See <https://build.geoserver.org/job/geoserver-java11-qa/969/display/redirect>
[...truncated 1.95 MB...]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-ogr-wps ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-ogr-wps >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-ogr-wps ---
[INFO] Fork Value is true
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-importer-web ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/dependency/gwc-core-1.17-SNAPSHOT.jar>
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/dependency/gt-main-23-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[java] [debug] Using AOSP style
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-web >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-web ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-web ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-importer-web >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-importer-web ---
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-ogr-wps <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-ogr-wps ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-ogr-wps ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-ogr-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.17-SNAPSHOT/gs-ogr-wps-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] -------------------< org.geoserver.csw:gs-csw-core >--------------------
[INFO] Building Catalog Services for the Web core module 2.17-SNAPSHOT [64/65]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.pom (1.1 kB at 219 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xalan/serializer/2.7.1/serializer-2.7.1.jar (278 kB at 31 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-csw-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-csw-core ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-csw-core ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-csw-core ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-csw-core ---
[INFO] Compiling 62 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetDomainKvpRequestReader.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetDomainKvpRequestReader.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-csw-core ---
[INFO] Copying 25 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-csw-core ---
[INFO] Compiling 23 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/test-classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/test/java/org/geoserver/csw/store/internal/ResourceAccessManagerCSWTest.java>: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/test/java/org/geoserver/csw/store/internal/ResourceAccessManagerCSWTest.java> uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/src/test/java/org/geoserver/csw/store/internal/ResourceAccessManagerCSWTest.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-csw-core ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/gs-csw-core-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-csw-core ---
[INFO] Copying gwc-core-1.17-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gwc-core-1.17-SNAPSHOT.jar>
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/csw/core/target/dependency/gt-main-23-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-csw-core ---
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-importer-web ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for GeoServer Extensions 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 7.599 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.224 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 15.653 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.772 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.302 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.394 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.622 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.888 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.552 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.878 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.767 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.978 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.030 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.069 s]
[INFO] OGR CORE ........................................... SUCCESS [ 5.647 s]
[INFO] OGR WFS ............................................ SUCCESS [ 7.149 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.065 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 37.393 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.641 s]
[INFO] Excel Output Format ................................ SUCCESS [ 10.430 s]
[INFO] Chart external graphics support .................... SUCCESS [ 5.037 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.320 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.184 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.685 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.137 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 14.238 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 7.059 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 6.785 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.133 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 20.272 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.094 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 12.803 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.108 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.610 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.267 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 10.831 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.240 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.078 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 13.629 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.258 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 5.082 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.055 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.927 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.015 s]
[INFO] Printing Module .................................... SUCCESS [ 24.648 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.043 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.944 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.505 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.258 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.533 s]
[INFO] Importer Core Module ............................... SUCCESS [ 24.071 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 13.735 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 9.607 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.391 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 16.481 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 8.943 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 14.656 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 16.647 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.928 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 7.449 s]
[INFO] REST SLD service ................................... SUCCESS [ 15.825 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 14.120 s]
[INFO] GeoFence Server .................................... SUCCESS [ 35.645 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 11.250 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:56 min (Wall Clock)
[INFO] Finished at: 2019-09-15T08:48:57Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-csw-core: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed. ArrayIndexOutOfBoundsException: Index 36 out of bounds for length 33 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-core
