
  at hudson.remoting.UserRequest.perform(UserRequest.java:212)
  at hudson.remoting.UserRequest.perform(UserRequest.java:54)
  at hudson.remoting.Request$2.run(Request.java:369)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
  at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
  at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
  at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
java.nio.file.DirectoryNotEmptyException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/wfs&gt;
  at java.base/sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:243)
  at java.base/sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:110)
  at java.base/java.nio.file.Files.deleteIfExists(Files.java:1180)
  at jenkins.util.io.PathRemover.removeOrMakeRemovableThenRemove(PathRemover.java:233)
  at jenkins.util.io.PathRemover.removeOrMakeRemovableThenRemove(PathRemover.java:237)
jenkins.util.io.CompositeIOException: Unable to remove directory <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src&gt; with directory contents: [<https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src/wfs\]>
java.nio.file.DirectoryNotEmptyException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src&gt;
jenkins.util.io.CompositeIOException: Unable to remove directory <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver&gt; with directory contents: [<https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver/src\]>
java.nio.file.DirectoryNotEmptyException: <https://build.geoserver.org/job/geoserver-java11-qa/ws/geoserver&gt;
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Failed to delete workspace
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:599)
  at java.util.concurrent.FutureTask.run(FutureTask.java:264)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
  at java.lang.Thread.run(Thread.java:834)
  Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-04d0af00aad7e1b1a
    at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
    at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
    at hudson.remoting.Channel.call(Channel.java:957)
    at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
    at sun.reflect.GeneratedMethodAccessor184.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
    at com.sun.proxy.$Proxy83.execute(Unknown Source)
    at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1152)
    at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1192)
    at hudson.scm.SCM.checkout(SCM.java:504)
    at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
    at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
    at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
    at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
    at hudson.model.Run.execute(Run.java:1818)
    at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
    at hudson.model.ResourceController.execute(ResourceController.java:97)
    at hudson.model.Executor.run(Executor.java:429)
Caused by: jenkins.util.io.CompositeIOException: Unable to delete '<https://build.geoserver.org/job/geoserver-java11-qa/ws/'.> Tried 3 times (of a maximum of 3) waiting 0.1 sec between attempts.
  at jenkins.util.io.PathRemover.forceRemoveDirectoryContents(PathRemover.java:86)
  ... 10 more
See <https://build.geoserver.org/job/geoserver-java11-qa/878/display/redirect&gt;
